BIMMERPOST Universal Forums >
General BMW News and Cars Discussion >
BMW Revving by Itself When Cold
| 02-06-2025, 08:19 AM | #1 |
Rep 3
My BMW has been revving by itself when cold. (n47)
I recently scanned for codes and found only A6CF (AUC sensor malfunction), which controls the recirculation flap when detecting air pollution. Could this be related to the revving issue ? |
| 02-06-2025, 08:52 AM | #3 |
Rep 3
| 02-06-2025, 09:26 AM | #4 |
![]() ![]() ![]() ![]() 2085
Rep 649
So," surging" at idle. I'd assume the AUC sensor is faulty and disrupting the air/fuel mixture. Or there is an air leak into your intake (unmetered air). The AUC sensor is usually mounted somewhere near/under the air box.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
| 02-06-2025, 11:10 AM | #5 |
Rep 2,588
What DrVenture said.
I'll add FWIW (and probably not much) is I had a car (Boxster) out of the blue manifest a varying cold idle condition. Idle RPMs would go up then down. Not by much but clearly not idling as it had before. Long story short the cause proved to be an air/oil separator that had failed (at around 80K miles). Which reminds me this same car at around 250K miles after a normal 30 mile drive to work when I pulled in to park the engine idle (hot idle this time) started going up and down. By a considerable amount. The RPMs would go low enough I felt the engine was about to die. I used a handy OBD2 code reader and found a pending code pointing to the variable valve timing system. In the shop the dealer tech diagnosed the problem as a failed variable camshaft solenoid/actuator. After their replacement engine was fine. I drove it another 60K+ miles before I sold the car. |
| Bookmarks |
| Thread Tools | |
