04-03-2018, 12:48 PM | #1 |
Rep 105
BM3 OTS Maps & Changes
I recently jumped on the BM3 bandwagon (great stuff so far), and I've done quite a bit of research before making deciding to ultimately pull the trigger. I thought I was pretty tech savvy and can follow directions, but trial an error is how I eventually got everything to work. (maybe I can't follow directions?)
I'm running a catless downpipe, but otherwise stock in the performance department, so I went with a Stg 1 OTS tune to start me off, as it listed a FMIC & downpipe as *requirements* for Stg 2 OTS maps. Stg 1 is simply *no modification required*. Being catless, I do get the CEL, with the Stg 1 OTS map, and there doesn't seem to be a way to modify the OTS maps. I opened a ticket to inquire about a way to get a custom map simply removing the CEL function for cat efficiency and cold start delete and keeping the rest of the OTS mapping, and was told simply that the those are functions of the Stg 2 OTS maps. I'm trying to figure out my next course of action. I'm not ready to do a custom map with one of the established tuning companies because I have more plans for the car and don't want to have to do things twice, and I don't want to have to revert to stock map just to be able to modify it to fix the CEL for cat efficiency. What are my options other than full-fledged custom map or getting stuck with a stock map with cold start delete and cat efficiency CEL delete? |
04-03-2018, 03:25 PM | #2 | |
Rep 4,551
Drives: 2015 328d xDrive
If you don't want to use stage 2 or the stock map you could always install a JB4 and run it on map 0. That will delete the CEL while letting you keep your stage 1 tune. Not the cheapest solution, but it will work. Awron guage and macht schnell EVC module also have CEL delete functions. |
04-03-2018, 04:27 PM | #3 |
24190
Rep 190,803
Best option would be to get a much needed intercooler and go with stage 2 map
With stock intercooler car is under performing even with stage 1
04-03-2018, 06:42 PM | #4 |
Rep 4,203
If this helps, I am FMIC & MPE only so far. Always running 93. Did some 4th gear pulls and a 5th gear pull and sent to Halim for review and it came back as "look great" I plan on a DP in the near future but from direct discussion you should be fine as long as your not going to track the car. if so then a DP is a must. FMIC is always required when raising boost levels.... believe me the health of the car overall will be better especially being in the hot and humid Fla environment
Jump to the STG 2 and do logs and review...you will be fine. Always run 93 and pop in some booster if it pulls timing a little bit. Also pay attention to your IAT's. I tell you the OTS map is smooooooth |
FSociety3812.50 |
04-09-2019, 01:17 PM | #6 | |
Rep 36
Hello,
I'm sorry for noob question, but sometimes I have to start What exactly you mean "if it pulls timing"? I mean what numbers I am looking for to recognise DME had done corrections in wot? Thanks, Roman Quote:
04-09-2019, 02:16 PM | #7 | |
24190
Rep 190,803
when you datalog you can each cylinder's timing and monitor whether its dropping during a pull or not.
04-09-2019, 03:46 PM | #9 |
24190
Rep 190,803
I would go with a 5" FMIC in cold countries
04-10-2019, 04:15 AM | #10 |
Rep 243
Hi Mike, is the Wagner Evo I/II Performance a 5 inch? I don't want any (trim) cutting on my car.
04-10-2019, 05:05 AM | #11 |
Rep 2,577
I'm surprised no one before me was able to tell you this - you can turn off cat efficiency warning with STG1 map thru config tab.
Don't forget to save the changes and flash again and you'll be good.
Lemania 2320
04-10-2019, 10:56 AM | #12 |
24190
Rep 190,803
No cutting required with either one, EVO is 5" , EVO II is 6"
