11-18-2023, 03:42 PM | #1 |
Rep 1,681
Help with my brakes squeaking??
Hi guys,
Have had my front brake pads replaced twice due to vibrations when breaking at 50+ mph but have also dealt with brake squeaking for the past year or so. I don’t drive the car a lot but I want to finally get this fixed and need advise on how or what to do. The dealer says that they do not cover brake noise so what is my next move? Below is a video of the noise I deal with every time I drive after 5 mins or so. I’ve noticed it goes away a bit after a car wash but eventually always comes back. https://youtu.be/yoL2eiR-Qk4?si=66gGcmoeDdVAn3pk
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
11-18-2023, 04:36 PM | #2 |
Rep 2,873
About a dozen threads covering this topic, do a quick search for more info. It's fairly typical. Properly bedding in your brakes may help. I think there are some aftermarket pad recommendations too.
11-18-2023, 06:59 PM | #3 |
I like turtles!
726
Rep 698
They squeak. BMW even made a brochure to hand out to clients complaining about it. If you didn't get one, go back to your service advisor and ask for one. It basically says "M brakes squeak. It's normal in our opinion and that is the only one that matters. Have a nice day"
Distinct147.00 |
11-20-2023, 11:12 AM | #4 |
Rep 3,842
Yes, they squeak. After a good jet wash mine stop squeaking but it only lasts for a short time. A couple of abs test stops will help too but the reprieve is short lived.
11-20-2023, 04:39 PM | #6 |
Rep 1,681
I’ve heard that it’s normal to squeak but I didn’t think 3 years in I’d be hearing it every single time I come to a stop. Guess that really is just the way it is if I’m not able to get on the highway every drive and give it a few good brakes.
Current: ///M2C
11-20-2023, 05:42 PM | #7 |
Rep 4,672
Unfortunately you have to use them like they were intended every once in a while or they will squeal. Go through a good bed in process. Let them cool and they will be good for a little while.
11-21-2023, 04:01 PM | #9 | |
Rep 8,970
Where is the fast out of town runs and hard braking? That will sort them out. |
11-22-2023, 02:24 AM | #10 |
Rep 501
Mines started squeaking when my car hit 500 miles. I didn’t even bother to take it to the dealership. The squeaking comes and goes during the 3 years I have had the car. Almost 32k miles and still on the same brake pads since day 1.
2021 F87 M2C HS DCT/MPE (Nov 2020 - Present)
2018 F32 440i MR/CR MPPSK (Mar 2018 - Nov 2020) 2014 F32 435i EB/CR (May 2014 - May 2017) 2011 E92 335is AW/CR (Nov 2010 - Nov 2013) 2008 E92 328i JB/BL (Feb 2008 - Nov 2010) |
11-23-2023, 12:32 PM | #11 |
Rep 60
The stock brakes pad compound throws a lot of dust & I found them to be rather sensitive & grabby. It's the excessive amount of dust that causes the squeal.
To address these issues I installed a set of HWAK Ceramic brake pads front & rear... Part #'s: (Front - HB828Z.760 Rear - HB193Z.670) All of the issues mentioned above were resolved. The only caveat is that for the rear pads there is no provision for the wear sensor, which for me wasn't a big deal as I just tied it off to the side. BTW, These pads are available from AMAZON Good luck! |
12-02-2023, 12:31 PM | #12 |
Rep 112
Drives: 2020 LBB M2C
I've learned over time that when I get squealing brakes when coming to a stop, it's time to wash the car. The squealing then goes away. I'm guessing it has to do with brake dust accumulation.
chris7197334.00 |
12-02-2023, 05:04 PM | #13 | |
Rep 7,298
I switched to Carbotech 1521 last weekend and the brakes have been 100% silent since. |
12-03-2023, 08:55 PM | #14 |
Rep 215
12-03-2023, 09:02 PM | #15 |
Rep 7,298
A lot less bite. Mostly for the better, but in the cold and wet so far I've had to make sure I tap them to kind of get them dried off a bit because the bite is definitely not like the stock pads. I only have 200 miles on them so far though so it may improve also.
12-07-2023, 08:46 AM | #16 |
Rep 891
Like someone said, plenty of threads on the topic. I take mine to a low-traffic road and do 4-5 hard stops from 40-50 mph. That gets rid of the squeal. It usually comes back in less than a month, and then I repeat the process. Annoying, but it is what it is.
Vehicles: 2021 Alpine White M2C 6MT; 2011 Kawasaki Z1000 (1/4 mile 10.3 seconds @ 129 mph - stock)
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
12-07-2023, 08:49 AM | #17 | |
Rep 1,681
I've noticed getting a car wash more often helps too
Current: ///M2C
12-07-2023, 10:44 AM | #18 |
Rep 4,672
Hard on brakes, stay out of abs, don't come to a stop. Quickly get back up to speed and do it again. A lot of bed in procedures suggest 10 to 20 cycles. The goal of getting enough heat into the pads to transfer material to the disc. Higher speeds make this easier, but more difficult to do safely and legally.
12-07-2023, 12:58 PM | #19 |
Rep 2,873
And don't come to a full stop during the cycles or for at least 10 minutes after you do it.
Here's a very good video, a bit of overkill if you don't track, but it shows the process and you can just do 5 or 6 cycles. Trigger warning: seeing AP brakes may cause sudden wallet-lightening. |
12-08-2023, 08:24 AM | #20 | |
Rep 891
Once they start squealing I haven't noticed a car wash helping at all, but then I'm not scrubbing the rotors.
12-08-2023, 12:09 PM | #21 |
Rep 3,842
