08-26-2023, 08:25 PM | #441 | |
Rep 7,429
ZM22810.50 |
08-26-2023, 08:29 PM | #442 | |
Rep 7,429
edycol1501.50 |
08-26-2023, 09:44 PM | #444 |
Rep 4,146
I’ll admit, I didn’t consider the idea that the exchanger could be helping the coolant temps, but as it was pointed out, oil takes longer to cool - I don’t see the exchanger helping coolant temps as much as adding cooling capacity to the oil cooler.
You can see on most cars that the coolant (check @M2guru thread for his most recent logs) cools quickly, even when approaching near the “limits” Easier to delete it, then go with a new Intercooler - even if I think the VRSF/BMS/eTc are upgrades |
08-26-2023, 09:46 PM | #445 | |
Rep 4,146
08-26-2023, 10:05 PM | #446 | |
Rep 7,429
08-27-2023, 12:12 AM | #448 | |
Rep 1,485
Exchanger is of benefit that it warms up oil faster. One can argue that that will slow wear a bit. But primary purpose is to boost mpg. |
08-27-2023, 10:17 AM | #449 |
Rep 3,695
Well, I’m traveling all of September and will then be doing my first NLS Nurburgring race in October, so I don’t think my M2 will see hot weather again for testing until May/June 2024.
M2guru I’ll be interested in seeing your logs in the meantime with the do88 oil cooler if you still find some hot weather. Altho, I’m more curious to see what your coolant temps will do if you put on a larger IC (more engine power to be cooled and potentially worse airflow to the radiator), and if the do88 radiator will be enough to keep in check, or if you’ll have to do one of the remaining options we’ve just listed. |
08-27-2023, 07:17 PM | #450 | |
Rep 4,146
08-28-2023, 05:29 PM | #451 |
Rep 573
Next track day is 9/5. Ambient temps look to be similar to last event for an apples to apples comparison. Two changes: 1) I straightened stock radiator fins and 2) do88 oil cooler and fender liner opened up.
Tempted to upgrade intercooler because I cannot see a way to clean out the 5-year old CSF intercooler - guessing it's not great. Might do that next year. Radiator and/or aux radiator would be after intercooler. |
AmuroRay2282.50 |
08-29-2023, 09:18 AM | #452 |
Rep 4,146
Following up on this - is that expensive? I'm not as hardcore as ZM2 or M2Guru - but I would love to consistently track my car, though I'm not sure this is something I would personally do - especially since I probably can't carry the speed/pace they do. I doubt I would max out what I have.
Mods: Yes.
08-29-2023, 11:23 AM | #453 | |
Rep 557
08-29-2023, 11:39 AM | #454 | |
Rep 7,429
So what you need is to do the following: 1) Retain stock fittings: go to an AC shop (because they are familiar with this crimp style fitting bmw uses for their oil line) and get them to cut off and then recrimp the oil cooler fittings to new lines that go directly to the oil cooler housing - again the fittings on the oil filter housing will need to be recrimped to the new hoses. 2) AN conversion: you'll need to change out to an AN capable oil filter housing or run adapters - I think vac sells them. Then you'll somehow need to create bespoke fittings that adapts an to the O-ring plug style fittings bmw uses on the stock oil cooler. So either have a shop cut off the stock fittings and weld them to an an fitting or something. But this is what you need to do if you want to run AN lines. Personally I'd prefer option 1, because I don't like the idea of welding small diameter pieces especially because most shops will not purge them and this can create stalactites and restrict flow. Crimping shouldn't have this negative effect - unless somehow it was crimped so hard it smashed down the fitting. Ok now some more options, but affecting the coolant loop: 1) Assuming the heat exchanger is capable of 270F - 300F (this should be the case) without any coolant flowing through it to reduce temps (not sure about this). Then we can leave the oil loop as is. We would however modify the coolant loop which is way easier. As coolant is under far less pressure and their associated hoses are capable of being fastened down with standard work gear clamps without failure. So remove the coolant hoses going to the heat exchanger. Cut the fittings off the hoses going to the aux water pump (if you have an m235i, m2 doesn't have this pump for whatever reason and now would be a good time to retrofit one). Then create your own hoses clamping those stock fittings to the new hoses. The new hoses would also go from the aux rad to the aux pump, and then plumb back to the main radiator. This is the easiest method and it should be diyable, and therefore cheaper.
08-29-2023, 12:25 PM | #455 | |
Rep 3,695
08-29-2023, 01:06 PM | #456 |
Rep 7,429
Could be bent ac condesor fins restricting airflow. But it's possible the stock radiator is really insufficient because the m23ir is detuned to 270whp.
08-29-2023, 04:00 PM | #457 | |
Rep 557
I’m running WRL race pace at Barber for 25mins without issues but never see 5th gear so it’s never been a problem. I am eyeing a trip to Road Atlanta next spring so I guess I’ll find out. |
08-29-2023, 04:33 PM | #458 | |
Rep 3,695
Yup, 140mph+ is the death zone for our cooling systems. Even with my latest oil cooling upgrades, I know if I was at Summit or WGI and hitting 155mph in the summer, my coolant temps would be out of control. Guess I’ll have all winter to contemplate next changes, unless someone else starts testing this stuff in Florida or TX. |
08-29-2023, 05:06 PM | #459 |
Rep 3,695
Also, not to be more pessimistic, but I’m realizing I was running the Stg 2+ MM v1.2 map on my latest outing.
That map is 450-460whp on my car, vs v1.1 that I was running last year (480whp) and a slightly more boosted version of v1.2 (what I call Stg 2++ MM v1.2) that Halim gave me which gets me back up to ~470whp. I meant to run the Stg 2++ MM v1.2 but clearly the cooling system still wouldn’t have been able to handle it, esp if it were a hotter day and higher speed track. The upside of Stg 2+ MM and Stg 2++ MM v1.2 is boost now drifts lower in upper RPMs to keep the turbo more efficient and generate less heat up top. So, the tune (mis)selection in this case was also helping keep coolant temps lower. |
08-30-2023, 07:38 AM | #460 | |
Rep 684
08-30-2023, 08:14 AM | #461 |
Rep 557
08-30-2023, 09:26 AM | #462 |
Rep 3,695
GasBurnlife(landapanda)576.00 |
