02-11-2019, 05:05 PM | #1 |
Rep 309
Vorsteiner V-FF 103 size??
I have a 2018 M2 and am confused about wheel size for V-FF 103. I want to run 255 up front and 275 rear. What size wheel do I need for those running them? 19 or 19.5 and can I stick with 35s instead of 30s? Also, I have 10mm BMS spacers and should I reuse them or no spacers. My car is dropped about 1 in on KW HAS.
Anyone have this set up and what do you suggest? |
02-11-2019, 06:51 PM | #2 |
Rep 195
The offsets on the 103's are already more aggressive than the stock rims. For the M2, they have a 9" in front and a 10" in rear. Vorsteiner recommends 245/35 front and 285/30 rear. You can run 255/275 if you want.
I wouldn't use the spacers. The rears will already stick out more without them. I was quoted 6mm more than stock rims with 10 mm spacers. The fronts will be 2mm inward than with stock rims and 10 mm spacers. Hope that helps...
2018 LBB M2 LCI
02-11-2019, 08:39 PM | #3 | |
Rep 309
02-11-2019, 09:39 PM | #4 | |
Rep 357
I already posted on another thread here: https://f87.bimmerpost.com/forums/sh....php?t=1541229 In any case, I ordered and received V-FF 103's and was informed that they're 19x9 ET21 and 19x10.5 ET40. I read elsewhere the fronts are actually 19x9.5. So which is correct? They also recommend 255/35 and 285/30. I'm wondering whether I should stick with 245/35 fronts instead. |
02-11-2019, 10:11 PM | #5 | ||
Rep 195
When you say "they recommend" who are you referring to? I've seen multiple times in this forum that Vorsteiner info recommends the combo I mentioned above and they provide picture examples of that spec as well. I have not gotten mine yet. They are on order
2018 LBB M2 LCI
02-11-2019, 10:14 PM | #6 |
Rep 195
2018 LBB M2 LCI
02-12-2019, 08:56 AM | #7 |
Rep 92
I am running 103's for an m3 on stock m2 Michelins. No problems what so ever. Flush fitment with good looking poke. No spacers and stock ride height. Specs are:
19x9.5 et22 19x10.5 et34 |
06-22-2020, 07:42 PM | #8 | |
Rep 929
According to Vorsteiner, I should go with stock size rims. But I'm waiting for a set of Michelin's I ordered which are 255 and 275mm because I really didn't want the tires to look stretched at all. My worry is that with the aggressive offset of 22 in the front plus the extra rim width, a 255mm tire would rub when fully turned in. Any help would be greatly appreciated!! |
06-22-2020, 07:43 PM | #9 |
Rep 929
I forgot to mention that my stock tires are Contis which look more stretched compared to Michelin's
