BMW M2 Forum > BMW M2 Discussions > Sound deadening
      05-09-2018, 11:53 PM   #199
bmwv
Drives: 325i Manual, M2 LBB DCT
2017 BMW M2  [0.00]
2006 BMW 325i  [0.00]
Originally Posted by 18EM2 View Post
Good to hear (pun intended).
What do you think makes the biggest difference?
I can’t tell. I had the stuff in the front, so i just added the rest.
      05-11-2018, 12:45 PM   #200
bmwv
2017 BMW M2  [0.00]
Does anybody know where are these located on the car
SOUND INSULATION, B-PILLAR 51487336928
SOUND INSULATION, BULKHEAD, A-PILLAR 51487286078
      05-12-2018, 12:38 PM   #201
MSurge
MSurge's Avatar
84
Drives: 2019 M2 Comp/2015 AMG C63 507
Originally Posted by BMWKLR View Post
Anyone know where the sound deadening material is being removed from the on the M2 in comparison to the M235. I see there is some in my trunk on the top deck and wonder where else will it be taken from. I would like to add it back in if possible. This is up there on the intelligence level with removing the oil dipstick and space to store a spare.
Best to keep your m235i. M2 owners want LESS sound deadening, not more! And the spare adds weight, so we do NOT want the spare.
In 25 years of driving I have NEVER had a flat tire. You need a spare as much as you need a lightning rod.
      05-12-2018, 01:00 PM   #202
bobert
Drives: manual shift cars
Speak for yourself about not wanting a spare - you've been very lucky not to have a flat tire before. Your last sentence there is nothing more than bad advice.
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone)
Appreciate 8
      05-12-2018, 01:01 PM   #203
voyagergab
voyagergab's Avatar
633
Drives: G82 M4 6MT, G01/F97 X3M
You must be incredibly lucky then.
Doesn't speak for everyone though.
Appreciate 8
      05-12-2018, 03:29 PM   #204
randyt
randyt's Avatar
Drives: 2018 MGM 6MT M2
2018 BMW M2  [0.00]
Same on the spare. I went through three run flats in 2 years on my 1 series.
As far as the sound levels of the M2 go, I certainly didn't find it as loud as I would have thought it would be from this thread. Certainly not as quiet as a 7 series, but that isn't what it is.
      05-23-2018, 04:04 PM   #205
PAC
PAC's Avatar
Originally Posted by GregoryK View Post
Back insulation done! You have to detach all the wiring. Then slid the insulation under and clip it back. Took about 4 hours total. I wanted to do it right. Also it was snowing for some of it!
As I said in one of my previous posts the Dynamat over those holes will kill a lot of high frequency noise from the rear. The proper part would likely do a better job as it is more ridged.
Is it 100% necessary to remove the rear seats to accomplish the placing the material in the trunk that would just cover the wheel cut outs? For less than $100 I could see myself doing this in like a month.
      05-23-2018, 05:07 PM   #206
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
I’m thinking of removing the side of the seats that is directly over the wheel where the hole is and putting insulation there. Then doing the trunk side of the wheel hump as well. Do you think that would do much by itself?
      05-23-2018, 06:37 PM   #207
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Removing the seats sounds worse than it actually is.....like most things. Take them out and put them back in 10 minutes. You do not need to remove them to do the back insulation though there is some overlap
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
PAC63.00
      05-27-2018, 05:06 PM   #208
mjsaville
101
Drives: M2 LLB - Arrived 4th Mar 2017
I've done the insulation under the bonnet / hood, very quick to do and the front of the car is noticeably quieter...
MJ
      05-27-2018, 06:08 PM   #209
18EM2
Public Last Class
18EM2's Avatar
2018 BMW M2  [0.00]
Would you say it reduces road noise or engine noise?
      05-27-2018, 07:20 PM   #210
S1monQc
Drives: '18 AW M2
X2
      05-28-2018, 01:41 PM   #211
mjsaville
101
Originally Posted by S1monQc View Post
X2
Engine noise, particularly when the DCT doesn't auto upshift until 3,000rpm, Probably helps keep the engine warmer for longer in the Winter too.
MJ
      05-28-2018, 01:45 PM   #212
mjsaville
101
Is it better taking the rear seat out via the boot or via the front doors?
MJ
      05-28-2018, 05:07 PM   #213
Nezil
Nezil's Avatar
1403
Drives: LCI '18 6MT M2
MJ
Front doors... It's really not as difficult as you think.
      05-28-2018, 07:00 PM   #214
silverado
silverado's Avatar
288
For those who installed only the under-the-hood insulation and the door seals, since it quiets the front of the car, does it make the noise seem concentrated behind you? These do seem like easy mods and I'm tempted to do them, but I worry about moving from all around noise to focused noise from the back, which could be annoying in its own way or more annoying. I worry that it needs to be an all or nothing thing: either do what GregoryK did (which is quite impressive!) or don't do anything at all.
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
      05-28-2018, 09:56 PM   #215
S1monQc
Drives: '18 AW M2
I would also like to know. I myself would like to tone down the road noise at the front, but not the engine/exhaust sound... I have the fender seals on order and tempted to do the hood insulation, but I do not want to reduce the engine sounds!
      05-29-2018, 10:00 PM   #216
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
MJ
Front doors only. It slides out of the center bracket once the sides brackets are unbolted. I'm in Canada so one seat is smaller and therefore easier to remove.
      05-30-2018, 03:17 PM   #217
mjsaville
101
thanks Gregory, Yup - I was forgetting my rear seat is split also. The added benefit is that will also help with weight and getting them out of the car.
Very tempted by this mod now.
thanks again....
MJ
      06-02-2018, 01:05 PM   #218
voyagergab
voyagergab's Avatar
633
MJ
Does the rear seat cushion and backrest come out as a single unit. ?
Or do you disconnect them first?
      06-02-2018, 04:09 PM   #219
voyagergab
voyagergab's Avatar
633
Hi GregoryK
I'm working my way toward the rear side trim and I don't understand how to remove the C-pillar covers.
The instruction below talks about clips (2) but none are exposed.
https://www.newtis.info/tisv2/a/en/f...sts/1VnXwsigxh
      06-02-2018, 04:17 PM   #220
Nezil
Nezil's Avatar
1403
I've removed these a few times.... Pull the piece off at the top first, then slide it upwards towards the headlining.
All three of the clips (two white, one metal) will slide down in the trim piece, and might actually stay in the metal bracket, but that's how you get it off.
You might want to buy a few additional white clips because they're more fragile than the metal ones. I've taken my trim off maybe 5 or 6 times now, and broken 2 clips in that time.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
