12-17-2018, 01:43 PM | #1 |
Rep 314
BM3 Stage 2 Data Log 60-110 mph
BM3 Stage 2 Data Log from 60-110 mph, took 3 screen shots numbers look good AFR, Boost, IAT... Any input would be great or other Data logs.
Kiel McCaul
12-17-2018, 05:44 PM | #3 |
Rep 314
Thanks bro, I know it's not very common to keep Boost all the way thru rpm.
Not sure how familiar you are at looking at Data logs if everything looks good?
Kiel McCaul
12-17-2018, 08:23 PM | #4 |
2465
Rep 9,004
I’m learning, but I don’t see anything that stands out. I also don’t know what all the BM3 targets should be.
BostonM235xi130.00 |
12-18-2018, 12:50 AM | #5 |
Rep 4,510
That's the target psi and actual psi is consistently about 1psi lower on all 3 screenshots...
Current '22 X3M LCI.. |
12-18-2018, 12:53 AM | #6 |
2465
Rep 9,004
12-18-2018, 12:59 AM | #7 | |
Rep 4,510
Timing - should be numerically the same with a variance <3 so this is borderline OK. Just by glancing at these I'd say fuel quality could be better
Taskmaster2465.00 |
12-18-2018, 07:08 AM | #8 |
Rep 4,510
BM3 boost targets are dependent on several factors - n55 M2 BM3 stage 2 will target higher psi than high 15's you quote.
https://f87.bimmerpost.com/forums/sh....php?t=1497548 The thread above shows how better fuel and or higher octane helps keep BM3 OTS map actuals v target parameters together more of the time with more consistency
12-18-2018, 07:34 AM | #9 | |
Rep 4,510
Suggest start by trying say 1 gal of ethanol to a full tank and logging; then repeat by adding 0.5gal at a time, topping up with regular gas and logging to see what changes. I wouldn't go beyond ~ 2.5-2.75 gal of ethanol to a full tank of gas.
12-19-2018, 11:29 PM | #12 |
Rep 2,577
OP,
With proper 93OCT and 60~70F of IAT in your case, the timing across should be maxed out any time all the time. Do a few more pulls to see how it adapts. Preferably pull back to back to let IAT climb so you see how it respond to higher temp. I'll look if you send me the link to full log.
Lemania 2320
12-20-2018, 05:50 PM | #13 | |
Rep 314
New data logs
Kiel McCaul
12-21-2018, 06:06 AM | #14 |
Rep 314
Logs
Kiel McCaul
12-21-2018, 09:53 AM | #15 | |
Rep 4,510
Suggest you do multiple pulls in a single gear [min. 3rd gear] with DSC fully off and with WOT (gas pedal at 100%) from below 2000rpm to redline and you will get more data points across a larger (ie ~5000 rpm) rev range. staying in 3rd gear, decelerate then repeat again a few more times in 3rd gear so as you can see how logs hold up as IAT's climb. You can continue to log into 4th [& 5th] as you move up thru the gears with pedal at 100% WOT.
Current '22 X3M LCI.. Last edited by Bee Pee; 12-21-2018 at 10:02 AM.. |
