02-23-2019, 04:17 PM | #23 |
Rep 27
02-23-2019, 04:24 PM | #24 |
Rep 3,695
Hmm...thought I’d seen around 20lbs for the Comp II. Either way, both are lighter than the CSF.
I’m going to do a bit more testing with my Dinan IC later this yr to see if it warrants replacement with the Evo Comp II or do88. Trying to find the best balance between weight, pressure drop, and ambient/IAT deltas for the track. |
02-23-2019, 05:50 PM | #25 | |
Rep 460
Drives: BMW 330i G20
Fair price and good looking (and not too heavy)! |
02-23-2019, 11:48 PM | #26 | ||
Rep 177
I had no noticeable turbo lag, but I already had a fabspeed sportcat dp installed so that may have helped. Install of IC and Chargepipe was easier than the dp install. No fitment issues. I won't truly know if it's worth it until the 100 degree temps roll in. |
specka71.00 |
02-24-2019, 02:29 AM | #27 | |||
Rep 166
Drives: M2 LCI BSM
I replaced the charge pipe with VRSF at the same time as FMIC install, and the workshop told me that the angle they've machined the pipe at means the pipe is quite tight in placement. They needed to insulate it with rubber as it sits metal on metal against another part of car. I'm wondering if there isn't some leak occurring between these newly added components. Question - would that result in a CEL if it was the case, or just reduced performance? Thanks
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
Blurbo311197.00 |
02-24-2019, 03:37 AM | #28 | ||
Rep 27
02-24-2019, 09:16 AM | #29 | |
Rep 3,695
I don’t know, tho. |
02-25-2019, 04:21 PM | #30 | ||||
Rep 177
Maybe you have a boost leak? I don't think a minor or moderate boost leak would trigger a check engine light but I could be wrong. |
specka71.00 |
02-25-2019, 04:31 PM | #31 |
Rep 166
Drives: M2 LCI BSM
I have the Wagner Evo II Comp. Boost leak is definitely something I'm wanting to investigate.
02-25-2019, 04:53 PM | #32 | |
756
Rep 2,149
Evo 1 Performance (bar and plate) 8.8kg Evo 2 Performance (bar and plate) 11.5kg Evo 1 Competition (tube and fin) 6.6kg Evo 2 Competition (tube and fin) 8.6kg Source: https://x-ph.com/wagner-tuning-bmw-f...s-intercooler/ |
03-04-2019, 08:41 PM | #33 |
756
Rep 2,149
Looking at this, an intercooler and charge pipe added 8hp with stock tune. Hmm...
https://f87.bimmerpost.com/forums/sh....php?t=1455188 |
03-04-2019, 11:35 PM | #34 |
24174
Rep 190,750
On a stock or lightly modded car go with a 5" intercooler
Wagner EVO I, VRSF 5" or Active Autowerke
Fedorov162.00 |
03-05-2019, 09:55 AM | #35 | |
Rep 460
I just saw that the competition was lighter..but maybe the weight difference could be nullified by other parameters..? |
03-05-2019, 09:56 AM | #36 |
24174
Rep 190,750
Competition is better than performance in every case, its lighter and recovers temperature faster
Fedorov162.00 |
03-05-2019, 11:43 AM | #37 |
Rep 3,695
Hey Mike, what other fin/tube FMIC’s are out there besides the Wagner Comp?
03-05-2019, 11:55 AM | #38 |
24174
Rep 190,750
Only Wagner offer tube and fin intercoolers
03-06-2019, 07:12 AM | #39 | |
Rep 32
The FMIC, charge pipe, and downpipe fit like they were an OEM part, and the technician who installed them said they were OEM or better quality. I have not noticed any increase in lag after the installation of the Active Autowerke FMIC and charge pipe—not that there is much in stock form. Indeed, I would say the cars pulls a bit harder throughout the RPM band, and even pulls to 7000 RPM with a bit more urgency. In terms of performance gains, I would say I feel more from the FMIC and charge pipe swap then I did from the downpipe. In sum, I have not felt any negative effects from changing out the FMIC and charge pipe to the Active Autowerke parts. Fundamentally, I made the move to the Active Autowerke FMIC and charge pipe because I live in Florida and wanted a more efficient intercooler to deal with the nearly year-around heat and humidity. I am very happy with my decision and would do it again. Hope this helps.
Modification \n (1603)\ the making of a limited change in something; also : the result of such a change
03-06-2019, 03:05 PM | #40 |
Rep 229
Personally, *I* would not upgrade an intercooler if I'm keeping my car stock. No way.
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
03-06-2019, 09:36 PM | #42 |
Rep 229
1) The car is designed for that power level, for street, with that IC. And so what if it cuts a little power ??
2) OP is in sweden (cold)...I've had absolutely no noticeable street issues with stock IC in Dallas heat 3) Once u start messing with IC, you MAY have warranty issues, you MAY have quality issues, etc. IS it worth it? It wouldn't be for me.
Fedorov162.00 |
03-06-2019, 09:52 PM | #43 |
Rep 7,422
+1
03-07-2019, 12:21 AM | #44 | |
Rep 460
Last summer was unusually warm where we reached up to 30 degrees celcius (about 85 deg fahrenheit) for almost a week. Otherwise we are happy to see even 25C/77F at all during summer. Rest of the year below 20C/68F for sure, at least where I roam. And I rarely push the car to the max but I'm still battling inside because keeping the temps lower in the long run would probably benefit the health of the engine/turbos.. So many decisions to make, so little time... |
