05-20-2020, 05:40 PM | #45 | |
Rep 1,336
Regardless I'm keen to see what BW is supplying for the fix and would be great if you can supply some happy snaps before and after of the items since I have not fitted mine yet Any ideas when you will pull the trigger
05-20-2020, 10:44 PM | #46 | ||||
Rep 78
Drives: 2020 BSM M2C
planning to pull the trigger as soon as im done configuring the setup with bw! as long as there isn't a covid-delay on anything, should be pretty soon |
05-21-2020, 05:00 AM | #47 |
Rep 1,336
Ah ok. It is a rear sway bar replacement. Depends how hands on you are there is some threads on this forum for the process. If you have a decent jack you need to lower the rear cradle with diff enough to slide the sway bar through on top of the cradle. It's a decent amount of work but doable at home if need be.
05-21-2020, 05:11 PM | #48 |
Rep 78
yup, looks like it is the rear sway bar + end links. they really are thorough at BW. they set me up with everything ill need, down to the bushings! Wonderful experience ordering high-end car parts.
It is going to be a perfectly-tight fit! Thankfully, I found a local shop that will help me do it, so i dont have to deal with it alone at my house lol also, thank YOU for making this thread! i went down a similar rabbit hole and noticed your name in a few places haha |
11-15-2020, 06:03 AM | #49 | |
Rep 1,336
11-15-2020, 06:33 PM | #50 |
Rep 78
no pictures, but i do have a list somewhere. however, my rear setup is just the coilover with helper spring and rear endlinks to clear the sway bar from the springs
11-16-2020, 12:20 AM | #52 | |
Rep 1,336
11-16-2020, 01:52 PM | #53 | |
Rep 78
And if they can't help, ill just send you my parts list so you can order what you're missing |
11-16-2020, 01:59 PM | #54 |
844
Rep 1,962
Would it be easier to just use that damper in the intended place and use a height adjustable spring perch and helper spring in the conventional mounting location? I'm guessing that the delta in theoretical performance between CO and separate systems must be significant to make this much hassle worthwhile?
