08-06-2022, 04:44 PM | #1 |
Rep 244
Drives: BMW M2 Comp, M-B A220
Repair or replace bumper?
I received small dents and holes from a truck that tapped into me. Would you think this is repairable? A BMW dealership-affiliated body shop thought that this is not repairable and need to replace the whole bumper, but I feel like they might just be trying to upsell. The damage doesn’t seem to warrant a whole new bumper but also enough that I feel like I need to dk something about it.
08-07-2022, 08:43 AM | #2 |
844
Rep 1,962
It's difficult to tell how much damage has occurred to the actual material from that picture. It is probably repairable, but to get it back to looking as new might be more expensive than fitting a new one.
Try a SMART Repair specialist for an alternative quote. HTH |
08-07-2022, 03:49 PM | #3 |
Rep 602
Definitely cost it out with a really reputable body/paint shop vs. new and then having to have it painted to match completely at body lines. I suspect, that the taps and dimples could be tapped out...or filled and paint blended for less than new. Do your due diligence...sit back and compare. You find the right answer for sure. Bests on the issue.
08-07-2022, 04:05 PM | #4 |
Rep 3,806
Some body shops are still willing to repair vs. replace, while others just want to parts-change. If your bumper is replaced, I would make sure it is an OEM piece and not an aftermarket replacement. Something like that seems relatively easy to repair and seems like the only way to make the numbers work would be to use a cheap aftermarket bumper.
08-07-2022, 05:59 PM | #5 |
Rep 1,968
I had a dime size "tear" in my 135i bumper. I assumed the only option was replace, but brought it by a small *trustworthy* body shop where I could talk to the owner and they repaired/painted it for $600 or $700. It was perfect, I could not tell where it was was, paint (Space Gray) was a perfect match (not sure if they blended into rear quarter panels). I had wrongly assumed replacement was the only way I would be happy.
08-07-2022, 06:14 PM | #6 |
The Seeker
13863
Rep 3,323
The problem is that your bumper cover is polyurethane, so repair putty doesn't like to stick to it like it would metal. You can have poly grafted on, but it's cost prohibitive. If you don't want it to come back some day, replace the bumper cover. If you don't care because you're not going to own it that long, do whatever you like.
