08-31-2017, 06:17 AM | #89 | |
Rep 790
Intuitively, the N54 twin turbo is more oversized (i.e. has more tuning room) than the dual scroll turbo of the M2... which everyone seems to agree is sized for its current tune and not much more. So you would expect that would give the M2 the advantage in the lag department (at factory settings). Sorry to hear of your experience... I am quite happy with the difference mine has shown. Would really be a bummer to feel that after spending all that money. |
SeanWRT3179.00 |
08-31-2017, 08:25 AM | #90 | ||
Rep 85
The more I think about this, the more I feel that it might not be "less" lag in the 135i that I'm feeling, but the effect of less boost pressure which would entail less spool up compared to the M2's higher boost. I'm not certain of the stock boost pressure in an 135i versus an M2, but it's safe to assume that the M2's N55 is a tuned variant with additional boost over the stock engine. More boost equals more time / effort to spin up, right? In fact, now that I think about it, the response delay in the M2 feels an awful lot like my 135i when I have the JB3 turned on to the high boost setting. The instant response is subordinated to a slightly delayed surge in power as the turbo comes online. For the record, my original comparisons were based on both cars in stock form. I know I'm oversimplifying, but the M2 engine is in some ways like a chip tuned version of the stock variant. It sort of feels like it at least. Appreciate the discussion here as it really is helping me to better understand the dynamics of the car. Good stuff. |
08-31-2017, 09:19 AM | #91 |
Rep 790
Glad to hear your impression is not affecting your enjoyment of an awesome car.
Good point about the relative boost pressures. I would be curious to know what the factory settings are as well. I am sure some geek on here knows. Anyone? I am not a turbo expert, but your explanation makes some sense. Though again I really did not see it when driving them back to back myself. I will let the comment slide about the N55B30T0 being a chip-tuned N55B30O0... much more to it than that! Crankshaft main bearings, pistons, oil sump, cooling... etc. Still think you need to stop driving it like such a granny (kidding!... just kidding) |
08-31-2017, 10:05 AM | #92 | |
Rep 85
Totally understand the M2 engine not just being a chip-tuned N55. The mechanical upgrades are legit, but I tend to think they are more of the enablers for a reliable increase in boost pressure. Curious now. The N54 had a non-turbo inline-6 sibling that was used in the early 128i cars (the N52). Unless I'm mistaken, the N55 didn't have such a compliment.... Aren't the less powerful car models now fitted with completely different 4 cylinder turbo engines? This might explain the NA part of the N55 lacking a bit in comparison.... If BMW engineered the non-turbo N54 sibling to be a strong performer off-boost, it would stand to reason that this behavior would still be present in the more powerful boosted version. In essence, the N54 just made a good thing even better, whereas the N55 engineers didn't put any focus on tuning off-boost performance (since there isn't a standalone non-turbo variant). This may also explain a piece of the "lag" puzzle. |
08-31-2017, 10:54 AM | #93 | |
Rep 790
08-31-2017, 12:17 PM | #94 | ||
Rep 85
The two engines seem to have distinctly different behaviors from my experience, even though the specs show them as being very similar. I can appreciate both, as I see them as being necessary tradeoffs for the purposes of the cars they are powering. I would be curious to drive a M235i for a more apples-to-apples comparison. I truly wonder if the differences really do just boil down to the additional boost on the M2. |
08-31-2017, 03:30 PM | #95 | |
Rep 5,369
BMW goes to great lengths to deliver smooth power delivery. Thus, for better or worse, they manipulate a ton of parameters to deliver that feel. It's largely why they can deliver so much more snappiness in boost delivery when in the Sport throttle settings. It's not just the throttle becoming more sensitive, it's wastegate, timing, and cam lift manipulation as well. Also, the nannies in these cars are hyper sensitive and operate quite efficiently in the background to the point that they too influence power and boost delivery. One should drive these cars around in DSC Off for two weeks to see what I'm talking about. I say two weeks because it takes some time to get use to the throttle response, but once you do, the car will become quite lively. |
doug_9992541.50 |
08-31-2017, 03:37 PM | #96 | |
Rep 5,369
The M2 makes around 4psi more than the M235 N55. On the dyno, the M2's power numbers are eerily similar to an M235 running BMS Stage 1 (3.5+ psi) or JB4 Map 1 (4 psi). The only differences being the power curves are slightly smoother with M2. This should be expected since BMW is actually writing code into the DME to deliver more power rather than using piggyback systems to manipulate the boost and timing control data to create power. Once you start adding mods, there's really no difference between the power numbers and gains. They're basically even. |
08-31-2017, 04:07 PM | #97 | ||
Rep 85
08-31-2017, 04:10 PM | #98 | ||
Rep 85
08-31-2017, 05:56 PM | #99 | |
Rep 5,369
I don't know how long you've owned your M2, but if you haven't driven it in cooler conditions (i.e., sub 60s), you'll see reduced lag as well. By nature, there's more turbo lag when the ambient temps are hotter and more humid and less oxygen available. |
01-18-2018, 08:47 AM | #100 |
Rep 8
Did an Autocross event with the M2, on a hot summer day, was probably high 80s for the ambient temps. We were maybe a dozen guys, across 3 M2's, and they all had HORRENDOUS heat soak-induced turbo lag from a stop. It was atrocious. I'd stomp on the go pedal after each stop at the cones where we're supposed to stop, and it literally would wait a full second before I get going.
Others concurred. Earlier on at a separate autoX course right near by, at the same racetrack, maybe a half hour earlier, we had M4's (3 of them as well). Those exhibited a lot less throttle lag / heat soak suffering. I hope BMW in the LCI of the M2 fixed this, because when it's hot out and you're pushing the first gen (2015/2016/2017) M2 as a performance vehicle, that N54 suffers massively from heat soak. Very bad heat management sadly. It turned me off so much that any chance that I'd consider getting one, was dashed, despite really liking the looks of the car, the brake feel, steering, and just general chassis/handling feel, and the sound/power. |
01-18-2018, 11:50 AM | #101 | |
Rep 4,254
///M Power
01-18-2018, 02:06 PM | #102 |
Rep 1,148
The M2 LCI had no changes to the engine. (There was no 2015 M2. The '16, '17, & '18 models use the N55 - I'm guessing that was just a typo and therefore has no effect on your argument, however. )
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone) |
01-19-2018, 12:03 PM | #103 | |
Rep 450
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
05-30-2018, 05:53 AM | #104 |
Rep 152
Everytime i upshift from whatever RPM there is a small gap between me giving gas and the car going anywhere. I dont know what kind of lag it is but it ruins the experience every time, regardless of mode.
Its a 2018 manual, really wish I went DCT.. never eperienced loss of boost on dct. |
05-30-2018, 07:18 AM | #105 | |
Rep 3,968
05-30-2018, 08:09 AM | #106 | |
Rep 152
I also feel that the bluetooth/spotify integration has problems too, it kinda forgets the phone after 10min of music and shuffle never works properly:S |
05-30-2018, 11:32 AM | #107 | ||
Rep 6,635
05-30-2018, 04:36 PM | #108 |
Rep 4,254
When you come off throttle you will absolutely come off boost as well in MT unless you are smashing through gears pretty aggressively. Not sure how this wouldn't be possible. But it's there for sure. If you stomp it, you'll feel the lag. Some of that is TC intervention though.
All manual turbo cars are like this.
///M Power
No Boost4021.00 |
05-30-2018, 07:22 PM | #109 |
Rep 1,608
I remember doing a bmw event last summer at Limerock. We were doing an autocross for prizes, and we were all driving race prepped M240is, and Ive got to tell you, whenever we had to brake hard going around a cone, after getting hard on the gas pulling out of the turn, it was like an eternity waiting for anything to happen.. Not a lot of fun. These were all equipped with the automatic transmissions.
Boostm3
05-30-2018, 09:05 PM | #110 |
Rep 2,577
Best way to feel lag is to do a 3rd or 4th (if you really have 450+whp) full rev range pull. DSC off, you rest assured, in such cases, stock M2 is way too weak to break traction.
Keep in mind, start from OFF THROTTLE cruise speed at below 1500rpm to make sure it's off boost. Floor it, you will know what I mean. I've done that literally hundreds of times for the past few years, for data logging tuning purpose. Let me tell you lag is with N54 and S55. You can feel it on the road and see it from log.
Lemania 2320
stefan2352.50 |
