12-26-2018, 05:22 PM | #1 |
Rep 1,644
Exhaust burble/overrun = anti-lag?
Since it seems this is now adjustable if using BM3, I'm curious if PTF or anyone else knows exactly what that adjustable burble slider in their software is doing? If its retarding timing on throttle lift, can we consider this a very minor anti-lag system? If its adjusting timing and still injecting fuel w/ spark during lift, I would think yes?
12-26-2018, 06:26 PM | #2 |
Rep 2,577
Igniting fuel on lift off appears help keep the manifold pressure, but the diverter valve already does just a much better job at it.
DV has been a smart engineering and specially well executed by BMW as you probably notice every single turbocharged BMW has excellent throttle on/off response, with or without burble. Huracan/R8 albeit being naturally aspirated, pops and crackles like crazy from factory. Let's believe it's just drama.
Lemania 2320
M2OG400.00 |
12-27-2018, 06:48 AM | #3 | |
Rep 1,644
12-27-2018, 06:13 PM | #5 | |
Rep 2,577
One more thing indicating that burble won't be necessary for more responsiveness - there is the wastegate to dictate how much exhaust flow is pushing the turbine. And if you read log, wastegate duty % is never 100% outside of spool up. That means if DME wants more turbine shaft speed during pedal lift off, wastegate duty can always increase to achieve that and much more accurately.
Lemania 2320
04-07-2020, 06:17 PM | #6 |
@lbb_kev
490
Rep 512
Reviving this thread... I'm currently running BM3 stage 1 OTS tune with FBO's (Fabspeed sport cat DP, Remus exhaust, etc..) and even the OEM burble settings are now slightly obnoxious for my tastes.
Have there been any new insights regarding the cons to disabling burbles? |
