03-10-2023, 03:09 PM | #1 |
Rep 23
Exhaust recommendation needed
Background:
I have a CS that is my daily (because I really like driving it). It currently wears the stock exhaust. I want to replace the exhaust for two reasons. One, it looks horrible. Two, it doesn’t sound great, but you know that. I am OK with more volume, but not with fart-can sound or drone. I plan to use the stock valve operation. I do not plan to make any meaningful engine mods. I do not plan to replace the stock downpipes. Question: What is the current “best” setup given these constraints? Thanks in advance! |
03-10-2023, 05:33 PM | #2 |
Rep 4,672
Unfortunately "best" is subjective. I think you can get a nice sound in a wide range of prices and audio clips don't do a good job of capturing the sound. I think The Dinan back box with an AE midpipe sounds real good. I would advise getting a midpipe. I've got an Akra system because I wanted weight loss and a good deal landed. I think the Akra is quieter than some others. Valves open is the right amount of obnoxious for me. It's pretty loud. Pops and crackles are there that we're not heard with the factory system.
Edit: I'd shop the for sale section and get a good deal on a previously loved system. Likely an upgrade over stock at a reasonable price. |
03-10-2023, 05:36 PM | #3 |
In the garage
390
Rep 211
IMO, the best affordable solution:
Active Autowerks Equal Length Midpipes (resonated) (link) Active Autowerks valved rear axle back exhaust (link) Xtreme Power House (x-ph) typically offers a 10% discount and during certain sales, you get store credit (dependent on purchase amount) for your purchases, so you could potentially separate into 2 orders to use said store credit on your 2nd order. No tuning/modifications required. YouTube has a plethora of videos showcasing the sound. That being said, Akrapovic has rave reviews and is used by many on these forums, but I think you end up spending a bit more. Good luck!
BMW M2CS 6MT
IG/TikTok: jd_m2d2 |
03-10-2023, 07:36 PM | #4 |
Rep 23
I’m a big fan of Akra from my motorcycle days, but I know their stuff is not cheap. I know Akra used to make a midpipe, but it seems to have discontinued in the US?
Is the AA EL (resonated) the consensus midpipe these days? Any thoughts on Eisenmann? I know they are big on the Porsche front. |
03-10-2023, 09:46 PM | #5 |
In the garage
390
Rep 211
The big debate from what I researched when making my exhaust purchase decision is AA EL vs AA (regular/single) mid pipe. As far as mid pipes go, I would say AA is the most popular for the F8X, not to say there aren't other great options of course. The biggest difference between the 2 AA mid pipe options is desired sound, with the EL sounding more "exotic" and less like a weed trimmer (as some put it) and the regular/single mid pipe sounding throatier and more characteristic of the S55. I'm summarizing, but there are lots of posts bimmerpost around this topic that could be helpful.
https://f80.bimmerpost.com/forums/sh....php?t=1770293 https://f87.bimmerpost.com/forums/sh....php?t=1803442
BMW M2CS 6MT
03-11-2023, 08:47 AM | #6 |
Rep 23
Good summary, thanks!
It seems the AA EL resonated is the most common/popular approach and yields a good balance. Is it fair to say that from there, the axle back is largely personal preference? Akra being most spendy and maybe a little quieter, others having various pros and cons? |
03-11-2023, 08:57 AM | #7 |
Rep 4,672
I would not get the Akra axelback alone. My opinion is that it needs to be paired with a midpipe. Otherwise you might end up with spendy disappointment. Don't get me wrong you'll get visual improvement and weight savings but the sound will be a little lower than you might want
Factory CS has a great tone. It's just too quiet until really on the throttle. I'd like to see someone cut open the back box and remove some sound deadening to see if that improved things. I've always said an AA mid with the factory back box would be a great combo. Unfortunately you still have the udder. But if udder doesn't bother you that would be a cost effective mod Seriously though, don't sleep on the Dinan back box. |
03-11-2023, 04:18 PM | #8 |
Rep 312
“ I would not get the Akra axelback alone. My opinion is that it needs to be paired with a midpipe. Otherwise you might end up with spendy disappointment. Don't get me wrong you'll get visual improvement and weight savings but the sound will be a little lower than you might want”
I beg to differ with above re: Akra alone being a disappointment or quiet. It is only quiet when valves are closed or set on auto, but plenty loud with valves open. For reference, my prior ride was an OG M2 with full Remus Sport exhaust. The Akra back box alone is loud enough with valves open to set off alarms at startup in a parking garage. I have it paired with an OBD port valve controller that memorizes last valve setting. I drive with valves open all the time and I love the sound. It has a nice growl at low rpm, is plenty loud, and has a good overall tone, to my ear at least. It also saves significant weight vs stock backbox. Disadvantages of this setup are: you have to be ok with cutting stock exhaust and there is a bit of a drone if you hang around 3k rpm, but it disappears above and below 3k. Nothing obnoxious though. If you want real bang for the buck before you commit to an exhaust, just buy a valve controller ($250) and keep valves always open on stock exhaust. It actually sounds good this way but lower volume than Akra. |
03-11-2023, 04:28 PM | #9 |
Rep 2,203
Drives: G81 M3 Touring (Frozen Black)
I’m very happy with my Akra catback with stock midpipe. This is after trying the AA EL midpipe and swapping it out. The drone was horrendous for me. I also had an install issue and there was a horrible fume odor that caught up with us at every set of lights.
I’ve kept my OEM exhaust and mid pipe intact and can swap them back to stock if I ever want to part out, though not expecting to. The final outcome is brilliant high RPM sound with a signature titanium shriek at redline. Down low it’s a deeper thrum (vs the OEM’s breathless rattle) that is very satisfying. And the tips and exhaust box look great imo. Last edited by Jimjamz; 03-11-2023 at 08:07 PM.. |
03-11-2023, 04:39 PM | #10 | |
Rep 23
Did you have the resonated pipe, or non-res? |
03-11-2023, 06:39 PM | #11 |
Rep 2,353
I will share my experience. Just as you mentioned the back box had to go, it is really the only thing aesthetically wrong with the F87 M2c/cs.
My first set up was Dinan cat back with x pipe. There was no drone, sounded nice and was inexpensive, however the quality of the system was not what I wanted for my cs. The tips were very large and it did not tuck 100% out of sight. I was fortunate enough to meet up with a local forum member with the AA non res EL mid pipe and Remus valved exhaust. This set up was definitely slightly more aggressive than I wanted. I suspected that it would be perfect with the resonated version. The remus tips are much nicer (carbon) than the Dinan tips, but still too large for me. I decided on the AA resonated EL with Eisenmann valved and it is a really clean sound with OEM like quality. It also is completely tucked and the tips are perfect. I love it! The Eisenmann took a while after I placed my order and was $1K more than the Dinan and Active boxes. Still much cheaper than the Akra.
BSM ///M2cs, 6spd
romes4rs81.00 |
03-11-2023, 08:05 PM | #12 |
Rep 2,203
03-11-2023, 10:31 PM | #13 |
Rep 287
I think the only consensus is one of the AA midpipes, beyond that it's very subjective. I agree the Single is throaty. I've got an AA Single Resonated paired to a Remus Race, very deep and quite loud. I use a valve controller to keep it closed when I'm not looking for total street shock and awe. Great sound, but with the stock valve actuation, it could be a bit much.
03-12-2023, 09:48 AM | #15 | |
Rep 23
Thanks for the detailed explanation!
Your solution seems to match my needs/wants quite well. I am familiar with the quality of Eisenmann from my Porsche days. Definitely a quality product. Did you consider the standard carbon tips? It seems they have two options (not counting the crazy gold version below). I don’t think I could justify them, but those carbon/gold tips look sharp. But $2700 for tips? Quote:
03-12-2023, 12:21 PM | #16 | |
Rep 2,353
BSM ///M2cs, 6spd
03-12-2023, 12:33 PM | #17 |
Rep 4,672
I was reading a post where the gold color gets dirty and you can't really tell it's gold anymore. That would be disappointing. One more thing beyond brake dust to worry about.
03-12-2023, 12:40 PM | #18 |
Rep 79
I’ve tried pairing the Akrapovic exhaust with the AA EL mid pipe, resonated and non-resonated. In my opinion, the resonated mid pipe had a worse drone at low rpms. If I had to do it, I would stick with the non resonated version.
Luckily for me, I was able to source an Akrapovic mid pipe which sounded the best. Some used ones will pop up in the classifieds once in a while. |
03-12-2023, 12:41 PM | #19 |
Rep 23
03-12-2023, 12:43 PM | #20 | |
Rep 23
Brake dust was probably 60% of the reason I went with CCB on mine. |
03-12-2023, 12:48 PM | #21 | |
Rep 23
I understand they used to make a pipe that is no longer imported to the US? It also seems they have another system, the Evolution? But I readily admit to being garbage with Akra model names. Last edited by transalpian; 03-12-2023 at 12:58 PM.. |
03-12-2023, 01:05 PM | #22 | |
Rep 79
Akrapovic
The Akrapovic muffler is still available to purchase. The midpipe is not. The only way to get it is from the secondary market. |
