09-03-2021, 06:19 PM | #23 |
Rep 837
Wanted to report back after coding today.
The code is great! I love everything about it EXCEPT now I'm finding the hill assist hinders more than it helps. Case in point, there's a stop sign at the top of a fairly steep hill that I've driven on at least a million times and I never have trouble with it. Immediately after coding I took the route that lead me to that stop sign and I stalled out twice in a row from a standing stop. I felt that the hill assist just really didn't want to release and required a heavier throttle application along with more clutch feathering than usual to overcome on the third try. Now I'm wondering if I can code out the hill assist too as I really don't need it. It was novel before but now I feel like it's fighting me instead with coding auto rev match off. Otherwise the code sequence is fantastic and feels like DSC fully off in regards to no rev-hang and auto rev match off. A return to a more "natural" state with the exception of still having traction control as a safety net*. *Traction: cannot confirm this yet because I really did not hoon the thing after coding. I'm just assuming traction control is still active based on my road impressions. |
Capt Canuck704.00 thegrinchboy62.00 |
09-06-2021, 10:23 AM | #24 | |
Rep 19
09-09-2021, 04:58 PM | #25 | |
Rep 837
Anyone recall what the factory setting was? I was so excited with the code I didn't think I would need to go back to stock so I didn't note the original settings. I need to make it a habit to save settings before coding... Current settings with rev match off and clutch+brake to start: TCM_Startlock_Brake - aktiv TCM_Startlock_Clutch - nicht_aktiv TCM_Startlock_Drivingreadiness - nicht_aktiv |
02-27-2023, 08:01 PM | #26 |
Rep 4
Just coded out rev matching using these steps in my 2020. Old thread, but wanted to add a vote of confidence for anyone checking it out. Hill assist works fine. The only thing different for me was that I found "TCM_Startlock_Drivingreadiness" was already set to "nicht_aktiv"
03-01-2023, 03:32 PM | #27 |
Rep 8,970
You don't have to heel and toe to rev match, to be honest that's for the track or really hard driving / very late braking.
Just drive normal I.e get your braking done before the corner, off the brake, quick throttle blip and down shift and turn in, easy no need to heel and toe. I turned of rev match with Bm3 map, but yes can do with bimmercode as mentioned. |
jefe2000740.50 |
03-02-2023, 09:01 PM | #28 |
Rep 147
I just saw this thread. So today I turned off DSC to get rid of rev match. Holy cow! The car shifts so much better getting into first or second. NO stuttering or rough shifts. I am now very disappointed that rev match works as shitty as it does for the first 2 gears. It does work perfect for 3rd gear and up.
Brandt51889.00 |
03-03-2023, 01:48 AM | #29 | |
Rep 8,970
With it on you can pull away gently with no throttle input, ie creeping in traffic, with it off you'll stall if you try that. You can check it easy: engine running, in 1st gear, stationary, flat surface, brakes off, clutch down. Gently release clutch to the biting point, do not touch gas, if the idle raises about 300rpm then its still working, if not then it's disabled and you will need to adjust your right foot accordingly... |
03-04-2023, 09:47 AM | #30 |
Rep 51
I’ve been thinking about doing this since I got my M2C in 2021. I have a veepak, but I’m nervous about glitches. Is there a way to revert back to stock configurations if I make changes?
03-05-2023, 07:32 PM | #31 |
Rep 4
I had the same worry. If i understood it correctly, bimmercode records all the settings before you make an update, and then you can revert back to this save in the future. But I can't speak to how effective it is because i haven't used the feature yet
03-07-2023, 12:59 PM | #32 | |
TeQuiero
85
Rep 424
^^ correct Bimmercode makes a backup when you start the app, so if things fail, you can revert. However, do look up instructions on how to do that though. I'm just paraphrasing off of what I learned... I've done this and have been driving my car for 3 months with no issues.
Pull the hand brake on a hill and slowly release it while also releasing the clutch in first gear. It'll teach your muscle memory on clutch engagement point better as well.
~ Feel blessed for all the goodness that's come my way! ~
03-07-2023, 02:33 PM | #33 | |
Rep 8,970
Even if the hill start assist won't let you do it old skool with the handbrake as it keeps the footbrake on until the clutch comes up Anti stall isn't for hill starts though its just to help bad 6MT drivers pull away from a stop I remember other attempts by owners in the past at removing rev match with coding resulted in all clutch pedal sensor base features being disabled including hill start, one push start, anti stall etc. Sounds like this method might work though... |
Moflow2484.50 |
03-07-2023, 02:39 PM | #34 | |
TeQuiero
85
Rep 424
Correct anti stall isn't affected. I can stay rolling in 1st gear without giving it throttle and it will not stall.
03-14-2023, 12:12 PM | #35 | |
Rep 4
03-14-2023, 03:22 PM | #36 |
Rep 8,970
Anti stall is one of those pointless gimmicks that manufacturers think we need when we don't.
But when you learn a car with it on, then if it goes away it can just catch you out until your right foot/brain adjusts. |
04-27-2023, 11:31 AM | #37 |
Rep 2
Came here to say thank you for the solution for the rev-matching "problem"! I just bought 2018 LCI M2 and rev-matching was the first item on the chopping block. I can report that this solution still works in 2023!
I haven't tested hill assist, but the car seems to be operating just fine after this fix. One interesting detail that wasn't mentioned in this thread before: after disabling rev-matching I tried to start the engine with my foot on the brake, but with clutch released (you shouldn't do this, I was just experimenting) - the engine didn't start and the iDrive gave me an error of "warning: engine start failure" or something like this. On the one hand, this is great, as I don't want my engine to start without the clutch pressed in. On the other hand, it gave me a minor heart attack when I first saw this warning, so just be advised. As for the people who profess love/hate for rev-matching: to each their own. It's a matter of personal preference and neither of the options is objectively better than the alternative. One thing you may want to consider though is the learning curve/feedback loop. My previous car was a naturally aspirated manual Japanese vehicle. I consider myself fully proficient with manuals, but I'm still in the process of getting used to this BMW manual, as both the clutch engagement zone and power delivery are different from my previous car. Rev-matching hindered this learning process as I didn't have the feedback loop - I couldn't tell if my shift was spot-on or crappy, because rev-matching masked my mistakes. This is not a good thing as mistakes are an important part of the learning process. I'm glad that now I can suck more, so that I can suck less in the future. |
IcewaterPete2146.50 |
11-24-2023, 05:08 PM | #38 |
Rep 5
Hi, I have just disabled rev matching on my 16´ F31 330i today using bimmercode app. All was fine!
My car has 147.000 kms and CDV drilled. By the moment, I have not noticed any collateral damage like increased RPM with gear engaged or hill assist dissabled. The only thing i have noticed is that you dont have trottle asistant while starting, but for me it´s not a problem. Tomorrow i´ll have a track day. I hope i can gear up faster than before. Many thanks for all! |
