10-31-2022, 08:44 PM | #45 |
The Seeker
13863
Rep 3,325
The one that came with my Suvneer hood isn't as nice. No problem, they are only $204.
10-31-2022, 09:07 PM | #46 |
Rep 278
Paddleshifterz was incredible to deal with and was very responsive. Wouldn't hesitate to order from "Szab" (Szabolcs Sztányi - owner of paddleshifterz) again. The new piece is definitely solid and looks great!
2020 M2 CS - Misano Blue, DCT, CCB
10-31-2022, 09:21 PM | #47 | |
Rep 367
https://www.ecstuning.com/b-genuine-...d/41618081166/ Yup, that's where I ordered it from. Says it's on backorder for a few days though. Understandable. |
///MPhatic13862.50 |
11-01-2022, 08:22 AM | #48 | |
The Seeker
13863
Rep 3,325
11-01-2022, 12:59 PM | #49 |
Rep 278
I was told my Paddleshifterz that the opening in the aftermarket hoods does not align perfectly with the factory or aftermarket carbon vent. Might be worth checking into that more, but sounds like it wouldn't necessarily fit?
11-01-2022, 01:53 PM | #50 |
The Seeker
13863
Rep 3,325
Suvneer told me straight that it would, and I'll raise 9 kinds of hell if it doesn't.
11-01-2022, 02:26 PM | #51 | |
2432
Rep 11,667
Many thanks for jumping in on this. looking forward to your fitment results
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
11-01-2022, 02:49 PM | #52 | |
Rep 278
[IMG]https://3a663eb0fef48c6d2d60-a88f8eb...1889_x600.webp[/IMG] Mine is much more square on the corners.
mtoosexy730.00 |
11-01-2022, 02:51 PM | #53 | |
The Seeker
13863
Rep 3,325
This is the correct M3/M4 GTS vent that should be identical to mine. |
///MPECABL582.50 |
11-01-2022, 02:53 PM | #54 | |
Rep 278
[IMG]http://www.nvdautosport.com/carbon/f...t-grille-3.jpg[/IMG] [IMG]http://www.nvdautosport.com/carbon/f...t-grille-2.jpg[/IMG]
11-02-2022, 11:35 AM | #55 |
In the garage
390
Rep 211
Still waiting on my piece from NVD. I can only hope it looks as good as the Paddleshifterz and Faserschmiede versions. Thanks for the pictures everyone!
to_riffic3023.50 ///MPECABL582.50 |
11-17-2022, 03:55 PM | #57 | |
Rep 367
JD_M2D2390.00 |
11-18-2022, 06:33 PM | #59 | |
Rep 278
JD_M2D2390.00 |
11-18-2022, 07:17 PM | #60 |
In the garage
390
Rep 211
That's awesome. Thanks man. I did finally hear back from NVD today and the unit is set to ship next week. I can only hope at this point it fits perfectly! If this doesn't work out, Paddleshifterz for sure!
///MPECABL582.50 |
12-06-2022, 08:53 PM | #62 |
Rep 367
Paddleshifterz comes through! Beautiful piece. They definitely got that tab alignment issue worked out and it matches well.
Interesting part about the 3M double-sided tape... I was hesitant to use it at first, but the clips loosen from the hood too easily and the piece comes off. Then, tried to use the tape. It was still was coming off too easily (probably because they were only slivers of tape all around the piece). I remembered that I had some 3M adhesive promoter. The hood is PPF'd so I decided to use it and if I ever decide to switch back and the tape doesn't come off, the PPF can always be redone. After using the adhesive promoter, the piece was solid. No way that's flying off on the road now. Also, one side effect of this piece that I didn't think of until after the install was that the clearcoat was real nice. Definitely doesn't scratch up as easily as the OEM piece. I feel like a strand of hair could scratch the OEM hood vent. |
JD_M2D2390.00 |
12-13-2022, 11:53 AM | #64 | |
In the garage
390
Rep 211
I received my carbon fiber hood vent from NVD Auto. As far as I can tell, this is a "skinned" factory part. It does in fact appear to be real carbon fiber, so I'm happy about that, versus hydrodipping. Normally, I might be a little annoyed by this, but given some of the fitment topics discussed here, re: 3m adhesive, I'm OK with the OEM mounting.
Update from manufacturer: Quote:
mtoosexy730.00 |
12-13-2022, 08:35 PM | #66 |
Rep 367
It looks like NVD still did a good job. The wet-layering looks clean and the weave is consistent. Thank goodness it's not hydrodipped. Haha... I can only think of the frustration and anger that would be coming up if it was advertised carbon fiber and you get carbon fiber-like, especially after what you went through.
Let us know if the fitment is good though. Sometimes, even with an OEM part, if they lay too much epoxy, that can hinder fitment. Or, if it's not done properly, the CF can start to separate from the OEM piece. But, yea, if it's done well, should be just fine! |
JD_M2D2390.00 |
