M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > MHD ethanol content analyzer
      03-05-2021, 05:20 PM   #45
F87source
F87source's Avatar
Drives: Bmw M2
Originally Posted by imap777 View Post
I did some rough calculations and it was somewhat 300cc. Still considerable amount, but as you said, location is not as important. There will always be a delay, as fuel rail has quite of volume too. User needs to make sure he let it enough of time.
Regardless, along with FlexFuel there will be safeties (AFR target vs actual and some more). Even now, if MHD ECA is lost (sensor is disconnected, or overall unit is down), CEL will be lit, and custom MHD+ errors (MHD001 and MHD005) will be reported. On MHD001, engine goes into LIMP mode (will get user configurable anytime soon). Another option of failsafe is "jump to fixed Ethanol content", which is also user configurable. So lets say you know what your fuel is, and on the race you don't want to get into limp. So you set "jump to E40 params if ECA is offline", and you're good to go.
Is it possible to have it limp to pump gas mode but compensate for fuel trims?
      03-05-2021, 05:28 PM   #46
imap777
imap777's Avatar
18
Drives: BMW 335i
Not sure at this point, but I will check and get back with the answer.
Or do you mean have scalars good for E blends but target 1 degree of advance? That's be more like map switching to a safe map
      03-05-2021, 06:04 PM   #47
F87source
F87source's Avatar
Drives: Bmw M2
That sounds cool if you could target pump gas timing, but essentially I want the car to be able to switch to a pump gas tune but still be able to compensate for E85 that is in the tank. That way when I'm on track I don't completely limp out, and when I'm on the street and potentially am using pump gas if the ECA fails it doesn't automatically default to e85 or e40 for example if using the fixed ethanol failsafe input. I know you could always change the ethanol concentration in the failsafe but that would be inconvenient and defeat the alot of the purpose of having flexfuel which would be convince.
      03-05-2021, 06:24 PM   #48
imap777
imap777's Avatar
18
Drives: BMW 335i
That being said, you just want to drop your timing to very low levels (which you would normally target only with pump gas ) keeping scalars (and trims) relevant for E blend. Is this correct? So called, "timing limp mode"
F87source7251.50
      03-05-2021, 06:29 PM   #49
F87source
F87source's Avatar
Drives: Bmw M2
Yup correct, but drop timing and boost too, to pump gas levels. So a so called "pump gas limp mode" but keeping the scalars for E blends.
      06-23-2021, 02:03 PM   #50
imap777
imap777's Avatar
18
Drives: BMW 335i
Hello,
Big news from MHD:Glad to announce that MHD FlexFuel QuickInstall Kit is in the stock now. Along with the MHD+ platform's recent update with MapSwitch and FlexFuel support it brings in a fully automated Ethanol extrapolation. At the moment custom tunes are available (all tuners were informed on the techniques as well as provided with a mapswitch/flexfuel XDF's), while OTS maps are at the last stage of the development. 10 Minutes DIY and technical assistance at every step.
Order your kit here now!
Comment with any questions or requests you may have.
Currently tested/supported cars:
  • F3x N55 2012+
  • F1x N55 2012+
  • F0x N55 2012+
  • F15 N55 2012+
  • F25 N55 2012+
  • F22/F23 N55 2012+
  • F80/F82 S55
  • M2 N55/S55
More coming in...
Installation video manual:
F87source7251.50
      09-10-2021, 04:29 PM   #51
CharsadehBEAST
Drives: Minivan
imap777 ETA on this kit being released for other platforms? Specifically for E8X/1-series/N55's?
