10-03-2020, 03:55 PM | #1 |
Rep 112
Drives: 2020 LBB M2C
Creaking Driver's Seat Fixed!
A few months after getting my new car, the driver's seat would creak as I would accelerate or brake. I could rock back and forth in the seat and easily recreate it. It was incredibly annoying. Noises usually don't bother me much, but this made me not want to drive the car. I brought it to the dealer, and the seat frame was the culprit. I unfortunately didn't get much detail. After the fact, I realized I should have asked to see the bad part just to understand what was happening. Anyway, they replaced it, and so far it is as good as new!
On another note, they gave me a 330i G20 as a loaner. After driving it around for a couple of days, it's a nice car and a great commuter, but I was glad to be back in my M2. The G20 is boring in comparison! |
10-03-2020, 07:30 PM | #2 |
Rep 503
My car makes the same sound, do you have the receipt that shows what part number was replaced?
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
10-04-2020, 08:07 AM | #4 |
Rep 112
speedsnice1204.50 Kattanah137.50 |
08-19-2021, 08:21 AM | #6 |
Rep 2,602
I had an '85 Dodge Daytona that was involved in a wreck. Afterwards, every time I'd use the clutch, the seat would rock a bit. At one point I heard a snap and the seat would rock way back. I found a broken seat frame at the front bolt. I simply found 2 large washers to sandwich the 2 pieces together at the bolt. Lasted as long as I owned the car.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
08-19-2021, 12:47 PM | #7 | |
Rep 3,337
Current Stable:
08-19-2021, 03:25 PM | #8 |
Rep 188
My seat is also creaking. Started around 1500 miles. It sounds like it's coming from the upper half of the seat back. I also can recreate it be rocking side to side or back and forth. Very noticeable under lateral load in turns. Haven't taken it in yet, but it's driving me nuts so it'll probably happen soon
2003 Toyota Tacoma TRD
2018 VW GTI Autobahn 2021 BMW M2 Competition |
thegrinchboy62.00 |
08-21-2021, 12:07 PM | #9 |
Rep 596
Had that problem on my 235i. The actual seat bracket had failed on the right hand side causing the creak. Must be a design flaw. Was repaired under warranty.
08-22-2021, 06:27 PM | #10 |
Rep 188
Did the creak in your car also seem to come from the upper part of the seat?
08-23-2021, 04:06 PM | #11 |
Rep 2,135
Ah, the dreaded seat creak...
I disassembled the seat back and peeled the leather off to troubleshoot the problem. Noise came back a week later. Mine was coming from the pull back lever/assembly. |
08-23-2021, 07:17 PM | #12 |
Rep 380
Mine is going in Friday to get rid that creaking noise and to fix or replace the trim on passenger side between front door window and the fixed rear window that is coming loose. Thanks for this thread! Thought it was just me.
08-24-2021, 04:16 AM | #13 |
Rep 188
That's exactly where the noise in my seat appears to come from. Any fix for it?
08-24-2021, 02:04 PM | #14 |
Rep 2,135
08-24-2021, 02:15 PM | #15 |
Rep 3,006
My seat is rubbing the center console. The dealer placed a piece of paper between the two and the noise stopped. Unfortunately, they said their was nothing they could do that wouldn't look bad.
08-24-2021, 02:42 PM | #16 |
Rep 241
This. I also noticed today that my seatbelts have the soft side of velcro applied to the center consol side of the female part of the buckle, I'm assuming to stop the buckle from scratching/scraping the center console sides. Both of the seat bolsters appear to rub both sides of the center console so I'm surprised they'd go through lengths to apply soft velcro to the buckle but not protect the expensive seats. Tape solves the wear problem, but yah, it doesn't look good at all and you gum up the alcantara. Seat bolsters are just too big for the cabin. That or the center console is 2 mm too wide. They'd have to redesign either of them to fix the issue.
08-24-2021, 03:13 PM | #17 | |
Rep 3,006
03-21-2022, 10:52 PM | #19 |
Rep 380
04-12-2022, 01:35 PM | #20 |
Rep 126
I went to the dealership today for a Cracking chair/mid console.
They need to get the chair out and replace some things they said. So next appointment hopefully it's solved.
@Rub1con76
