12-10-2018, 10:08 PM | #1 |
Rep 361
Dragy Testing
I’m starting down the path of modding my M2. To quantify the results of the mods I got a dragy. I don’t live in an area with many dynos and it seems that there are lots of variables that can affect dyno numbers. While whp numbers are nice to know I’m more interested in what it adds up to out on the road.
My plan is to test each mod by timing the 60-120mph times with a dragy and be as scientific as possible. Every time I test the car I take a screenshot of the weather for comparison sake. Runs are on the same flat road in the same direction with back-to-back pulls seperated by a .5- .75 mile slow down. No rhyme or reason for this format it just happens that the road requires it. The first test was stock vs Dinan sport tuner in race mode. The 60-120mph results were: Stock- 12.47 seconds Dinan Sport tuner Race setting-11.25 seconds. Race setting is 1.22 sec faster Weather 70f, humidity 38% wind NNW 2mph resulting in a slight tail cross wind. What do ya’ll think? Suggestions & advice welcome. |
12-10-2018, 11:41 PM | #2 |
Rep 2,577
60-120mph is 96-193kph. Your number of 12+s with stock car is way off. Stock car does 100-200kph in 10.5-10.8s.
Also, with M2 it would be even difficult for FBO and a quality flash to gain a full sec in 100-200. A TMAP based piggyback alone is not going to do 1.2s.
Lemania 2320
Rock Sweden268.00 |
12-11-2018, 07:33 AM | #3 | |
Rep 361
Blurbo311197.00 |
12-11-2018, 07:46 AM | #4 |
Rep 361
Wagner Sport Cat
A wagner catted DP has been added since I did this on 11/18. I haven't done any tests with it yet but should do a couple in this week. Been waiting on the weather to be comparable.
I also shot videos of the stock exhaust. I used a DB meter (Decibel X Pro for Iphone) to try to quantify the difference but I think it's going to be inconclusive. The meter doesn't show much if any difference between comfort and traction mode. BTW The DP threw a code within 15 miles of soft driving. Next I will tune with BM3 OTS stage 1 followed by a CSF intercooler and ER charge Pipes and OTS stage 2. The IC & CP S2 will be after new years. |
12-11-2018, 09:51 AM | #5 | |
Rep 427
DCT, with it’s extra gear, probably has different shift points and tighter ratios, but not sure what you’re driving. Anyway, that’s probably obvious, but just a thought while I’m still drinking my morning coffee. |
12-11-2018, 11:46 AM | #7 |
Rep 175
Guestimated loss for a manual is about half a sec, 1 sec if you change gear sloppy? So 11.2 is not that bad
Edit: sorry...11.2 is actualy bad for non-oem |
12-11-2018, 12:40 PM | #8 | |
Rep 361
no its 120, the extra gear shift may account for some of it.
I'll get some more times soon. weather hasn't been cooperating lately. lots of rain and cooler temps. Thursday high in mid-60's. I'm a newbie at this stuff so all insight is appreciated. |
bentom2335.50 |
12-11-2018, 02:53 PM | #10 |
Rep 147
I think if you're doing this for scientific purposes, the most important thing is keeping the conditions relatively consistent and just looking at the speed improvements. There are so many variables so don't bother comparing to other people's times, just compare to your own.
I rarely see people achieve what publications report for performance metrics like 1/4 mile, 0-60 etc. By brother-in-law couldn't beat a 13.9 @ 100mph quarter mile in his bone stock Audi S4 when it was new. Motortrend apparently clocked a 13.0. Same deal with my old e46 M3 back in 2005 - I got a best of 13.7 @ 101mph bone stock (with a 2.0 60') yet the magazines showed 13.0-13.1. Don't sweat it. Your car is quicker after the mods, that's the important part. |
12-11-2018, 03:35 PM | #11 | |
Rep 361
12-11-2018, 03:41 PM | #12 | |
Rep 361
12-13-2018, 03:16 AM | #14 | |
Rep 4,515
Current '22 X3M LCI.. |
Rock Sweden268.00 |
12-13-2018, 04:33 AM | #15 | |
Rep 2,577
OP being a manual explains a lot. My advice for OP is to measure 60~120mph time in just 4th. If 4th isn't really long enough, finish where 4th ends. The single gear pull removes shifting inconsistency by human error. Therefore it works as the real world dyno from which you see accurate improvement. Like said, delta is what matters. Keep in mind in doing that, you'd be seeing bigger improvement than should, because you stay in the middle range longer than should. But anyway, that's mostly the real world case for manual car.
Lemania 2320
Bee Pee1779.00 |
12-13-2018, 08:36 AM | #16 | |
Rep 415
I believe the quickest my car has gone on the tweaked ots is 9.3s, so quite a bit off. This was however in greasy/traction limited conditions in mdm mode. I have a new version to try but I don’t expect to reach the levels of performance you get from a custom map with these slightly tweaked OTS’s. Still fun to test and see how the changes affect on road performance. |
SeanWRT3179.00 |
12-13-2018, 03:41 PM | #17 |
Rep 361
Just did a couple of runs on way home. Wasn't able to use same road today.
Weather: 61f, 65% humidity Wagner Catted DP Stock 10.51 sec Race 10.33 sec I just saw the shifting advice so i didn't try that. Not to mention my baseline is with a 3rd- 4th shift so I'm going to stick with that method. Apples to apples and all. |
SeanWRT3179.00 |
12-13-2018, 07:49 PM | #18 | |
Rep 2,577
FMIC+DP+Turbo Inlet+ Dinan= 10~10.2s. On stock tune (turning off Dinan), I did 10.1-10.3s. The hardware mods increase the stock tune aggressiveness, which cannibalizes the gains from Dinan Elite software that may have an absolute maximum boost target designed for complete stock hardwares. Dinan Sport tuner that you're using would be a different story as it adds 4psi of boost in race mode on top of whatever DME targets. As such it sometimes takes more advantage of hardware when ambient condition allows, but at other times it goes over aggressive and DME pulls timing, ending up being slower.
Lemania 2320
12-14-2018, 06:14 AM | #19 | |
Rep 361
Weather 70f, humidity 38% Weather today 61% humidity 65% |
