11-29-2018, 06:05 PM | #1 |
Rep 22
Bimmercode BMW M2
Hi guys,
Anyone knows if we can use the Bimmercode to keep the exhaust flap open? I got the adapter from Amazon, and there is a 20% discount with the coupon code! pretty good. http://bimmercodeapp.com/adapter/ So here are what I did for the M2. 1. Disabled auto-rev match. -> (https://f87.bimmerpost.com/forums/sh....php?t=1418405) 2. Enable iD6 light 3. Disabled the Active Sound ... (Finally!! Driving on highway with sport mode was a nightmare before with that fake sound...). P.S., the software update on BMW website seems down. Anyone by any chance got a copy of the .bin from the website for BMW M2 2017? BMW doesn't wanna to release it anymore somehow...? And asking me to go to the DEALER... And auto-rev match really messed up my driving style now finally I'm controlling my car completely. Isn't that the whole point of manual driving? Nights and days... |
11-29-2018, 06:19 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
Only the separate bimmerlink app would give you exhaust flap control but it would NOT memorize your valve setting and keep it in the position you last left it in. It would default back to the OEM setting every time you shut the engine off. You'd have to reconnect to the app every single time you got into the car which would be super inconvenient and in my opinion isn't worth doing. A better solution would be to either buy a proper valve controller or pull 2 fuses from your fuse box. The fuses would leave it open or shut with no control and the controller would allow you to adjust it as you please with ease.
More info on fuses here: https://f87.bimmerpost.com/forums/sh....php?t=1558468 Good valve controller here: https://www.cgprecision.com/#!/VSC-1...egory=19726366 |
NYC Bimmer259.50 SeanWRT3179.00 |
11-29-2018, 08:05 PM | #3 | |
Rep 22
$$ SAVER... You are awesome... I was about to buy those apps and wonder if they are gonna be a pain to manage!
What should I do with the BMW Software Update however? I wanna update it myself and BMW seems to going for dealer only route now. OH YOU GOT the same car too good one bro. What's your version and is it even worth upgrading? Quote:
11-29-2018, 08:45 PM | #4 | |
Rep 4,551
istep updates I have no idea how to do myself. I just told the dealer my connected apps were super laggy and asked for a free update which they gave me "on good will". They said they next one would cost me $145 or whatever their hourly rate is. I've only done that one update about a year ago and the only noticeable change was that when you take the car out of reverse the rear PDC will stop beeping in neutral. Other than that not much seemed to change. Some people claim they experience large changes like different steering feel and a change in ASD or exhaust noise but who knows if it's true or just a placebo. I personally won't be getting anymore istep updates because I've done a ton of coding to my car and added some special things like M4GTS EPS/MDM and VLD which required me to use a program called ESYS which was a big pain in the ass to download and figure out how to use so I don't want to get my istep updated again solely because It wipes your car clean of any coding and reverts it back to all factory settings, and frankly I don't feel like having to redo everything. |
Poochie9104.50 |
11-29-2018, 09:48 PM | #5 | ||
Luxury at the redline :)
9105
Rep 7,563
I wanted a software update also but I'm scared that when the dealer updates the ECU, it will revert to the stock settings and stuff like the LCI tail light swap or the cluster will show a error message, confirming I "tampered" with it.. When I had my 135i which didn't have LED angel rings, I put some white PIAA bulbs in it.. When the dealer realized that I had a different bulb, while working on an unrelated blown HID ballast, they tried to blame the error on my choice of aftermarket bulb and wanted to charge me $600 for the repair.. Long story longer, if you have mods that had had required you changing the original coding parameters, I would play it safe and not update the software by the dealer.. At least until your warranty has expired.. Or else it will highlight your changes.. |
11-30-2018, 07:16 PM | #7 | |
Rep 22
Good point. If I revert back with bimmercode, would they be able to find out I mod the car?
And this is the ISTEP update you mean? The one we use USB? https://www.bmw.com/en/footer/software-updates.html Quote:
11-30-2018, 07:49 PM | #8 | ||
9105
Rep 7,563
I was referring to a full dealer ISTEP update of all the modules that's sometimes available.. If you revert the parameters back to how it originally came, they wouldn't detect anything.. But then you would have deal with putting back on any original parts that came with the vehicle, before you take it in for a software refresh or else the dash will light up like a Christmas tree with error lights when they re-power the car, after the re-flash.. Too much hassle for me just so achieve some minor changes in the new update. Software don't go stale; they just improve it when the engineers feels it's warranted or add revised features/parts.. |
11-30-2018, 10:41 PM | #9 |
BMW Fanaddict
65
Rep 76
I use this device from Burger Tuning
http://www.burgertuning.com/f_series...odule_BMW.html You can set the valve for always open/always closed or stock. A little pricier than the CG Precision device, but I do like the BMS products - have a JB4 tuner box as well (not installed at the moment, had it on my previous 435i/F33) And the Bimmercode App is an EXCELLENT piece of software - I have many things coded on mine as well, including ASD off. You all mentioned the map updates - I assume you're referring to Navi maps, correct? I've been using Google Maps through Car Play - this works really well and FREE! Did your cars come with Apple Car Play in '16 and '17? Not sure when this was introduced to our cars... |
///M TOWN16566.50 |
12-03-2018, 03:20 PM | #10 | |
Rep 22
Oh! I got the software update finally. So apparently they update everything except for the Multimedia function? And yea the car updates the map automatically.
Anyone experiencing lags for the carplay + google map? It's so slow that I always miss the highway exits . Quote:
12-04-2018, 02:50 AM | #11 | |
Rep 553
12-04-2018, 08:47 AM | #12 | |
Rep 4,551
If you read this entire thread from the top of the page it explains the how and why pretty well: https://f87.bimmerpost.com/forums/sh...3#post23951103 |
12-04-2018, 09:31 AM | #14 |
Rep 4,551
I'm my experience, no, dealers don't code cars for customers. Some might even consider it a breach of warranty. Just buy bimmercode or an ASD delete harness and take care of it yourself. Most dealers aren't mod friendly.
12-05-2018, 05:38 AM | #15 | |
Rep 553
12-05-2018, 05:51 AM | #16 | ||
9105
Rep 7,563
So the valve is always open, except when you're coasting in Comfort or Eco Mode.. BMW also drastically quiet down ASD, so now people could barely distinguish if its on/off now.. Andrew is correct, the valve control only actively suppresses the sound only when plugged into the OBD port, in real time.. After you disconnect it, it goes back to factory mapping, whatever they might be for your vehicle.. Bimmerlink engineers already confirmed this. Email them from the APP and they'll reiterate it.. |
AndrewC198910931.00 |
12-05-2018, 12:50 PM | #17 |
Occasionally frequent poster
3000
Rep 2,744
Current inventory:
12-06-2018, 11:25 PM | #18 | |
Rep 553
Re ASD, yes in comfort there isn't much difference but in Sport+ ASD is loud & intrusive when you put the engine under load, there's no mistaking ASD being on or off. Muting ASD via Bimmerlink is definitely saved without having to re-connect the app on start-up. |
12-06-2018, 11:40 PM | #20 | ||
9105
Rep 7,563
You have to keep the device plugged in for ASD and valve control to retain. The car forgets the settings and goes back to default when unplugged and off. I understand you're skeptical of my claim, so once again I suggest your contact Bimmerlink to verify this. If you want ASD to be permanently off, you need to change the parameters with Bimmercode. That's the only way it memorizes your settings. You can't permanently change the exhaust valve behavior by coding. You need a flash tune for that.. |
12-06-2018, 11:46 PM | #21 | |
9105
Rep 7,563
I like having the latest stuff too but I used iDrive 6 in a loaner car and I really didn't think it was much of a difference from 5. |
12-06-2018, 11:50 PM | #22 |
Rep 4,551
Personally I prefer it to the id5 layout. If you don't like it you can always switch back. Not like you're signing a 30 year mortgage or anything, lol.
Poochie9104.50 |
