04-30-2022, 12:25 AM | #1 |
Rep 97
Terrible Fitment of Full AA system (with Single Midpipe)
So, I just had a full AA system installed consisting of the new valved rear axle back with their single mid pipe. It did not fit well at all... which was quite disappointing since I figured buying a full AA system would mean a nice easy clean install. Instead of mixing and matching or cutting the stock exhaust and adding just a back box.
My mechanic said its the worst fitting exhaust we've brought to him (me and my brothers have had him do lots of exhaust installs over the years). Even with the dropped F-brace he said he couldn't get the exhaust to have any clearance there (see pics), and the system was simply too long as well. Which makes me think of all those people that had melted diffusers from other AA systems... which were all with EL mid pipes from what I saw so was hoping that was part of the reason. Long story short, I will likely have to take it to another shop that can possibly heat and bend it in places and cut some length off at the connector pipes to make it fit better... very annoying considering I was hoping to avoid this type of stuff by going with a full AA system. Anyone else had similar issues in terms of fitment with AA? [IMG][url=https://flic.kr/p/2nhzymE] [IMG]Midpipe at F-Brace |
04-30-2022, 12:33 AM | #3 | |
Rep 97
Also, forgot add to original post it rattles horribly... especially on start up and sometimes acceleration obviously. |
04-30-2022, 03:36 AM | #4 |
chasebish
50
Rep 32
The rattle is probably due to the gaskets between the midpipe and downpipe being reused or not used at all. When I removed the stock exhaust from my car, they were wedged within the midpipe, so somebody installing it might not even know they were there.
CanadianComp125.00 jdubm2c169.00 |
04-30-2022, 05:43 AM | #5 |
Rep 287
This is unfortunate news, this is the exact setup I've been eyeing. Keep us posted on how AA responds to this and what you're doing to make it work. I was thinking I could do the install myself with a Quickjack, but I'm in no position to make changes on the fly.
04-30-2022, 09:04 AM | #7 | |
Rep 1,263
04-30-2022, 09:18 AM | #8 |
24305
Rep 191,021
Im surprised to hear that; it's a popular setup without any known fitment issues.
Im not sure what happened, but I recommend you contact AA for help and advice.
CanadianComp125.00 |
04-30-2022, 10:09 AM | #10 | |||
Rep 97
04-30-2022, 10:22 AM | #11 |
chasebish
50
Rep 32
You need two new exhaust gaskets for the install, part number 18307851168 - they are crush gaskets and should not be reused.
If you reuse them, the possibility for an exhaust leak and and/or rattling is high since they are one time use. If the mechanic didn't reuse them and completely omitted them, I would basically guarantee an exhaust leak and rattling as you will have metal on metal contact directly beneath the cabin. I find it unlikely that the mechanic purchased new gaskets without telling you and/or charging you for them. Luckily since the exhaust is already installed, it's easy to put new gaskets in, so it shouldn't be too much effort for the shop if you buy some new ones. |
04-30-2022, 10:22 AM | #12 | |
Rep 97
[/url]Clearance at rear [/url]Around diff [/url]Around diff etc I definitely trust my mechanic as he's done lots of exhausts for me and my brothers, pretty confident he knows what he's doing, and don't see how hard it can be... and he spent at least an hour fiddling and trying to adjust he said... |
04-30-2022, 04:10 PM | #13 | |
Rep 97
04-30-2022, 05:33 PM | #14 |
Rep 201
I installed mine. No issues.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
05-01-2022, 09:05 AM | #15 |
Rep 14
Unfortunately I had the same issue with the AA signature exhaust and 3.5" mid pipe. The tolerance is minimal because it's super tight under there.
It looks like you might need to move the 2nd mid pipe piece further forward onto the 1st piece. You also need to play around with the way that piece is rotated. Good news is AA has good customer service. It was determined that a weld was off just a bit at the front of piece 2 for me. AA eventually replaced that whole 2nd mid pipe piece and sent it to me. Also, the replacement they sent me had a different style hanger mount for the differential which was much better, made more space in that area for me to avoid it banging around there. |
05-01-2022, 04:25 PM | #16 | |
Rep 97
Thats good to hear about their customer service... hopefully they can help resolve the issues. |
05-01-2022, 08:35 PM | #17 | |
Rep 14
Yes, pretty sure we are talking about the same piece. 1st piece connects to the downpipes. 2nd piece connects to that, it's the mid section of the kit. 3rd piece is the exhaust itself. Still seems odd your exhaust is that far back though. Is the dif hanger alinged straight or does that look way off too? |
05-02-2022, 12:59 PM | #18 | |
Rep 857
05-03-2022, 03:30 AM | #19 |
chasebish
50
Rep 32
05-03-2022, 07:50 AM | #20 |
Rep 857
