01-17-2023, 09:32 PM | #1 |
Rep 4
M2 6MT hp limit with forged internals?
Hi, this is my first thread and question - I’m currently running PureTurbos Stage 2 kit upgrade with custom map, forged internals from VAC motorsports and practically full bolt-on as far as the rest goes (air intake, charge pipes, intercooler etc.)
My PT turbo died after like 10.000 km, waiting for mechanic to pull it out and see if we’re gonna file a warranty claim with PureTurbos but that’s another story… What I am interested in is this: With a bigger turbo, what do you guys think is the HP limit? With a nice power curve, no crazy peaks. And what are potentially problems/limitations along the way? Meaning what else would I need to upgrade? Thanks in advance! Alex • 2016 M2 6MT • PureTurbos Stage 2 • Custom tune 505hp 680nm • VAC Motorsports Forged internals • Porsche GT3 Carbon Pole Position Seats • Rear seat delete • HRE FF01 19” wheels |
01-17-2023, 09:40 PM | #2 |
Rep 647
1000whp
But just once. |
track.n.trail62.00 |
01-18-2023, 03:51 PM | #3 |
Rep 10
Drives: F87 m2 lci
Limit would be the turbo itself, hybrid turbos can't push more than 520/550 hp on pump fuel (no ethanol) you have to switch to a turbokit
The second limit would be the open deck engine Everything depends on what you have to do with your car, it's a bit different if you use the car for heavy track use, occasional pulls or drag |
01-18-2023, 04:32 PM | #4 |
@lbb_kev
491
Rep 514
Are you still open deck?
01-18-2023, 05:39 PM | #6 | |
Rep 4
01-18-2023, 05:41 PM | #7 |
Rep 4
01-18-2023, 06:13 PM | #8 | |
@lbb_kev
491
Rep 514
Closed deck conversion will probably cost between $2-$3k without all of the other labor. Most go with cylinder support systems.
01-18-2023, 08:09 PM | #9 |
Rep 7,299
You are probably already close if you want long term reliability. The Apex ring taxi had an S55 fail with a hairline crack in a cylinder at around 500 WHP after about 23k miles on track. Could be a one-off, and obviously they run it hard, but it's also an S55.
Liukk891.50 |
