11-22-2024, 04:45 AM | #1 |
![]() 27
Rep 54
Debunking BMW star tires vs regular non OE tires. Are we silently damaging our xDrive?
Hi folks!
I ve been searching alot on this topic weather you should pick OE tires for your BMW model or regular non OE tires. Interstingly i ve not yet found any conclusion on this matter if you should run OEM tires to avoid any potential xDrive issues or run normal non OEM tires because of the better price & comfort being non runflat. Nobody gives an clear answer why you should pick one over the other technically. Theoretically BMW approved tires have the same rolling circumference, being created specifically to meet the stringent low RC tolerances of xDrive. Yesterday i found something very interesting. I compared two brand new tires one Pirelli Sottozero 3 (star marked) runflat and a regular Michelin Pilot Sport 4s non runflat of the same size, load rating and speed rating. 245/45/20 103V In the photos attatched you can see the OE tire is slightly taller than the non OE one even if it has 0.5 mm less thread than the non OE tires. (8 for MPS4S and 7.5 for Pirelli) I ve seen many people post around that if you mount tires based on the readings on the B pillar specs you are totally fine as long as it matches the exact tire size, load & speed ratings. But the question is, are they acutally the same? Obviously it seems they are not. Are we exposing ourselves to transfer case/xdrive issues? i dont know. Maybe we dont see an immediate effect on the drivetrain but maybe it stresses it s componets running non approved tires. Making this post is not because i am an advocate of OEM tires but because i wanna see what othets think about this matter. |
11-22-2024, 06:24 AM | #2 |
![]() ![]() ![]() ![]() 408
Rep 469
I’m not sure I understand your point, since actual measurement size differences between brands is common. It only seems significant if you plan to mount two different brands or types of tires on your car at the same time.
BMW wants all the tires to match diameters within about 2.0-2.5mm to keep the xDrive happy and not cause issues. If all the tires on the car are all the same brand, type and measured size, the actual diameter may be larger or smaller than OEM and it will not hurt the xDrive. |
tracer bullet4350.50 Kilabyte4033.00 wilbur_the_goose378.00 ShocknAwe3719.50 omasou2147.50 StradaRedlands7152.00 |
11-22-2024, 06:29 AM | #3 |
![]() 120
Rep 125
Long-time track and autocross driver here - so I've done a decent about of tire-related research over the years. You won't risk hurting xDrive unless you put on mis-matched tires, like different brands front and rear (unless they came staggered in size from the factory - but even then, I'd never put on a different brand or type of tire on one axle).
xDrive wants to see similar circumference on all wheels. I rotate my wheels every 10K to even out the wear (using a simple front-to-rear swap, not the more complicated front-crossover method that requires all four wheels off the ground). Often, OE tires are some of the worst available when you look at Tire Rack ratings. My X5 came with Bridgestone Alenza Sport A/S tires, which are rated #32 out of 54 for my tire's type and size. I definitely won't be getting these tires again, although admittedly I personally have no complaints with them so far. The priority of the X5 is comfort, so the tire requirements aren't very stringent. Those Michelin PS4S tires are awesome summer tires. I've had those on several of my "fun" cars, and may go back to them in the future. Right now I'm running Cup2's on my fun car. Great tires when they get heat in them (like at the track), but for the street, the PS4S is a much better all-around tire. I just wouldn't recommend the PS4S tire (or ANY summer tire) once the temps drop below 40F. In light snow or freezing rain, they are comically ineffective as tires! When I was much younger and naive, I thought I'd be OK on summer tires in the winter if I just drove extra slow. All it took was a couple flurries to prove that theory wrong! |
4
11-22-2024, 06:33 AM | #4 |
![]() ![]() 101
Rep 314
True! I think the problem was with non star tyres having softer side wall which causes significant flattening of the diameter during extreme accelerations....leading to enormous stress of the transfer box. I also believe the earlier xdrive models were more prone to failure since almost every piece failed eventualy. Havent heard of such failures on newer models lately....
11-22-2024, 07:50 AM | #5 |
![]() ![]() 2138
Rep 1,977
What I gathered with my 230ix (and I assume the same is true of my M8) is using the BMW sanctioned (identified by the Star on the sidewall) tires of the size called for by BMW ensured the tire diameters would have the same wheel rotation speeds between the front and back tires.
I think no more than 1% was the allowable difference. But one has to be careful. When I asked at my local dealer was told 1% but when I pressed for something in black and white there was nothing forthcoming. Rather I was told the tech when the car was in for tires would look up what tires were suitable for the car and fit those tires. If you find non BMW sanctioned tires (that don't have the Star) you must still be sure the tire sizes agree with what BMW calls for and also ensure tire diameters do not differ by more than what is permissible, assuming you get accurate info on this metric from BMW directly. But even if you get the right diameter tires there is a risk the tires could prove to be subpar in terms of handling/braking/road feel/etc. I've driven my other German sports cars hundreds of thousands of miles always fitted with factory sanctioned tires of the proper size -- the cars had staggered wheels/tires and one had an AWD system -- and regardless of the brand (Pirelli/Michelin or Continental/Bridgestone) -- I could not tell the difference between the tires. Road feel, handling, tire life, all were the same. Oh there's more. This manufacturer did not sanction mixing brands of tires even if the tires were sanctioned. IOWs, I could not run Pirelli on the front axle and Michelin on the rear axle. And even with the same brand of tires all the tires had to be of the same generation. The generations were labeled "N0", "N1", and so on. No mixing -- even on an axle basis -- of different generations of tires. I have not put enough miles on my BMWs to have to replace tires yet but when the time comes I'll stick with BMW sanctioned (Star) tires. |
11-22-2024, 08:05 AM | #6 |
![]() ![]() ![]() ![]() ![]() 1074
Rep 930
Drives: '25 M240xi
1% is literally a rumor that is pervasive on this forum and the internet in general.
There is no hard and fast rule documented anywhere, and frankly it's unlikely that BMW or anyone actually knows since testing these types of things is highly impractical and near impossible. Try your best to keep front and back tire diameters the same. If they are not the same you may see an issue or you may not. It does seem that 1% or less is safe. End of discussion, nobody can say ANYTHING more conclusively.
2025 M240i Xdrive TNM - Eisenmann Exhaust - Dinan Springs - CF Goodies - More in process...
Kilabyte4033.00 |
11-22-2024, 08:11 AM | #7 |
![]() 763
Rep 291
11-22-2024, 08:22 AM | #8 |
Rep 930
Drives: '25 M240xi
Just gotta get a bench mark down so that when the inevitable "wild speculation and fear mongering" posts follow they can be rebuked.
reallymarkedup763.00 |
11-22-2024, 08:47 AM | #9 | |
![]() 27
Rep 54
11-22-2024, 08:58 AM | #10 | |
![]() 3560
Rep 3,063
Drives: 2020 M4 ZCP / 2023 X3 M40i
https://g20.bimmerpost.com/forums/sh...19&postcount=4 |
11-22-2024, 09:10 AM | #11 | |
Rep 930
Drives: '25 M240xi
I would argue that this is regarding the use of old and new tires together and a CYA to force customers to buy new tires.
SpeedOften82.00 SirKazik0.00 |
11-22-2024, 09:16 AM | #12 |
![]() ![]() ![]() 11727
Rep 7,244
Drives: 2018 M2 AW DCT
This is a very funny discussion. Lots of people have changed from runflats to non runflats with no problems on their all wheel drive BMWs. My brother-in-law has run Michelin CrossClimate SUVs on his X5 for the last 50K miles with no problems. Obviously they are not star spec but they are the same size as stock tires.
wilbur_the_goose378.00 |
11-22-2024, 09:49 AM | #13 |
![]() 87
Rep 62
Drives: 2021 M440i X-Drive
Tyre Reviews did a non BMW Star PS4S vs BMW Star PS4S.
His opinion is the BMW OEM tires work better. No mention of Xdrive though since the car used for the test was an M |
Westside Guy7789.00 |
11-23-2024, 03:11 PM | #15 |
![]() 2483
Rep 3,022
This is ridiculous. The star tires are just their way of getting you to buy “special tires” that are ridiculously high priced and wear out fast.
It’s akin to when a dealer says only they should change your oil and no one else. There is zero difference between star tires and normal non-star tires…..at least not one that you or I will ever notice.
2025 X7 40i, 2024 I7 60i, 2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
wilbur_the_goose378.00 M5Rick73666.50 |
11-23-2024, 03:35 PM | #16 | |
![]() 27
Rep 54
BMW star marked tires are mostly "star marked" because they are approved in rolling circumference (same RC all four)but of course there are some other star marked tires that use different rubber compound like Michelin Pilot Sport 4S |
11-23-2024, 03:48 PM | #17 | |
![]() 763
Rep 291
I also have to disagree that this is anything like having your oil changed by the dealership (or being told you need to). There's a video earlier in this thread showing the difference between the two tires and you're not beholden to buying them directly from BMW either as third party vendors obviously carry them. |
11-23-2024, 04:58 PM | #18 |
![]() 116
Rep 79
At least in X5s I get the sense that transfer cases are failing all over the place. Lawyers are collecting cases for class action law suit. Mine just failed. I have been on star spec OEM pirellis though so I don't think tires are the cause.
Frankly if BMW transfer cases can't withstand slight variation front to rear, that is a design flaw. Other manufacturers of AWD vehicles do not need special tires etc. to keep their transfer cases from failing. |
11-23-2024, 05:22 PM | #19 | |
![]() 27
Rep 54
11-23-2024, 05:23 PM | #20 |
Rep 930
Drives: '25 M240xi
Did he stutter? It is writen clearly and explicitly.
11-23-2024, 06:01 PM | #22 |
![]() 116
Rep 79
Yes I had the initial set of star spec pirellis from the factory and then replaced them with the same OEM star spec when they were worn. I do have the 21inch staggered setup, so the rears wear a bit quicker and can't be rotated. But not sure that's relevant. Apparently BMW claims it used the wrong transfer case fluid during manufacturing. Maybe this is accurate but they are failing in other years too. Seems like a design flaw to me. Again, loads of AWD cars these days from other manufacturers that don't seem to have this issue.
FWIW BMW uses non star spec Continentals at all the M school cars driven on the track (including the X-Drive M5). They then go on to sell the school cars as CPO. So clearly even BMW doesn't think star spec is crucial. Last edited by user12464; 11-23-2024 at 06:26 PM.. |
