M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > BM3 Log CSF/Evo DP
      05-21-2019, 09:51 PM   #1
nismoman
Drives: 2017 LBBM2,2001 LSB M3,S52 E30
BM3 Log CSF/Evo DP
Thoughts on this log would be appreciated. 2017 6spd m2, Installed Injen Intake, CSF Intercooler and Evolution race-werks catless down pipe, stage 2 93 octane ots, with the stock muffler. I'm assuming I just paste the share the web
link address? Thanks for the input
http://www.bootmod3.net/log?id=5ce4ae72c090c67dfdca5e7b
      05-22-2019, 01:30 AM   #2
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Looks like the HPFP was struggling to keep up, your gas looked ok in the first gear but once the pump started lagging your timing went to shit. Was the car hesitating or stuttering at all?
      05-22-2019, 07:24 AM   #3
nismoman
Not really, felt normal through the pull. What is the normal ish timing advance number for a healthy pull
      05-22-2019, 09:28 AM   #4
Cornally
Drives: '18 BMW M2
Not to thread-jack, but, does it make sense in a scenario like this to back down to the stage 1 93 ots map or stage 2 91 ots? I'm wondering which map strikes a better balance of performance vs. taxing the hpfp.
      05-22-2019, 10:20 AM   #5
cecaa850
Great question. I would be interested in this as well.
      05-22-2019, 02:31 PM   #6
Pray for Mojo
430
Usually it's only the E30 tune that taxes the HPFP, not sure why the OP's pump was struggling a bit, could be a one off tank of gas. I run the 91 OTS because it doesn't seem as sensitive to gasoline quality and I'm only sacrificing 10-15hp.
Clean log should look like this, this is M235i Stage 2 91 OTS. Timing is nice and even all the way up, around 6,000rpm should be 10 or 11.
http://www.bootmod3.net/log?id=5baadd37d10b435c56a38457
      05-22-2019, 10:05 PM   #7
nismoman
Thanks. It was definitely fuel quality, That was a no name mobil station 93. I had roughly half a tank today and filled up with shell 93 and dumped a can of vp octane booster and everything cleared up big time. Pulled like a freight train! I'll post the log from tonight in another thread so people can see how it affects timing. Thanks for the help.
      05-23-2019, 08:25 PM   #8
Anthony1s
756
Drives: 2018 Mineral Grey M2
What happened to cause your timing to jump to 36 at the end? Is that the exhaust burbles coming on?
      05-24-2019, 09:47 AM   #9
Happy Motoring
Happy Motoring's Avatar
Drives: OG M2
2017 BMW M2  [10.00]
I don't know how bad or good the gas in Canada is but with people experiencing knock issues based on octane, I think I'll follow you and do 91 octane ots to play it safe.
      05-24-2019, 10:39 AM   #10
digimattic
digimattic's Avatar
37
Drives: 2017 6MT LBB M2
Our gas (at least in Toronto) seems pretty good! I have had no issues with Esso (ExxonMobil)'s 93 Octane or PetroCanada's 94 Octane. My M2 is not tuned, but had a WRX pro-tuned for 94 and never had an issue with a bad tank.
      05-24-2019, 10:47 AM   #11
Happy Motoring
Drives: OG M2
2017 BMW M2  [10.00]
Considering M2 from factory is able to take 91 octane I'm sure nobody will notice a difference but it seems with BM3 it is really finicky.
      05-24-2019, 12:50 PM   #12
Pray for Mojo
430
You really don't have any idea if the gas is good unless you're logging. The cars are made to run on almost any "premium" gas seen worldwide. The DME will adapt and make less power on poor quality fuel.
You might have better luck with TX 93, but here our "94" won't even run OTS 91 with clean timing. We have similar fuel quality to California/West Coast.
      05-24-2019, 01:30 PM   #13
digimattic
digimattic's Avatar
37
Noted. Would the Torque Pro app be sufficient to start logging it? the BM3 logs look like they're measuring timing on all six cylinders?
      05-24-2019, 06:55 PM   #14
Nezil
Nezil's Avatar
1403
Drives: LCI '18 6MT M2
It's not that BM3 is finicky, it's that the CA 91 octane is truly awful!
As others have said, the M2 from factory will run on 91 octane, but it won't run correctly as intended; even more so if it's hot outside with its woefully inadequate factory FMIC.
Take logs on the stock map and you'll see timing pull all over the place.
I'd actually hazard a guess that if a BMW DME engineer were to look at the logs with the CA 91 fuel, he'd be very surprised, and not in a good way. I very much doubt they've ever had engineers test CA fuel.
I know BMW has staff all over the globe, but I work for a large company that sells product internationally. If there is a problem in a region, we might send some engineers there to investigate, but if there isn't a problem, 95% of the engineering work goes on wherever 'home' is - Germany obviously for BMW.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
