01-18-2022, 05:57 PM | #23 | |
Rep 7,429
Yes as large a gap as possible to promote complete combustion.
01-18-2022, 06:09 PM | #24 | |
Rep 196
PTF just cleared out my account and reset my VIN because they had to fix some DME update related lockout that was stopping me from flashing for a while, so I lost the entire history of logs that I had.. However if I remember correctly very low 13's on E mix with STFT on WOT pinned low because of either a small boost leak or Dinan intake. So if anything it's pulling because it thinks it's too rich. I throw a lean code during idle but have no problem holding 19-20 psi all day long. So it's either really small or just a vacuum leak. Hence why I haven't tried to find it (been a rough semester) Plug pics tomorrow
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
01-18-2022, 06:22 PM | #25 | |
Rep 7,429
01-18-2022, 09:13 PM | #26 |
378
Rep 348
I’m moving back to stock plugs soon. Went NGK gapped to .023 out the gate for BM3 Stage 2, but will be reverting back.
Not having any issues, but hope to smooth out cold start a bit. Thanks for all the intel. |
01-18-2022, 09:32 PM | #27 |
Rep 7,429
No problem. Imo ngks are quite expensive at $20/plug vs. $5/plug for the Bosch, so why spend more if it's not needed or beneficial. If you do need it then you need it and spend the extra money, otherwise it's just like wasting money on botique oils.
05-11-2022, 08:23 PM | #28 | |
Rep 345
TIA |
05-23-2022, 12:07 AM | #30 |
Rep 753
This is what my (2018 M2) stock plugs looked like after 26 track days, 20K miles on the odometer and 4 years of service life. I just replaced them with new OE plugs that I got off Amazon (BMW P# 12-12-0-039-634) and new Delphi coils. The latter was simply preventative and while I was in there.
[IMG]https://media.fotki.com/2v2aFz9k8xu6LVA.jpg[/IMG] [IMG]https://media.fotki.com/2v2aFz9T3xu6LVA.jpg[/IMG] [IMG]https://media.fotki.com/2v2aFz9d9xu6LVA.jpg[/IMG] |
05-23-2022, 06:39 AM | #31 | |
Rep 1,644
05-23-2022, 10:57 AM | #32 | ||
Rep 1,644
F87source7251.50 |
05-23-2022, 12:23 PM | #33 |
Rep 1,644
The only Bosch part number that is officially "recommended" for BMW #12120039634 is the 330. The 330A is not recommended by Bosch for that BMW number.
I'm not sure why BMW specs the platinum one when the copper core/iridium tip is better (ngk plug is also copper/iridium). You can get the 330 Bosch plugs for $8 a plug from the Bosch website vs $25 everywhere else. |
05-23-2022, 03:40 PM | #34 |
Rep 7,429
Yeah I was not 100% sure, I just saw them as equivalent part numbers so I thought they were interchangeable. But it turns out there are differences.
05-24-2022, 06:31 AM | #35 | |
Rep 1,644
As long as the heat range is the same the 330a Bosch or comparable ngk plug should be fine. Iridium should have better performance and higher durability than platinum. |
F87source7251.50 |
05-24-2022, 11:01 AM | #36 | |
Rep 1,644
It looks like sometime after 2019 bmw switched to ngk iridiums as OE for existing engines. Either plug type should work for pre 2019 as long as heat range is correct. |
05-26-2022, 11:59 PM | #37 | |
Rep 7,298
05-27-2022, 12:25 AM | #38 |
Rep 7,429
You probably will need to call the dealer to find that out, real oem stopped getting updated after 2019.
chris7197334.00 |
05-27-2022, 05:34 AM | #39 | ||
Rep 1,644
chris7197334.00 |
05-27-2022, 05:42 AM | #40 |
Rep 7,429
That lines up with when real oem stopped getting updated too. I wonder what is happening, and I also wonder if bmw would consider shutting down their etk, because enthusiasts use it to buy parts which directly benefits bmw. There literally is no con to it imo, it's not like a shop manual where newtis caused people to not have to rent it from bmw and thus cause a profit loss, this is literally a self serve option whereas the alternative would be harassing a dealership - either way there is no additional profit to be had when getting p/n's online vs a dealer.
05-31-2022, 03:43 PM | #41 |
Rep 4,146
I'm replacing plugs again because the NGK 97506 are garbage - what is the consensus on the 330s? Are the "a" interchangeable and worth it?
Mods: Yes.
05-31-2022, 04:18 PM | #42 | |
Rep 7,429
The Bosch plugs are pretty good - well if you don't get a bad batch. The 330a should be interchangeable with the 330 because the heat ranges are the same as judged by the Bosch part number, the only difference is material construction and the a version with the irridum copper design should be better.
05-31-2022, 06:47 PM | #43 |
Rep 7,429
Just bringing this back up, but for bosch plugs the 3rd digit is the heat range. Since they are both 5 they are the same heat range, only construction varies so they should be cross compatible without issue.
06-01-2022, 03:04 AM | #44 | |
Rep 4,146
https://f87.bimmerpost.com/forums/sh...2#post28965442 |
