04-13-2021, 11:30 AM | #23 |
Rep 6,637
I believe when you buy the pack I you get ALL the maps for the car.
04-13-2021, 12:15 PM | #24 |
#gotboost
517
Rep 861
Pay the $50 for all of the maps, its worth it
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
04-13-2021, 07:46 PM | #25 |
New BMW owner
325
Rep 843
Alright. I’m getting the whole OTS pack.
Have you guys used an iPhone to connect? Straight connect into the enet cable and iPhone’s lightning adapter right. No need for that OBD Agent (OPT 2)? Image below (from their website) seems to say otherwise.
04-13-2021, 10:47 PM | #26 |
Rep 875
Drives: ///M2
My FBO N55 made 8whp & 28wtq on a OTS ACN 91 octane BM3 map vs stock tune.
How reliable it'll be & what the logs looked like I'm not sure but that's what it put down
04-13-2021, 10:56 PM | #27 |
Rep 3,696
ENET to Lightning adapter with an iPhone works great. Faster and more stable than the wireless OBD agent.
04-13-2021, 11:03 PM | #28 |
New BMW owner
325
Rep 843
So there's NO need for that OBD Agent?
04-13-2021, 11:09 PM | #29 |
New BMW owner
325
Rep 843
Are you happy with that gain? Seems rather low (IMHO). Disclaimer: I'm a newbie. Should i be adjusting my expectation to be around this range?
My current plan now is FMIC, charge pipe, turbo inlet and high flow downpipe. I don't think that's considered (full) FBO.
04-13-2021, 11:16 PM | #31 | |
Rep 3,696
6speed_M2 also made 440+whp with the same hardware and an E50 mix with the Stg 2+ E30 OTS map. You could run your 100 octane fuel and the Stg 2+ Race Gas map and get similar results. |
04-13-2021, 11:33 PM | #32 |
Rep 875
Drives: ///M2
We've also put down 480wtq & 385whp on another 91 octane tune. It all depends on how you drive the car & your intended goals.
I'm currently on a new set up for both 91 octane & E50. As of now we're putting down 385whp & 407wtq (close to the stock tune in terms of power, stock tune FBO) 426whp & 433wtq on E50 making 400whp up to 7k rpm. We went with a "low boost" approach, or should I say a track focused approach. Something that could handle any weather & any circumstances (daily driving, canyons, track) more of a bulletproof tune if you will VS the bigger numbers from my E30+ dyno with the bm3. I wanted to keep the heat out as much as possible to avoid the extra stress on the engine. The torque kicks in at 2.5k rpm and builds until 4k instead of that initial dump from the bm3 tunes
04-13-2021, 11:36 PM | #33 |
Rep 875
Drives: ///M2
Order is as follows:
Stage 1 OTS bm3 ACN 91 Stock tune ECUtek 91 octane tune (protune) ECUtek e50 ECUtek e50 (protune)
04-18-2021, 10:40 AM | #34 |
New BMW owner
325
Rep 843
There’s an active sound on/off in BM3. Is that the same as the active sound that is pump into the speakers? Or do I really need to use bimmercode to shut that off?
04-18-2021, 11:33 AM | #35 |
The Seeker
13863
Rep 3,325
What I would like to figure out is drivability. Back when I had my STi the most powerful tune certainly wasn't the easiest to drive. Which one of these drives the most like stock?
04-18-2021, 02:13 PM | #36 | |
Rep 875
Drives: ///M2
///MPhatic13862.50 |
04-21-2021, 12:50 AM | #37 |
New BMW owner
325
Rep 843
Hi guys. Just got my activation code today and proceeded to hook my iPhone to the car. Activation went well and proceeded to downloaded the Stage-1 91 & 93 octane. Download & Flash later.
I then went to click the FLASH button. The dashboard started to have its expected display of errors but around a minute later I'm seeing ODB is not connected. Now no matter what I do it's no longer recognizing the connection. OBD DISCONNECTED (red rectangle). Problem is the car has all these errors now. &*^%#%!! What did I do wrong and what can I do to fix this? Help.
04-21-2021, 01:13 AM | #38 |
New BMW owner
325
Rep 843
I'll try and disconnect the battery's black wire in the trunk.
I'm worried to be honest.
04-21-2021, 01:28 AM | #39 |
Rep 602
Hey, looks like the adapter might've given out on you mid flash. Don't freak out. There's a flash back to stock option that should work. Do you have an obd2 to Ethernet cable and a pc?
04-21-2021, 10:17 AM | #40 |
New BMW owner
325
Rep 843
I connected my MacBook with an adapter, again ....and it worked. It connected and showed green! So I flashed it again and this time it finished doing it.
Then I plugged it back to my iPhone and it took a while then it showed green as connected again. The laptop needed to download a ODB Agent.... the iPhone doesn’t need to do that? Tomorrow morning I’m testing the car. |
04-21-2021, 01:59 PM | #41 | |
Rep 602
04-21-2021, 07:27 PM | #43 |
Rep 570
04-21-2021, 09:48 PM | #44 |
New BMW owner
325
Rep 843
I just tried the data logging function. What should I be noting on it. so many datas. I've got some knocking 0.2 & 0.4 I would assume nothing to worry about? City driving.
I went straight to Stage-1 93 internal 114F All stock. BM3 only. BTW, laptop needed internet access during the drive out.... all the time or can I log Offline?
