01-21-2020, 10:41 PM | #1 |
Rep 149
Short Commute and Break-in
I've read quite a bit about what to do during the break-in period (up to 1200 miles), but wanted to get some more practical advice for those of us with a short commute during this time. Not so much about how to get to the higher mileage faster (that's simply solved through longer drives off commute), but rather the style of driving recommended in a short commute (around 10 miles) that is non-highway miles/side/back roads (albeit major paved roads). Things like, will the car really ever get warmed up fully in that short of a drive? Is it not good for it to barely get warmed up and then shut off? Should it be driven somewhat hard (mine will be MT) during that short drive (if up to temp), but within the limits of the break-in requirements?
Thoughts? |
01-22-2020, 01:41 AM | #2 |
Rep 1,823
Drive it hard, stay is lower gears. My commute is about 5 miles, car gets warmed up but part of my commute is the Autobahn so within these 5 miles I’ll sometimes hit 150mph for a mile or so.
Break it in hard and fast, and it will last. |
01-22-2020, 06:13 AM | #3 | |
Rep 149
Most of the roads I'll be on will be 45 mph or less with one small stretch of 60 mph. Seems like my main concern is going to be not getting a speeding ticket. |
01-22-2020, 07:54 AM | #5 | |
Rep 88
01-22-2020, 09:58 AM | #6 | |
Rep 843
That's what you're supposed to do. Who am I to argue with M engineers? |
01-22-2020, 10:09 AM | #7 | |
Rep 4,047
I also believe in not babying the car during breakin, and no I dont mean abuse (stay withing guidelines), but certainly push it routinely to the within breakin specs |
Moflow2484.50 |
01-22-2020, 10:11 AM | #8 |
Rep 744
Lots of ways to break in the car, personally I dont believe in the hard and fast rule. Having said that you should increase the load on the engine as you put on the miles. To the point you do some medium hard accelerations. This helps seat the rings.
Also tons of topics on this already (hint a search function exists!) You should also know it takes 8-10 miles to get the car and (DCT)trans up to temp.
ChrisK4449.00 |
01-22-2020, 10:57 AM | #9 |
Rep 3,842
The hard and fast rule is up to the owner. I wouldn't do the hard and fast rule on a new engine when the oil is not hot though. That can take almost 10 minutes.
01-22-2020, 11:53 AM | #10 |
Rep 4,047
01-22-2020, 12:12 PM | #11 |
Rep 3,842
01-22-2020, 12:22 PM | #12 | |
Rep 4,047
That is definitely not hard and fast, but its definitely not babying the car either. |
01-22-2020, 12:27 PM | #13 | |
Rep 149
Out of curiosity, how long does it typically take you to get to the oil temp mentioned above in those modes? My concern with the short commute at lower speeds is by the time it gets up to temp, I can't do much at the higher RPM end (below 5500 obviously at first) or drive it in a variable load kind of way; and that I'll just be getting to work as it's time to do that. Good comments/thoughts by all and it's appreciated. |
01-22-2020, 12:41 PM | #14 | |
Rep 4,047
01-22-2020, 01:55 PM | #15 | |
Rep 1,823
At least this is my tried and true philosophy based on a sample size of 4, and one car eating oil from the dealer lot, and stopping after this break in. I also track my car, so I think breaking it into conditions it will encounter during it's intended use is best. But this is not to say my is the only way. 90 million cars are broken in world wide each year. I just like my method best. Besides, BMW tells you many things. Always obey posted speed limits Only use BMW oil and fluids Oil changes every 25000 km or 2 years are ok, but will cost you an arm and a leg M2CS is worth almost $90k 60 weight oil is ok for winter use on low clearance V8 M3 Some make sense and some don't. Have to make our own choices sometimes.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 01-22-2020 at 02:36 PM.. |
01-22-2020, 03:59 PM | #16 |
this is the way
18137
Rep 8,518
The break-in period is not primarily for the engine, it's for the entire drivetrain as well. That's why they specifically layout in the owner's manual not to use launch control during break-in. It's a new car and the entire powertrain's moving parts need to "bed in" properly. Use common sense, as the car warms up you can rev it higher, but don't exceed the 5,500 rpm during break-in, etc. If you accidentally go over 5,500 rpm, it's not a big deal. Even after the 1,200 break-in you shouldn't go WOT right away. Slowly ease into it over the next few hundred miles. Once the pain of break-in is over you can beat the snot out of your car with peace of mind it's been broken in properly.
infinitekidM2C4206.50 MMMBRAP975.50 |
01-22-2020, 04:07 PM | #17 | |
Rep 4,047
Tag18137.00 |
01-22-2020, 04:13 PM | #18 | |
this is the way
18137
Rep 8,518
Think of your new car as a baby, it's still learning about itself. After break-in the car is now a teen and ready to go. But, being its parent you don't want it to hurt itself. So you gently ease it into learning it's abilities until it's time for it to get out there and be somebody! |
01-22-2020, 04:39 PM | #19 | |
Rep 4,047
01-22-2020, 06:54 PM | #20 |
Rep 3,842
I break my cars in by using my motorcycle engine method. Bring the car up to operating temp, there is a guage on the dash for oil temperature.
If you live near mountains, take it through the hilly twisties, going up through the gears and down through the gears. Then you'll have positive pressure to make heat going up and negative drag on the engine going down. This way the engine, rear end, transmission and brakes all get a fair workout. This subject has been beaten to death. I can say that neither of my BMWs that I bought new have burned a drop of oil. |
natmad667.00 |
01-23-2020, 07:00 AM | #21 |
Rep 7,594
Drives: '19 M2C
I have followed the owners manual break-in on 11 BMW's. Never had a problem.
Let it warm up, and drive. Don't beat on it before it warms up or while in break in. it's a complex and expensive piece of engineering.
www.ReTuneTheDeTune.com
Tag18137.00 |
01-23-2020, 07:37 AM | #22 | |
Rep 744
Your 1st paragraph is 100% correct and what you should do. Personally I think taking it to 7k+ rpm is too much and I stuck under 5k rpm. I have no oil consumption and power seems to be good (just as fast as my friends S55 cars). People talk a lot about RPMs but that is only half the story. 7k RPM with no/little load is less harmful than full accel at 1.5k RPM up a hill. The load on the engine is critical. You can use the sport display gauges to know how much TQ/load you are applying. I would and did not do 100% TQ before the break in service. But I did increase it as the KMs were put on so went from max 20% load to max 80% load. 5.0 Monster if you ever plan to cross the border and try out Assen or Zandvoort let me know as I would love to meet up.
5.M0NSTER3353.50 |
