01-04-2021, 10:04 PM | #156 | |
Rep 1,657
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
01-05-2021, 04:35 PM | #157 |
Rep 534
M Performance Gloss carbon fiber trim on steering wheel (like rest of interior). I put the open weave matte carbon fiber trim on my M2C.
01-05-2021, 07:59 PM | #158 |
Rep 1,259
Mine was just delivered this week.
2020 BMW M2CS HS 6MT
2022 Audi RSQ8 |
01-05-2021, 09:06 PM | #159 |
Rep 534
01-06-2021, 06:02 PM | #160 |
Rep 692
I am when I get the car
Vic
01-06-2021, 08:28 PM | #161 |
Rep 71
Akrapovic exhaust and link pipes installed today by Torrent Motors in NY. Great looking and sounding pipes. And Tico's shop did a great job installing. The original exhaust not only looks crappy but also weighs a ton.
11
01-06-2021, 08:36 PM | #162 |
Rep 1,657
Looks and I'm sure sounds great. Any idea about how many lbs you saved? That could be the deciding factor for me. I think as sound goes, my EL AA mid pipe will do the trick but if I could save another 20 lbs..it might be worth swapping the muffler also. My plans were paint only
MadBimmeRad7122.50 |
01-07-2021, 12:07 AM | #163 | |
Rep 534
Did this come with a valve controller/remote? Did you need to remap the ECU to prevent a check engine light? |
01-07-2021, 10:47 AM | #164 |
Rep 4,697
Is it possible with these aftermarket exhaust options to use the factory valve actuators to maintain the factory logic? My preference is to not have a remote.
01-07-2021, 11:11 AM | #165 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
Most of the valved exhausts just use the actuators moved over from the stock exhaust, so to answer your question... yes.
01-07-2021, 11:32 AM | #166 |
Rep 4,697
Thanks. So does the actuator just override the factory logic if you decide to use the remote, but defaults to factory if not "activated" with remote? I have no experience with them so I thought you had to always use the remote to select a valve position.
01-07-2021, 01:51 PM | #167 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
I've used a VSC-2 which basically plugs in-line with the stock plug and if you press the button, it overrides the OEM controller and opens up the valves. If you hit the button again, it reverts back to OEM control. Other valve controllers might work differently, but this one was simple and worked well. You can also order it to always be open or closed and pressing the button goes to OEM control (or open, or closed)... pretty much however you want it to be configured.
01-07-2021, 01:56 PM | #168 | |
Rep 577
Also - any check engine lights or coding needed as a result? I hear the EU folks with OPF have to code the car when doing this set up
Instagram: @MinionM3
Current Garage: 2012 M3 ZCP, Mineral White, DCT: Track Build 2020 M2CS, Misano Blue, 6MT |
01-07-2021, 02:34 PM | #170 | ||
Rep 71
01-07-2021, 09:02 PM | #171 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
Going in for full PPF tomorrow and then I can drive it a little more.
I've already done iND reflector delete, black badge and matte red M1 and M2 buttons, 80mm stud conversion and clutch slave cylinder/CDV delete. When it gets back from PPF I'll do my axxeon lip protection and cf splash guards. 10mm spacers in hand but not sure if I wanna put those on yet.
01-07-2021, 09:54 PM | #172 |
Rep 1,259
Akra-evo actually saves close to 30-lbs. Multiple vids on youtube -
2022 Audi RSQ8 Last edited by yaymitch; 01-07-2021 at 10:00 PM.. |
01-08-2021, 10:24 AM | #173 |
Rep 4,697
Appreciate you posting a video with sound for the vehicle under load. I despise the free revving videos because the exhaust sounds completely different. Who sits around free revving the engine all the time???
01-08-2021, 10:43 AM | #174 | |
Rep 577
01-08-2021, 01:45 PM | #175 | ||
Rep 1,259
2022 Audi RSQ8 |
Apppo132.00 |
01-08-2021, 03:01 PM | #176 |
F1 Fan
94
Rep 133
Some more CF parts...
2020 M2CS, 6MT;
2017 230i, 6MT, M Track Pkg/Premium/Executive |
