04-25-2016, 02:08 AM | #24 | |
Rep 146
He responds to email promptly. |
04-25-2016, 02:48 AM | #25 |
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Just wait for jb4 lol
04-25-2016, 12:58 PM | #27 | |
Rep 1,015
Has anyone coded it out and noticed poor audio quality in the sound system? |
04-25-2016, 03:05 PM | #28 | ||
7906
Rep 11,785
04-25-2016, 03:34 PM | #29 | |
Rep 1,015
I read from his statement that he went with the harness, but didn't hear any audio benefit over coding it out. Hence the reason he can't recommend the harness. |
04-25-2016, 10:25 PM | #31 |
Rep 3,402
I ordered my ASD bypass device last night. I did get an email with the invoice that warned using that device can have a small impact on the bass. Not sure what that impact is. 65 bucks is kind of silly for a small wire harness but I like the fact I can reverse it easily. Of course all I need now is my damn car.
04-25-2016, 10:43 PM | #32 | |
Rep 146
Just code it off guys, this harness is no bueno for our cars, in my ever so humble opinion. |
04-27-2016, 12:40 PM | #33 |
Rep 689
So this is probably something i'm having a hard to distinguishing. Do my ears suck?
Because I tried pressing the button at different modes and it did get louder but I thought that was a correlation with the fact that the throttle was more sensitive at the given location. It has not bothered me yet... |
04-27-2016, 04:43 PM | #34 | |
Rep 140
04-28-2016, 01:40 PM | #36 | |
Rep 2,942
The ASD elimination harness doesn't reduce the sound quality; it removes yet another trick that BMW uses to artificially boost bass SPL; the power amp in the ASD module. It actually improves it by removing an element that is designed to hide the 2 Series HK system's many deficiencies. In addition, as stated before, the harness also removes a significant amount of floor-level system noise caused almost exclusively by the ASD module. You would actually need to run an A-B-C test to hear all of this for yourself: A: Stock HK system B: System with ASD coded off C: System with ASD harness installed If you want to do this, go for it. Or you can trust those of us who have done all of this already in the 2Addicts forum and know this as fact. Your choice. Finally ... Technic, who is a pro audio installer in SoFla and a BMW enthusiast, makes each of those harnesses by hand. They're not spat out by some factory in Hunan province. For context, try finding speaker pigtails with OEM harnesses. Companies like Scosche make those by the hundreds for many other makes. But for BMW, they're not available anywhere -- except from one DIYer on the bay.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 04-28-2016 at 01:49 PM.. |
04-28-2016, 02:12 PM | #37 |
Rep 146
So the ASD amp also adds some power to the subs. This aligns with what my ears heard. There is a reduction in bass, period. That is sound quality loss to me. My harness was not plug and play. I could tell it was hand made. I do not recommend the harness to others. My experience, my results, my opinion.
04-28-2016, 03:05 PM | #39 | |
Rep 2,942
Also worth consideration: the DSP in the HK system is biased toward bass, mids, and high-mids. It cuts mid-bass and treble significantly. Why? Because the OEM speakers can't handle those frequencies, and the HK tweeters are harsher than most partially because of low quality. I would suggest searching through this subforum on 2Addicts to learn about the HK system that's standard in the M2 -- and available on every 2 Series car as an option. The system is not built for an audiophile's ears; it's built for low-density, low-bitrate digital music and integration with the car's other audio systems (ASD, Bluetooth, iDrive sounds, etc.) -- and at a price point.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
04-28-2016, 08:25 PM | #40 |
Rep 173
04-28-2016, 10:04 PM | #41 | ||
7906
Rep 11,785
I actually am an audiophile, and while I can definitely see perhaps removing the ASD circuit via a bypass if I were going with aftermarket components .. It seems that the preferred method for Joe bimwad that isn't an audiophile, [in other words , anyone reasonably happy with the stock stereo , ] should just have this coded out. |
04-29-2016, 11:16 AM | #42 |
Rep 3,949
So if you like good quality sound knowing the M2 is louder to start with than the M235 which should you do? code it out or bypass? I will be changing the speakers with the Bav kit.
04-29-2016, 07:16 PM | #43 |
Rep 2,672
It is unbelievable that M car has fake sound and we need to disable it to hear actual sounds. Why remove sound deadening and install asd. Marketing dept needs to be fired! So annoying ...
04-29-2016, 09:03 PM | #44 |
Rep 173
Having disabled ASD, I'd say not just having it but cranking it up makes a lot of sense to cover up all the road noise from the absent sound deadening material. Do I prefer road noise to fake engine sound? Hell yes! Would the average $55k+ car buyer rather think they're hearing a gnarly engine instead of experiencing the sound of a basketball being dribbled at an indoor gym every time they go over a seam in the pavement? Probably. To each their own. For me, no ASD. Given the controversy, it seems this should have been a setting that's easy to toggle.
