03-24-2021, 12:54 PM | #111 |
3528
Rep 6,752
The 18x10 ET25s can also be run as a square setup on this chassis. They eliminate the need for a spacer up front but make fitment in the rear more difficult. We generally recommend running at least -2 degrees of camber in the rear with these wheels although the camber requirement will vary depending on the model and size of the rear tires and the ride height of the car. Significant negative camber is still required up front as well.
Either square option is viable, but the 18x10 ET33 is in my opinion slightly more flexible which is why I recommend it more often. For those looking for an aggressive spacer-free setup, the 18x10 ET25s can certainly work, but they are not a direct fit. -Tom
mcvaughan704.00 |
03-27-2021, 11:36 PM | #112 | |
Rep 92
I was contemplating trying to get the 18x10.5 et27s to fit. By my maths, that should be close in the rear without doing fender mods and should require less mods in front? I’m trying to build for a class with a max rim width of 11” and tires of 295. I can roll fenders but that’s it.
2011.5 E92 M3 - Gone but not forgotten
2018 F87 M2 - The new hotness |
Rundskop148.00 |
03-29-2021, 12:32 PM | #113 | |
3528
Rep 6,752
With enough time and some massaging, you could probably make the 18x10.5 ET27s work but you are moving the fitment problem from the front of the car to the rear rather than eliminating it entirely with the ET27 wheels. -Tom
Rundskop148.00 |
03-30-2021, 09:56 PM | #114 | |
Rep 92
Oh well, I definitely appreciate your help and insight. You've saved me some cash from unnecessary experimentation.
Expert@ApexWheels3527.50 |
04-06-2021, 06:49 PM | #115 |
3528
Rep 6,752
The APEX FL-5 really suits the lines of the M2, especially with a meaty track tire.
APEX Wheel Fitment Specs:
04-07-2021, 11:57 AM | #116 |
Rep 3,842
19" M2 Comp compatible please.
04-23-2021, 08:12 AM | #117 |
Rep 436
EC-7
MovingChicane109.50 Rundskop148.00 |
04-24-2021, 05:01 PM | #118 |
Been there and back...
110
Rep 142
04-26-2021, 02:13 PM | #120 | |
3528
Rep 6,752
If you do not have the larger 2NH brake package on your M2, you can run the following FL-5 setup as a direct fit: Front: 18x9.5" ET28 with 265/35-18 tires Rear: 18x10.5" ET40 with 285/35-18 tires -Won't fit M2 Competition with 2NH brake package. -Available in ARC-8R, EC-7R, and FL-5 designs. -Front negative camber may be required. -5mm front spacers or larger may be required with certain aftermarket suspensions, see below. -Front 275/35-18 tires can also fit with additional negative camber. -Rear 295/35-18 tires can also fit. -Rear 305/35-18 tires can fit with aggressive negative camber and/or rolled/pulled fenders when using aggressive tire compounds. With a 18x9.5" ET28 front and a 18x10.5" ET40 rear, you can run 265/35-18 front and 285/35-18 rear tires as a mostly direct fit. As long as you are using street focused tire compounds, you can typically get away with the stock camber settings up front. However, with track tires that tend to run a bit wider than their sizing suggests, front camber plates will typically be required for a rub-free fitment. If you have any additional questions, please do not hesitate to reach out! -Geirsen
04-27-2021, 05:14 AM | #121 | |
Rep 4
Great thanks ! I'm indeed looking the put some track focused tires. Will I have the same problem with FL-5 18x9 ET30 with 245/40-18 tires ? |
04-27-2021, 11:31 AM | #123 | |
3528
Rep 6,752
Just as a heads-up, most track-focused tire compounds are designed to work with increased negative camber. With stock M2 front camber settings, you will chew through the outer shoulders of just about any track-focused tire. Increased front negative camber is highly recommended not just from a fitment perspective, but also for performance and tire longevity, as well. With that being said, the 18x9" ET30 FL-5 can work with a 245/40-18 as a direct fit. However, that wheel size is typically our winter wheel setup recommendation for the M2. The 18x9.5" ET28 is a much better fit for a track application. -Geirsen
rwemersonrw535.00 |
04-27-2021, 03:05 PM | #124 | |
Rep 4
04-27-2021, 07:23 PM | #126 |
6637
Rep 4,145
Drives: '18 M2 6MT
05-03-2021, 12:07 AM | #127 |
Rep 118
Expert@ApexRaceParts Do you guys have any pics of a Comp (2NH) running the new SM-10s yet?
Also are your delivery timelines relatively accurate, I know with COVID some things get thrown off but based on the site its looking like mid-May for EC-7s and June for SM-10s? |
05-04-2021, 03:22 PM | #128 | |
3528
Rep 6,752
We don't have any on-car pictures of the new 19" M2C spec SM-10 wheels quite yet. However, we should start to get plenty once orders begin to ship out. ETA-wise, that is correct. We are expecting new inventory for the EC-7s around mid-May and around mid-June for the SM-10s. Please let me know if you have any additional questions! -Geirsen
05-12-2021, 12:40 PM | #130 | |
3528
Rep 6,752
Thanks! -Tom
aftercorbu404.50 |
05-20-2021, 06:30 PM | #131 |
3528
Rep 6,752
Jacob's BMW F87M2 with 18" FL-5 wheels in Satin Black Finish.
Spider.75.50 |
05-21-2021, 04:18 AM | #132 |
eric
25
Rep 28
