06-02-2020, 06:58 AM | #67 | |
Rep 85
Tyres are racing wets 265/645/18 so pretty much the same as a 265/35/18 I had to go 9.5 on the front too. Some coilvers with a shorter spring design can give more room. The MCS kit is bad as the spring gets bigger but mostly its down to running a lot of camber. |
gphung193.50 |
06-02-2020, 07:02 AM | #68 |
Rep 85
265/35/18 & 275/35/18 Nankang AR1
Untitled by M2 ClubSport, on Flickr Protrack One wheels from Hack Engineering 18x9.5 et25 & 18x10.5 et 40 Untitled by M2 ClubSport, on Flickr Untitled by M2 ClubSport, on Flickr Chucked a 3mm spacer on the front to give me that little bit extra clearance. Since pictured above I've had a geo to my desired specs and ceramic coated the wheels, will be putting them back on this evening and going to try out my 10mm spacers all round as gained room with added camber. Bedford GT this Saturday, lets hope I can remember how to drive on circuit. |
4
06-02-2020, 01:43 PM | #69 | |
Rep 267
I'm a total nob when it comes to tire/wheel fitment but I have a MG M2 as well and this is the exact set up I would want. Is this the wheel set you have..... https://www.turnermotorsport.com/p-5...d-set-of-four/ why does it say it doesn't fit ours? Do these wheels require spacers? appreciate any help. Thanks |
06-02-2020, 03:07 PM | #70 | |
Rep 89
Well they don't say it doesn't fit our MG M2 or LCI ;D they say it fits on M3/4 because the wheel originally came with the M3 and M4. It was the standard wheel for m3/4 and the m437 was the optional 19" wheel. but in my opinion most of the m3/4 buyers upgraded to the m437 19" wheel and therefore the m513 are quite rare to see on a m3/4 and if the buyers took the m513 18" wheel they upgraded after a while to some bigger tires nowadays the m513 wheel is popular for track set ups or people who want oem quality and a light racy looking wheel it has the exact same width and offset like the m437 and therefore fits (after my knowledge) all BMW OG M2s and LCIs without spacers, not on M2c with bigger brake kit though ... I hope this was helpfull EDIT: the price seems quite high, here in germany you can get a used set for arround 1000€, maybe you can get a cheaper used one from craiglist or somewhere else |
06-02-2020, 04:33 PM | #71 | |
Rep 267
06-03-2020, 02:26 AM | #73 | ||
Rep 4,516
Current '22 X3M LCI.. |
H20neun114.00 BallHog5873174.50 |
06-03-2020, 02:58 AM | #74 |
Rep 89
BallHog5873174.50 |
07-25-2020, 11:22 AM | #76 | |
Rep 468
How have you found it? |
07-25-2020, 11:33 AM | #77 |
Rep 1,263
Fine so far. Will be tracking in a couple weeks. Probably will put some 11" rims on the rear if needed.
