BIMMERPOST Universal Forums > Off-Topic Discussions Board > Let's See Your House Projects!
      04-21-2021, 08:42 AM   #1145
Patrick303
Patrick303's Avatar
Drives: F36 440i GC
Originally Posted by The J-Man View Post
I like that granite, what’s it called? Or is it quartz?
It's quartzite, named Platino.
2024 Porsche Taycan 4S
2017 Ducati Monster 821
      04-21-2021, 12:44 PM   #1146
lakefront
Drives: 2017 Macan GTS
Originally Posted by Mosaud1998 View Post
Helped my pops install 2 out of 6 underground downspouts and pop-up drains.
We didn't use PVC pipes we used flexible plastic pipes.
When we got the house built in 2015, the builders just added the downspouts in the front of the house where the landscaping was done.
So every time it rained, the landscaping would get all messed up including the mulch.
We brought a drain spout extension a few months after moving in to extend the downspout to the driveway.
Friday morning, we noticed the sidewalk leading to the front door was sinking because of the drain sput extension. So, we rushed to Menards and brought some material to install the drain spout underground with the pop-up drains.
I wonder if the builders will come to fix the sidewalk since it started to sink because of them technically.
Looks like this:
This looks like a great idea, but what about winter? If its buried at a shallow depth, won't it freeze?
vreihen1615280.00
      04-21-2021, 01:59 PM   #1147
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
Huh, didn't think about this
      04-21-2021, 02:47 PM   #1148
Alfisti
Drives: 2008 Saab 9-3 Combi
We went from old school granite to a very reputable brand of man made quartz and the granite absolutely SHITS all over it. Granite is far less likely to stain and is far harder, wife already chipped the quartz.
Buug95917420.00
vreihen1615280.00
Mosaud19983940.50
      04-21-2021, 09:53 PM   #1149
ShopVac
Not willing to take advice
ShopVac's Avatar
Drives: F82 M4 - 6MT
I think you're backwards in this...quartz is way harder than granite and doesn't chip?
If you're having chipping issues, staining, or can't set a hot pan on it...you don't have quartz.
      04-22-2021, 06:33 AM   #1150
RickFLM4
RickFLM4's Avatar
Drives: M4
Agree that quartz is harder and nonporous so less likely to stain, but granite is more heat tolerant. You don’t want to place a hot pan directly on quartz.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      04-22-2021, 07:41 AM   #1151
Alfisti
Sorry I thought you meant the man made stuff not real quartz.
      04-22-2021, 07:53 AM   #1152
cmyx6go
cmyx6go's Avatar
15763
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Found this online.
The biggest difference between quartz and quartzite is that quartz is a man-made material, while quartzite is a natural stone. A quartzite countertop begins as sandstone, which under a natural process of heat and pressure is fused with sparkly quartz crystals to form quartzite.
Quartzite typically comes in shades of white or light grey, but minerals in the stone can lend pink, gold, or reddish-brown hues.
A quartz countertop is engineered with the same quartz crystals found in quartzite, but a man-made process binds the crystal with resins, pigments, and other materials such as bits of glass. This process results in a very durable, non-porous countertop material that comes in a wide variety of colors and designs.
Aside from the different composition of these two materials, the stylistic differences are quite striking as well. Quartzite is often mistaken for marble or granite, as it has the delicate veining of marble and similar coloration and patterning to some granites. Those seeking a natural look with lots of movement may prefer a quartzite countertop. Quartz on the other hand, can be made to look like any stone, and is offered in many different shades and patterns. If you have a specific color in mind, or want a consistent pattern throughout your slab, a quartz countertop is probably a better bet for your home.
Another big difference between quartz and quartzite is the care routine and durability of each material. The binding process makes quartz extremely durable as it helps to extract air, making quartz a hard surface that is non-porous, and therefore resistant to chipping, scratching, and bacteria.
Quartzite is a fairly hard stone, but it's less dense than quartz and susceptible to easily staining in a heavy use area such as the kitchen. Quartzite requires sealing to prevent staining the surface, while quartz needs virtually no maintenance.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
Appreciate 6
Buug95917420.00
vreihen1615280.00
King Rudi13154.00
RickFLM410981.00
      04-22-2021, 12:33 PM   #1153
DETRoadster
Space Force - 4 Star General
DETRoadster's Avatar
11463
Drives: M2 MG 6MT / Moto Guzzi V7
Anyone else here stunned by the costs of raw materials, especially lumber? I'm constructing a small "shed" to store and season split firewood. Making it mostly out of cedar, repurposed from a fence I tore down. I need a couple of 2x6 for the rafters and some plywood for the roof sheathing. 2x6 cedar is $11 a linear foot and 1/2" doug fir ply is $60 a sheet! WFT?! Guess I'm using pressure treated 2x6 and OSB chipboard for the roof. Sheesh.
King Rudi13154.00
jmack548.50
Buug95917420.00
      04-22-2021, 01:16 PM   #1154
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
Here! You know what I do for a living. Make shit happen at as low of a cost as possible. Tough to do when OSB is $40 a damn sheet.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
DETRoadster11462.50
Buug95917420.00
      04-22-2021, 01:26 PM   #1155
MPOWER5266
Drives: 1997 Dinan m3
Got a new roof and chimney cap this week, its a start.
Untitled by Nick Wood, on Flickr
Appreciate 6
cmyx6go15762.50
King Rudi13154.00
Buug95917420.00
jmack548.50
      04-22-2021, 01:29 PM   #1156
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
There was a story on our local TV news this week about wood shortages from the COVID construction and home improvement project boom adding $25K to the cost of new houses these days. If memory serves me correctly, the demand for lumber was up 70% and pushing the prices up.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
DETRoadster11462.50
Buug95917420.00
      04-22-2021, 01:37 PM   #1157
unluky
unluky's Avatar
7528
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
Appreciate 9
MPOWER52664753.00
DETRoadster11462.50
King Rudi13154.00
RickFLM410981.00
S1nner126.00
jmack548.50
      04-22-2021, 03:39 PM   #1158
ToddBlack88
ToddBlack88's Avatar
595
Drives: 2007 Z4MC 2010 F650GS
I just replaced a 55’ section of fence that the wind blew down, and it cost me 2x as much as the 110’ section I replaced 8 years ago.
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab,
King Rudi13154.00
DETRoadster11462.50
      04-22-2021, 04:13 PM   #1159
Buug959
Buug959's Avatar
Ukraine
17420
Drives: 335xi E90, GMC Sierra, VW Golf
Yup, a 2x4-8' spruce is $8.10 right now! A year a half ago they were $2.90. I don't know how people are building homes with the price of materials so high but they are. There are whole subdivisions going up all over the place.
Wha' da ya mean? No brakes never stopped anyone before!
DETRoadster11462.50
      04-22-2021, 06:04 PM   #1160
DETRoadster
11463
I don't get it either. My wife and I just bought a 1/2 acre to build a house on and are seriously considering just sitting on it for a year or two to see if costs stabilize. Of course the risk is that interest rates spike and we end up screwed either way.
      04-22-2021, 06:38 PM   #1161
Buug959
Buug959's Avatar
Ukraine
17420
The plus side is that you have the land. Something to consider though happened to me years ago. I bought a large lot, about 4.5 acres, and sat on it for a few years before building. The problem I ran into was nobody wanted to give me a mortgage because I owned the land outright. They didn't want to be holding a mortgage without claim to the land the house was sitting on. You might want to check into that with your lender of choice just so you know where you stand.
      04-22-2021, 07:11 PM   #1162
DETRoadster
11463
Interesting. I wonder if that's a Canadian thing? The lender we are working with for the construction loan actually prefers that we paid cash for the land as that will take the place of 20% cash down for the construction loan. They put a lien on the property during construction, I guess, to cover themselves in case we default before the house is built. Once construction is complete the loan automatically converts to a 30 year fixed mortgage. We lock in the mortgage rate at the time the construction starts which is awesome as it takes away the worry about interest rates spiking during the 6 to 8 months of construction.
Buug95917420.00
      04-22-2021, 07:17 PM   #1163
Buug959
Buug959's Avatar
Ukraine
17420
Things may have changed here since then. It was probably about '88-'89 when I ran into this. Since then I've just bought existing houses and then renovated to get what I wanted.
      04-22-2021, 07:29 PM   #1164
DETRoadster
11463
Oh, OK, yeah that's totally what it is. Most of the banks now who do construction and property loans make it pretty easy to roll from one into the other. They want to keep the business in-house afterall.
Our lender is just wrapping up a refi for us on our primary mortgage + the HELOC we used to help buy the land. They will roll that all up into a new mortgage at a low rate, then when the time is right do the construction loan and the mortgage on the new house. By keeping it all in-house they make more money and we save as they are able to extend better rates and lower closing costs as they have more of our business.
Buug95917420.00
      04-22-2021, 07:40 PM   #1165
Buug959
Buug959's Avatar
Ukraine
17420
Cool. Now all you need is for the price of materials to come back down to earth and a set of plans for your dream home. Good luck with your build, whenever it happens.
      04-22-2021, 08:12 PM   #1166
unluky
unluky's Avatar
7528
lol3
Appreciate 7
Buug95917420.00
vreihen1615280.00
DETRoadster11462.50
ramman434712.00
Kilabyte3948.00
