02-11-2019, 02:58 PM | #1 |
Rep 67
What pressures are you running?
What pressures are you guys running on the stock tires for aggressive canyon drives? I could use a little help dialing in my pressures. I'm on the Conti's BTW, but will be moving to M4PSs shortly. Thanks.
02-16-2019, 06:35 AM | #2 |
Rep 1,124
For track driving I run 38 front and 36 rear when hot. The front biased pressure makes the car more neutral on track.
02-16-2019, 09:18 AM | #3 |
Rep 6,934
Drives: 2018 M2 AW DCT
I have been using 35 all around as recommended by BMW.
02-16-2019, 10:40 AM | #4 |
Rep 425
well for last weekend's 20 mile brief wake-up from winter hibernation, i ran 27lbs all around on my stock Conti's per the car's TPMS. it flashed a warning not to drive over 80 mph. I then checked with my own gauge and they showed 31lbs all around. Pulled into a gas station and their gauge showed about the same...31lbs. Curious as to how accurate the reading from the TPMS is. Sorry for the slightly off topic reply.
02-16-2019, 05:39 PM | #5 |
Rep 6,934
TPMS reading are usually low. My readings are constantly 2 pounds lower than my calibrated tire gage.
