M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Are oil catch cans worth installing?
      10-27-2020, 07:13 AM   #45
Sarg33
Sarg33's Avatar
Drives: 2021 X3M
Okay let me start by saying I am a proponent of installing an OCC. I fully understand the concept and I have posted previously in this thread as to why they are important. I even installed one on my M2C when it was brand new. I checked it the day before taking it in for the 1,200 mile service. At that time it had probably 1-2 ounces of liquid in it. In seeing that I felt I had justified the OCC on my car.
My car just hit 5,500 miles and I thought I would check the OCC again. I took it off and looked inside and there was barely anything in there. Picture below.
So in 4,300 miles it has had almost no accumulation of liquid. I can only assume that since the engine has 'broken-in' it has no significant blow-by. Given this and the fact that I need to pull the strut brace every time to check the OCC I decided to remove the OCC. One less thing to worry about.
Just wanted to give an update and add more info to the thread.
Can't or Won't?
Current: 2021 X3M
Gone but not forgotten: 2020 M2C LBB MT
Appreciate 9
ChrisK4449.00
tjsabec52.50
Moflow2484.50
ROASTM163.50
QM287.00
02M3ForMe4261.50
      10-27-2020, 12:41 PM   #46
beMtroubleYou
beMtroubleYou's Avatar
67
Drives: M2C '18
2018 M2C  [0.00]
Originally Posted by omasou View Post
Based on the S55 videos post here and other places they're collecting condensate not much oil.
Jupp. So no point really unless racecar.
Edit: Also thanks to the guy above posting pictures of his find. Cant appreciate the post enough
      10-27-2020, 04:58 PM   #47
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
I empty mine every few months, about 50-75ml of unpleasant brown burnt oil / fuel / water emulsion each time.
Better in there than collecting in and coating the intake tract.
No need to remove the brace either, less than 5 mins job done.
      10-28-2020, 04:40 AM   #48
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
Where did you mount yours?
      10-28-2020, 10:19 PM   #49
Skulinex
Drives: '4 M3/'5 M3CS/‘18 M3CS /‘21M2C
2015 Toyota 4Runner  [0.00]
2021 M2 Competition  [0.00]
2018 M3 CS  [0.00]
2004 M3  [10.00]
2005 M3 Competition  [0.00]
Anyone had experience using the mishimoto one?
      10-28-2020, 10:32 PM   #50
smknjoe
smknjoe's Avatar
Drives: 2020 M2C, 2018 GTI, 2007 Rabbi
Search "oil catch can" on the forum and you'll find a few threads. Some guys seem to like them.
      10-29-2020, 03:09 PM   #51
Detoxified
Drives: M2C HS
Yes I have the "M3/M4" Mishimoto oil catch can on my M2C. It fits fine and works great. I suggest buying the drain plug kit so you don't have to remove the can to empty it. I did not buy the drain kit and may buy it in the future.
      10-29-2020, 10:52 PM   #52
imyourmaster
imyourmaster's Avatar
Drives: 2021 M2C
2021 BMW M2C  [0.00]
Aren't there factory filters that do exactly what an OCC does? I'm pretty sure there is a thread discussing the removal of the factory filters whereafter guys will install an OCC. If this is accurate I don't see the need for an OCC unless the factory filters are removed.
      10-30-2020, 11:22 AM   #53
Detoxified
Drives: M2C HS
Incorrect, my Mishimoto catch can was installed inline of the Crank Case Ventilation hose from the intake manifold. You remove this hose and place the new Mishimoto hose from the intake manifold to the can and the heater block. This hose that you completely replace to place the catch can "inline" is an empty hose with no filters inside of it.
      10-31-2020, 04:18 AM   #54
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
what is generally overlooked is that the oil will prematurely weaken the plastic pipes over time and to me that is a bonus of having a catch can to prolong the life of the pipes.
      11-01-2020, 03:07 PM   #55
doughboy
doughboy's Avatar
1545
In the normal place as per BMS guide, just no need to remove the brace, it just fits right in the gap.
      11-01-2020, 03:11 PM   #56
doughboy
doughboy's Avatar
1545
No, the motor has no factory filters as such.
There are cyclonic separators in the cylinder head cover but these are not removable and don't work that well.
Manufacturers just accept that this blow by gunk will mess up the engine over time but they don't care as it will be out of warranty / high miler cars only...
      12-10-2020, 11:14 PM   #57
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
I'm curious and I haven't been able to find an answer so far, does the s55 need or even able to have a dual OCC setup like the n54 has? Or is the PCV system setup differently where the s55 only needs the 1 OCC in total to capture for both low load and high load conditions?
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
