07-05-2019, 12:28 PM | #1 |
Rep 463
TTE550 vs PS2
Anyone have experience with both of these turbos? I'm looking at both and am torn. They both seem to make roughly the same power and dyno plots look similar. I can't find compressor maps for either.
If you had to pick one which would you choose and why? Keep in mind this is for a street car. |
07-07-2019, 12:06 AM | #2 | |
Rep 1,466
I believe SeanWRT has the TTE550, and has knowledge of the PS2 from other vehicles so he might be able to shed some light on the differences. My understanding is that PS2 is significantly cheaper because they can handle core exchange in the US, whereas other hybrid vendors either don't support a core deposit, and / or aren't US based which slows things down a lot. The other thing that puts me off about going PS2, is that I keep hearing rumours of different versions of PS2. Is there a PS2+ for the M2? How many fins does it have, is a titanium impeller etc. I wish they'd publish version numbers and details if they are changing the specs like that.
2018 ///M2 LCI, LBB, 6MT...
07-07-2019, 10:15 AM | #4 | ||
Rep 2,577
PS2 is physically bigger and is the only proven hybrid turbo that supports 22+psi (WMI and fueling are also required), or at least holds up that kind of boost for a short while. Also very obvious with the PS2 is the turbo lag. If you live in the city downtown, it's quite annoying as you'll be feeling it most of time bumper to bumper traffic. The car feels sluggish. I'd set up a goal first and decide which turbo to do.
Lemania 2320
07-07-2019, 12:34 PM | #5 | |||
Rep 463
Ultimately, the goal is as much top end power as is possible without sacrificing daily drivability in traffic. The car is already FBO w a Dinan turbo and XDI hpfp so a bugger turbo would somewhat plug and play. My thought being that because I'm limited to 91 octane and do not want to deal with meth injection, a larger turbo at the same PSI I'm currently tuned to(approx 18psi) would flow more air and result with a slightly cooler AIT. My worry w the TTE is that they're in Germany and if I need support for whatever reason it's going to be a huge pain. Plus, if I install it only to find that the lag is similar to the PS2 then it would make more sense just to go the Pure route |
Happy Motoring474.00 |
07-07-2019, 01:35 PM | #6 |
Rep 449
You have Dinan turbo with xdi and want more?? Just curious what you're putting down now and how much more you're looking for.
07-07-2019, 06:18 PM | #7 |
Rep 2,577
OP, if you're already octane limited, you won't be gaining much going from Dinan turbo to a STG2 hybrid. I doubt you can do 18psi reliably on 91 whatever turbo you're on, unless it's very cold where you live.
Lemania 2320
07-07-2019, 07:15 PM | #8 |
Rep 463
370whp on a dynapack known as "the heartbreaker" I suspect on a another dyno I would make a good 20-30hp more but these numbers are irrelevant. I will make some Dragy runs soon. That will really tell how much power is being made. Ultimately I would love if the car could run mid 11's in the 1/4 mile. I highly doubt it has that type of speed in it's current configuration.
07-08-2019, 10:22 PM | #9 | |
Rep 72
07-11-2019, 01:58 PM | #10 | |
Rep 328
What tune are you running? I made 398whp on stock turbo with BM3 on a very conservative dyno. Cleve |
07-11-2019, 03:52 PM | #11 | ||
Rep 463
07-11-2019, 05:51 PM | #12 |
Rep 463
Also, for those following. Being that octane is the biggest factor holding me back I'm caving in and likely going the meth injection route before I get a bigger turbo. Looking at all the systems and their safeguards(or lack thereof) I think the Twisted Tuning direct port kit is ideal. My inference is that It’s a rebranded torqebyte controller which from everything I've been able to find is really quite impressive in its capabilities. Specifically whats attractive to me is that the tune can be setup in a way so that when the meth tank runs dry the car stays off boost. Seems ideal and dummy proof to me vs most of the other systems.
07-11-2019, 11:29 PM | #13 | |
Rep 22
07-12-2019, 12:11 AM | #14 | ||
Rep 463
07-12-2019, 09:33 AM | #15 | |
Rep 22
I am waiting for TTE550 and will be tuning for Shell 100 octane. |
07-12-2019, 01:25 PM | #16 | |
Rep 1,466
There is no way that I'm aware of to integrate WMI with a DME map; the two are unaware of one another. I've been designing my own fail-safe circuit, and have been running with my car in 'fail-safe' mode for a couple of days now. It's working fine apart from at WOT, so I need to tweak the MAP response, but it's not complex. Does Twisted Tuning have this as part of their Torqbyte controller?
07-12-2019, 01:37 PM | #17 | ||
Rep 463
Checkout that video, not Justin's kit per day but this guy does use the Torqebyte controller. It appears that when the failsafe is triggered the ground to the wastegate solenoid is broken causing the car to stay off boost as is its own built in safety. It's definitely a hack but I'm ok with it. When I spoke to Justin he mentioned that his tunes are "setup with knock safeties that reduce load when I certain about of knock is registered". Admittedly I am very ignorant to all of this as I learn by doing. So I'll likely be much more informed once I'm done with this vs now which is still the research stage for me |
07-12-2019, 01:46 PM | #18 |
Rep 1,466
Ahhh... That sort of fail-safe is what I'm calling 'in-elegant'. It's very easy to achieve this with almost any meth controller on the market that has some sort of fail-safe switching output.
To achieve a drive-train error, which will indeed protect your engine, all you need to do is to disconnect either the TMAP MAP sensor wire, or the EWG position sensor wire. In both of these cases, you'll get a CEL error that the sensor has shorted to positive (there is a hold up resistor, so that in absence of a signal, the DME sees it as a short to positive), along with a drive-train error. Aquamist's default installation instructions do this by using a relay in their controller to switch the EWG sensor wire to 5v, but I'm working on a solution that doesn't cause a CEL. So far, what I've been able to do is bias the TMAP sensor voltage high, so that the DME sees a higher boost voltage than is really there. I'm not getting a cell, and the car is slower, but at WOT, there are some isses still.
07-12-2019, 02:08 PM | #19 | |
Rep 463
In a perfect world, the car would just revert to a lower boost level once the meth is gone vs completely staying off boost. |
07-12-2019, 05:42 PM | #20 | |
Rep 1,466
That's what I'm trying to design; a piggyback boost reducer. That way you can have your car tuned for Meth, and then either switch the system off for a 'valet' mode, or let the fail-safe kick in and still be drivable, but at a reduced load. The system I've made so far works for part throttle, but at WOT you get some hunting where the throttle plate closes, EWG dumps boost but only for about half a second before building pressure again. I think I've made two mistakes with the system so far - 1 is that it's too agressive, it basically doubles the apparent boost until clipping at ~21psi. This means that by the time you're at 10psi of boost, the DME sees 20pst, which is probably too much. The second issue is that the region where clipping occurs is too large. It starts clipping at 21psi when the engine is really producing 10.5psi, and anything over that shows at 21. I'm working on a new version of the controller now which should track an adjustable amount of psi above truth, and start testing at say 3psi above reality?
M2OG400.00 |
