M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > HELP - At Wit's End - Installing MPE issues (w/Pics)
      05-07-2018, 01:56 PM   #1
MdMcoupe
Drives: 2000 Mcoupe (blown/track toy)
Installed my MPE (thanks Sunmotor Cars for great price) and a Fabspeed sport cat this weekend.
Started the car up.....WOW it was loud....and the typical tips vibrating...lol.
BUT....for the life of me I can NOT get my valves/flaps to open via the blue tooth controller. This is where I need some help.....
I double click the the little button, and all I get is 2 quick flashes back. Which according to the instructions is "lost connection". I tried double clicking the remote while in the trunk, nothing..... I even laid on the ground next to the exhaust and double clicked the remote...I have never seen the "flaps" open on the otter pipes.
I redid the wiring 2x to double check. See wiring of fuse box below....I put the red wire in the 15 amp fuse F145, and the green wire goes to fuse F137. I used my little "pen" type voltage tester that lights up(its in the 1st pic propping up the fuse block), and I have voltage at the red wire but not the green....not sure if it's supposed to have voltage though.....
Does this look right......
I have the "flap" set properly to active, correct......
I am really hoping I overlooked something stupid. Does everything look like it should be working.... Does anyone have a wiring diagram?
I have read about people having the "flaps" close randomly after driving, BUT I can even get mine to open once...
I wanted to install this myself so I could trash that clamp, and weld the exhaust together. But now I am concerned, what if my ~$200 button is bad, or something is faulty......would a dealer warranty anything if I installed it myself?
m2ruder SeanWRT lopm2 I have followed alot of your posts/threads wondering if you guys could help....
Kinda depressing ........
      05-08-2018, 08:41 PM   #2
MdMcoupe
Not even a freaking BOO!
      05-08-2018, 08:56 PM   #3
F87_LCI
F87_LCI's Avatar
1787
Drives: 2018 LBB F87
I had the exact same issue. Unfortunately I did not fix it myself, so I can't be of much help, but the dealer (mine was port installed) fixed it in only a few minutes, saying that the connection was loose and so was the fuse. Apparently the fuses can be loose fitting, so you may wish to start there. And yes...it's f'n loud. Lol. I have FS DP as well. Cold start is ridiculous.
      05-08-2018, 09:08 PM   #4
MdMcoupe
F87, thank you!
I have put the 15 amp fuse in and out 10 times as I read that was a problem from a previous thread.
I will check the connection of the red/green wire again.
If I can't solve the issue, and for some reason I may have faulty hardware, will I have a problem replacing anything under warranty since I installed myself.
thanks again
      05-08-2018, 09:28 PM   #5
F87_LCI
F87_LCI's Avatar
1787
Honestly, I would get a new fuse, just to be sure that is not the issue and it's a cheap way to eliminate it as the potential issue.for mine it wasn't the wires that were loose, it was the connector itself...apparently the connector is a bit wonky and can seem connected but isn't quite 100%. As for warranty, can't see why they would deny a claim, but you'll need to figure out what's wrong first, lol! Good luck.
      10-03-2020, 07:46 PM   #6
FiveDirtyFive
FiveDirtyFive's Avatar
Drives: 2017 OG 6MT M2
Originally Posted by MdMcoupe View Post
F87, thank you!
thanks again
Hey, Im having a similar issue with my newly installed MPE?.Was the loose fuse the issue? Did you find the fix?
      03-03-2021, 07:48 PM   #7
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
Sorry to bring up a dead thread but does anyone know where to find extra connectors? Specifically the teal one in the top right of OP's pics.
      09-14-2021, 04:38 PM   #8
ae03440
ae03440's Avatar
240
Drives: 18' M2 & 20' X3 M40i
Did you or anyone ever get an answer on this? Looking for a part number for the green module that goes into the fuse box for the MPE valve control.
Thx
      09-22-2021, 12:50 PM   #9
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
Thx
Thx
Nope I never got it figured out on how to get one from BMW. I ended up pulling a fuse connector from my buddies totaled F30 tho...
      10-05-2021, 09:42 AM   #10
Joakim_79
Drives: BMW 230i 2018
Here is some pictures with Numbers. Bmw might be able to help
      10-05-2021, 12:17 PM   #11
ae03440
ae03440's Avatar
240
Thank you!!!
