07-28-2022, 09:40 AM | #1 |
Rep 445
PPF relief cuts?
Hey all,
I had a partial ppf done and had some questions. I understand pre cut kits have some reliefs but these seem sort of aggressive and in the most flat facing part of the bumper. It also didn't go all the way around the reflectors. I feel like the gaps around everything are just too extreme. I paid what all shops in my area are quoting for partial (800-1000). Thoughts?
Current: 2018 M2 DCT
Previous: 2011 E92 M3, 2007 E92 328xi Insta: @kmannc |
07-28-2022, 11:10 AM | #2 |
Rep 1,610
not a PPF expert and don't even have PPF in my car (apart from my mirrors and lights which I did myself, it is hard but can be quite fun to do) and I have been seeing a lot of PPF jobs since something I wanted to learn (I like to punish myself). The reliefs on the first 2 pictures don't look too bad, maybe a bit larger than I have seen though.
The one aroudn the reflector is weird, that should go all the way around the reflector. I also have noticed that the tow hook cutout is pretty crooked so maybe this is not the greatest ppf job ever. Also thats crazy cheap, 800-1000. Here I was quoted 2k for front PPF (or 1500 for half hood/fenders) but I guess thats the NY tax. |
07-28-2022, 11:13 AM | #3 | |
Rep 445
Apparently the cutout they use doesn't go around the reflector…..such is life. The more I'm looking into ppf…..the more I'd skip it. All the nuances, even on a perfect job aren't worth it to me I don't think
07-28-2022, 11:23 AM | #4 | |
Rep 1,610
But yeah there are different kinds of ppf jobs and I think its worth paying for a nicer one where they will use bulk for certain parts like the hood and will do a better job on the bumper as you can do precut that is longer so you can still wrap some edges... that is not the precut they installed on your car, its pretty asine not to have the precut go around the reflectors, never seen a precut like that, certainly isn't the XPEL or 3M pattern that they have because I have seen both. I am maybe wrong but I feel like they fucked up the install and just trimmed it that way... Hopefully someone here that has a lot of PPF experience will chime in but yeah imo that looks ass, why have a cut there when you don't have to, got to follow lines with your cuts. |
07-28-2022, 11:41 AM | #5 |
Rep 445
I agree. I'm going to ask the shop, you can see a lot of exposed paint on the fang too in the last pic. I sort of feel like for that much exposed paint I'm better off without ppf at all but maybe I'm being too picky
07-28-2022, 11:48 AM | #6 |
Rep 3,006
What you are seeing is part of the pattern the installer used to plot the PPF. The cut next to the reflector shouldn't be there. Typically the plotter cuts out the reflector, the installer "weeds" it out and they line it up the cut out.
The relief cuts and patterns are why have I have love hate relationship w/PPF. If you get a custom bulk install it will look better but depending on who did it you will still have gaps/seams. Every edge collects dirt the less the better. I've given up on PPF (except for headlight) but I don't live in a dry, rocky area. |
07-28-2022, 11:52 AM | #7 | |
Rep 445
07-28-2022, 12:04 PM | #8 |
Rep 3,006
Finally, found it, https://f87.bimmerpost.com/forums/sh...ht=recommended
The first set of pictures is what a pattern cut and bad installation looked like on my previous M2. The second set of pictures is a custom bulk cut application, which though very, very good, still had edges lift. This was the best guy I could find locally and unfortunately he moved back to CA. Last edited by omasou; 07-28-2022 at 12:10 PM.. |
07-28-2022, 12:11 PM | #9 |
Rep 445
Yeah I have all the seems in the bottom similar to the kits posted. I'm not incredibly happy with the alignment In some spots but it looks like it's the nature of our bumpers and the angles
07-28-2022, 12:13 PM | #10 |
Rep 1,610
PPF on a light colored car has to have rolled edges or you will see the dirt pretty quick and it does NOT look good, on a dark car (or in this case black) that is not a problem).
But damn on your pre-cut car it was crazy how many cuts were on there, not necessary. Bulk is definitely the way to go and with the edges lifting, it happens and its actually an easy fix, heat gun (be careful of course because they do get HOT) and just warm up the lifted edges a tad and then they will stick right back in. Just gotta do it quick before any dirt gets inside the lifted edges or it can become a problem. |
07-28-2022, 12:30 PM | #11 |
Rep 445
Reading in the post it seems the split the lower into 3 parts to aid in repairs, makes sense since they take a beating. Would only have tk replace one piece.
Im heading back next week to get the lifted edges fixed!
07-28-2022, 04:55 PM | #12 | |
Rep 445
This guys used STEK and I'm honestly fine with most of it except for the relief cuts in the middle, I think they should be more inside the curve like yours were.
07-28-2022, 05:59 PM | #13 |
your average JAMF
3101
Rep 4,094
Yikes. That looks like it was applied by some flat brim vape bro at a ghetto stereo/tint/CBD store.
'21 M2 Comp
'19 Golf R |
07-29-2022, 03:34 PM | #14 | |
Rep 445
I saw your thread where you used a pre cut I believe. Do you have pics of how the seams line up on the lower pieces?
07-30-2022, 09:21 AM | #15 |
Rep 445
Maybe not so harsh. They did my tint too and I just noticed this
07-30-2022, 10:42 AM | #17 |
Rep 1,968
I have partial PPF on my OG, and just took a look. I have the same relief cuts, but smaller. They are also less visible, I didn't think I had them until I rubbed my finger over the area.
07-30-2022, 02:54 PM | #18 |
Rep 445
Noticing some cuts from the tinter…..Same shop…..
07-30-2022, 03:59 PM | #19 |
your average JAMF
3101
Rep 4,094
I took some shots of mine, will post when I get home. I can’t even see any relief cuts. Now after seeing that tint aftermath, oh my…
07-30-2022, 05:56 PM | #20 |
Rep 445
Thank you could take some pics of that window trim. I'm sure that's not normal but I'd be curious what one looks like
07-30-2022, 06:09 PM | #21 |
Rep 1,610
Oh man yeah those cuts are bad. I hate to say this but I probably would not take my car back to that place. I certainly would not trust em with a bulk install be cause if they can’t control their x acto knife for the tint imagine around the paint. Something I always wonder with ppf, you won’t find out their fuck ups until the ppf gets removed later
07-30-2022, 07:24 PM | #22 |
your average JAMF
3101
Rep 4,094
These pics aren't great, sorry.. I can try to get some better ones. But I'm def not seeing any cuts in my window trim anywhere, and even when I look super closely at the bumper area, I don't see relief cuts..
'21 M2 Comp
'19 Golf R |
