03-19-2022, 08:31 PM | #45 | |
Rep 165
2020 HS M2C
03-20-2022, 07:15 AM | #46 | |
Rep 1,610
When I bought mine there were only 3 too, message them and they will add more |
03-20-2022, 11:38 AM | #48 |
Rep 201
What do these tips weigh?
My AA tips are true double wall, install with band clamps, and are heavy. Would be cool if I could drop a few pounds with lighter tips.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
03-21-2022, 12:10 AM | #49 |
Rep 165
Do you guys think these are the same tips from a different seller?
https://www.ebay.com/itm/36344267837...Cclp%3A2047675
2020 HS M2C
03-27-2022, 04:26 AM | #50 | |
Rep 7,637
11-10-2022, 12:01 AM | #52 |
Rep 120
Is is possible to add tips with a 80mm ID on a stock exhaust? Could a shop come up with a adapter to make this work. Would it be worth the hassle?
11-10-2022, 12:25 AM | #53 |
Rep 8,970
11-10-2022, 07:58 AM | #54 |
Rep 287
A shop can make an adapter, but I'll tell you my own recent troubles trying to do something similar. I have the Remus Race which has 60 mm OD pipes. Before installing the Remus, I had the BMW M Performance carbon tips on the stock exhaust. These have a 70mm ID. I liked the way they looked as they complement the CF diffuser, etc. You would think it's easy to find a shop to make an adaptor. No. I tried a local exhaust shop and a local metal fabricators. Neither could help. I ended up going with shop that makes custom exhaust tips and they were able to build the adapter to spec, but it's been a long journey that I'm still not completely done with. Let's hope it's worth it.
chris7197334.00 |
02-10-2023, 09:33 AM | #55 | |
Rep 1
I am looking for these exhaust tips but the link isn't working anymore :/ could you please help me? They look amazing and I need to have them. Thx in advance, Kind regards, Steve |
03-25-2023, 09:59 PM | #56 |
Rep 5,373
+1
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
03-31-2023, 05:34 PM | #57 |
Rep 183
06-05-2023, 10:06 AM | #58 |
Rep 111
Hi all, on the Mode or Ebay tips does anyone have a rough length measurement to the longest portion of the tip? The Mode's are currently out of stock in black and the ebay links earlier in this post are too old at this point.
I found these on Aliexpress that seem as if they would be pretty close to some of these others. I definitely do not want them sticking out too far though. It looks like they are 140mm (although another spot they list as 142mm).... https://www.aliexpress.us/item/3256804511395814.html TIA! |
06-06-2023, 11:44 AM | #59 |
Rep 111
Looks like the black Mode tips are no longer (at least for time being). I went ahead and ordered the Aliexpress ones I linked to above. They confirmed they are 140mm in length and groove cut-out length for the alignment pin on top is same as OEM, so with all this said I think are pretty close to the Modes.
06-07-2023, 09:26 PM | #60 |
M///modifyer
2489
Rep 1,295
I have the Black chrome (same as Mode sell), replaced my carbon versions. See last pic for a comparison.
They are 70mm int dia, ext dia is 97mm, length is 142mm.
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022 |
06-17-2023, 11:56 AM | #61 | |
Rep 15
I also have a EL midpipe and depending on how you install it can effect how much your hangers are being pushed on/kick the tips out. |
MSH_121.50 |
06-18-2023, 09:50 AM | #62 | |
Rep 111
06-18-2023, 03:05 PM | #63 | |
Rep 42
This was after a roadtrip of 2000km through Germany. Car was stock with OPF delete and AA EL MP. |
06-18-2023, 09:05 PM | #64 |
Rep 111
Did you order through Aliexpress? If so which vendor? I'm sure most of them are probably the same but still curious. I threw mine on today. Fortunately, not sticking out too far and look good for now. I guess time will tell...
06-19-2023, 06:33 AM | #65 | |
Rep 42
I am pretty sure these are all the same as the Mode ones, mine were matte black. |
