08-18-2021, 08:11 PM | #1 |
Rep 374
Ceramic pads (dust)
Has anyone here actually made the change to a low dust ceramic pad? If yes, what pad was it? I called both FCP Euro, and Pelican (month or 2 ago) with my vin for fitment, and neither had a suggestion. Ive read here the calipers are the same as an M2 Comp, but are they?
And yes, Im fully aware of the step backwards in performance, and they can NOT be used on track. UPDATE In post 15 Last edited by specracer; 09-21-2021 at 07:12 PM.. |
08-20-2021, 12:01 AM | #2 | |
Rep 7,301
08-20-2021, 02:35 PM | #3 |
Rep 374
08-20-2021, 03:37 PM | #4 |
Rep 547
The red M Performance calipers are the same as the grey ones, just colour difference. Aftermarket pad selection would be the exact same.
I believe the red brakes package came with slightly more aggressive sport pads from factory however. |
08-20-2021, 09:31 PM | #5 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
You need pads for the M2C 2NH big brake kit. The stock M2C brakes are different I think. I found these after a search but I haven't tried them. Been waiting for someone else to confirm.
Hawk HB828Z.760 Hawk HB193Z.670 |
08-20-2021, 09:35 PM | #6 |
Rep 7,301
2NH is stock in US, the blue brakes are ROW. So yes, 2NH listings.
08-20-2021, 09:38 PM | #7 | |
Rep 7,301
https://parts.bmwnorthwest.com/p/BMW...112284869.html The Red M Performance kit if purchased separately seems to come with a different pad part number, but I don't think the CS cars use it as far as I can tell. The "sport" 34112284465 part number is listed as for F10 M5 and no longer available. https://f87.bimmerpost.com/forums/sh...497066&page=13 |
08-20-2021, 09:47 PM | #8 | |
Rep 7,301
I have not confirmed the part numbers, but this site lists them for M2C incl. CS, so I assume 2NH, but you need to verify: https://www.knsbrakes.com/c/car-seri...mic+Brake+Pads also supposedly low dust: https://www.knsbrakes.com/c/car-seri...521+Brake+Pads I've bought from this vendor before and they were great, but I have not ever used the Hawk Ceramic pads nor the Carbotech 1521, so I can't vouch for them. I am pretty sure those are the right pads for the red brakes because when I put in the info for a F80 M3 (blue brakes), the prices are different. |
08-21-2021, 05:10 AM | #10 |
Rep 3,348
Dave Z has a nice section listing a range of pads for the M2C/CS 2NH brakes including a useful note about the factory wrap-around shims on the rear pads: https://www.zeckhausen.com/catalog/i...th=3_7079_8092
Current Stable:
cncmastr1591.50 |
08-22-2021, 09:44 AM | #12 |
6638
Rep 4,145
Drives: '18 M2 6MT
One of the reasons I'm holding off on the 2NH BBK is because there are no decent ceramic pads available, so if you find some, certainly let us know. At present I have an OG M2 with Akebono pads, and couldn't be happier with the performance/silence/low-dust.
08-23-2021, 01:15 PM | #13 | |
Rep 91
I am not sure Akebono makes pads for 2NH brakes, do they? John |
08-23-2021, 03:48 PM | #14 |
Rep 1,041
My 1st choice would be Akebono Euro Ceramics, followed close by Posi Quiet Ceramics.
But after inquiring with Dave Z, looks like we are not going to get a ceramic option for the 2NH. The best compromise would be the Semi Metallic compounds from Posi Quiet. I dont drive my CS enough at the moment to let the dust bother me. But it sure would be nice to know there would be options out there. |
6CylindersEveryDay340.00 |
09-21-2021, 07:12 PM | #15 |
Rep 374
UPDATE
I now have Hawk ceramic pads on our CS. I was able to confirm, via a dealer, that the M2C and CS have the same BMW pad part numbers. Then Dave Zeckhausen was very helpful and sent the dimensions of the C pads, and I pulled the pads and measured. Looked good, and I ordered a set. One note, as mentioned on his site, it is best to swap over the backing shim off the OEM rear pad (I did this) Here is a link to Zeckhausen, M2 C pads. Top of the page explains the shim https://www.zeckhausen.com/catalog/i...th=3_7079_8092 For sure less dust, after 50 or so miles. Car stops fine, but with less initial "bite", but plenty of stopping power. |
CSBM52730.00 |
09-21-2021, 08:00 PM | #16 | |
Rep 2,356
63-443-1648 63-443-0810
BSM ///M2cs, 6spd
09-22-2021, 07:30 PM | #17 |
Rep 374
Yes, and sorry I should have provided that.
Also just an FYI to any DIYer's, you will need a large Hex socket as the front calipers need to come off to get the pads out. Torque spec I was told is 80 lbsft. The rears are more standard, (tap out the 2 sliders, and the Brembo spring) Last edited by specracer; 09-23-2021 at 04:46 AM.. |
M3R12173.00 |
09-22-2021, 07:56 PM | #18 | |
Rep 2,356
BSM ///M2cs, 6spd
chris7197342.50 |
09-22-2021, 08:30 PM | #19 | |
Mmmm... Bavarian
2129
Rep 1,690
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
chris7197342.50 |
09-22-2021, 08:32 PM | #20 | |
Mmmm... Bavarian
2129
Rep 1,690
M2 CS
chris7197342.50 |
09-22-2021, 08:36 PM | #21 | |
Rep 7,301
09-23-2021, 04:55 AM | #22 | |
Rep 374
I have been working on a couple cars recently and obviously not remembering things correctly. Thank you for the correction, and I updated my post. Indeed it's a hex, not Torx.
On your yellows, consider swapping over the OEM backer shim. When installing the Hawks, they too were loose in the caliper. Added the shim and it took up that space. I would also add that Padgid yellows are a great track /street pad. In a different car that I had tracked a few times, I went through 3 other pads, before the yellows, and the yellows and Girodisc rotors were the only combo that survived a trackday Quote:
