05-01-2019, 11:06 AM | #222 |
Rep 538
Has anyone from the US gotten the new update or been locked out? It's sounds like this might be for OPF cars only... Is there a way to see if the update is across the board internationally?
05-01-2019, 11:08 AM | #223 | |
Rep 159
That being said, some USA dealers have applied the update anyway, so it's probably best to talk with your dealership prior to taking the car in and understand clearly what they will/won't do. |
05-01-2019, 01:49 PM | #224 |
Rep 8,972
There are US guys on here who have had the update and been locked out yes.
But there is no requirement to ever take your car to BMW for servicing, so no requirement to have any updates unless..... The term "recall" means you will be written to by BMW and asked to take it in. Some recalls being compulsory others voluntary. This is neither, and seems to be just a regular update that will be done at next visit to BMW. No one has requested that I must take my car in, so it will not be going anywhere near BMW. |
Proctor750426.00 |
05-01-2019, 04:23 PM | #225 | |
Rep 538
I also believe if something catastrophic were to happen under warranty and you don't have service history that might not go into your favor. The s55 does have some pricey replacement parts.. |
05-01-2019, 07:13 PM | #226 |
Rep 227
Having taken delivery of my m2c this week and not having the latest update, I'm going to have to decide whether to specifically tell the dealer not to do any updates (and risk alerting them to the fact that there is one) vs staying quiet when I take it in for the 2k km service..
05-02-2019, 11:58 AM | #227 |
Rep 562
Has anyone tried to use a USB to OBD cable instead of the Ethernet to OBD? I have a surface pro that has no Ethernet port and would rather not deal with an adapter.
05-02-2019, 12:45 PM | #228 |
1287
Rep 1,675
05-02-2019, 02:21 PM | #229 |
Rep 8,972
afaik you need ENET OBD as you need TCPIP link.
Ethernet adaptors are easy and cheap. I have slim non enet laptops and they all came with micro enet adaptors. |
05-02-2019, 09:32 PM | #231 |
24083
Rep 190,612
Shoutout to PTF team, i was having issues with online coding and they were very fast to take care of the problem although it was not caused by BM3 (i accidentally deleted coding file )
05-05-2019, 10:47 AM | #232 |
Rep 1,297
If ODB flashing is no longer available after the BMW software update, would it still be possible to send the ECU to the PTF folks so that they can unlock it?
05-06-2019, 11:40 AM | #233 |
Rep 77
Saw that the GTS transmission flash was updated to v3.0, tried to flash today and it was successful but within 5 minutes of driving all gear indicators disappeared and I was unable to manually shift.
05-06-2019, 12:59 PM | #234 |
Rep 3
05-06-2019, 03:49 PM | #235 |
Rep 107
I tried the GTS TCU tune on my M2C and love the gear changes.
The display does dissappear and only works in manual mode (Can live with this). LC does not work below 3000 rpm and starts off at 3500 rpm. Last settings are never retained and whenever I use LC I need to drop the rpm. |
05-06-2019, 04:48 PM | #236 |
Rep 1,297
Does anybody know which map has more average power and more top end?
Stage 1 with 20% boost reduction (on all gears) or the CS+ map? Thanks in advance! |
05-06-2019, 08:29 PM | #237 | |
Rep 3,659
Drives: 981 Cayman GTS
05-07-2019, 04:21 AM | #238 | ||
Rep 1,297
If the Stage 1 map with 20% boost reduction can give me more power throughout the RPM range as well as more top end than the CS+ map (but without all torque spikes) then it may be the best of both worlds for me. Just trying to understand how these two maps would measure up to each other. |
05-07-2019, 07:30 AM | #239 |
Rep 231
running C's+ with 20/10 reductions. the 10% in second pit down power better than stock.
Did a track session in 3rd (no reduction) and had no issues with traction. Next I plan to load stage 2 91 with 30/20/10/10/10/10 then remove some reduction once I have more tire/downpipe/crank bolt capture. stage one would be fine put the torque by gear should make it controllable |
Proctor750426.00 |
05-08-2019, 01:43 AM | #240 |
Rep 479
Drives: CB E46 and SG E92 M3s
This thread is ridicules. A stage 2 m2c is completely controllable. Its not like this thing is going rip your head off with tune. If your that worried then why bother? Its still slow asf on the top end.
Commanderwiggin2048.00 |
05-08-2019, 06:53 AM | #241 |
Rep 97
Will pick up my new M2 Comp in a few hours and will try connect it to BM3 Agent and see what happens.
Just hope they won't update anything with the break-in service |
05-08-2019, 10:34 AM | #242 |
Rep 1,043
Congratulations on your new Car, let us know how it goes.
19 Audi RS5
15 Audi S5 GIAC Stage 2 white 11 E92 335is DCT FBO 441 whp silver 08 E92 335i FBO 6MT 427 whp space grey 05 E46 M3 red |
Tags |
bm3, bootmod3, m2 competition |
