07-14-2022, 07:10 PM | #199 |
3888
Rep 54,535
Drives: F80 M3
Part #: 13.01.10046
Brand: Essex & AP Racing Complete front Essex Designed AP Racing Radi-CAL Competition Brake Kit for the F80 M3 F82 M4 F87 M2: Saves 24 lbs. of unsprung weight vs. the OEM M2 Competition front brake package! Fits inside popular 18" track wheels Features AP Racing CP9668 Radi-CAL Pro5000R six piston calipers 372x34mm, 84 vane AP Racing disc Saves roughly 8 unsprung lbs. from the nose vs. the standard OEM iron brake package Every component designed to resist the heat of extended track sessions Pistons sized properly to allow for seamless integration with OEM master cylinder and ABS system Designed to work with OEM rear brakes or our Essex/AP Racing rear BBK 9668/372- F80 M3 F82 M4 F87 M2 & M2 Competition WHAT'S IN THE BOX? One pair AP Racing CP9668 Radi-CAL Pro5000R six piston calipers One pair 372x34mm AP Racing CP6084, 84 vane, J Hook racing discs, with fully floating 6061 hard anodized aluminum hats, and attachment hardware One pair caliper mounting brackets and hardware One pair Spiegler Stainless Steel Brake Lines with abrasion resistant coating Detailed installation instructions Brake pads are NOT included with our system. Racing brake pads are a highly personal choice. Many manufacturers include a set of inexpensive, low quality pads with their brake kits. Rather than artificially inflating the price of our system with a set of pads you probably don't want anyway, we've decided to remove the cost from our system and allow our customers to choose the pads that best suit their needs/wants. When purchasing our kit, you are able to choose one set of front pads at a substantial discount vs. the retail price. Please use the drop-down menu to select your pads. Advantages Over OEM Brake System Our CP9668/372mm Radi-CAL Competition Brake Kit offers our customers the following advantages over the OEM brake system: Approximately 8 lbs. of unsprung weight reduction vs. the OEM standard front iron brake package AP Racing Radi-CAL calipers are the stiffest, lightest, and most technologically advanced calipers available at any price CP9668 calipers use a 25mm thick, commonly available brake pad shape Ventilated, domed back, stainless steel pistons keep heat out of the brake fluid and provide an ultra-firm pedal Mitigation of pad knockback via anti-knockback springs behind the caliper pistons Anodized caliper finish that is resistant to wear and deterioration at elevated temperatures Stainless steel caliper hardware for a long caliper service life under frequent pad change conditions High temperature, low drag seals that will hold up to track temps= less rebuilding and longer service life No dust boots to burn up Simple pad change with two bolts or quick-change spring clip, no caliper removal required Lifetime professional caliper rebuilding support by Essex (at a fee)- pull off your calipers, send them to us, we clean, inspect, and rebuild them Available disc burnishing service ensures that your kit arrives ready to be installed and driven hard immediately Championship winning, 84 vane, fully floating, AP Racing J Hook racing discs with 12 attachment points to hat Anti-knockback/anti-rattle disc attachment hardware Replacement iron disc rings available at an extremely competitive replacement price Disc metallurgy specifically designed to handle the temps typically seen on track offer a long service life Highest quality, Spiegler stainless steel brake line with clear sheath that reduces compliance over OEM rubber design |
09-12-2022, 04:00 PM | #206 |
3888
Rep 54,535
Drives: F80 M3
