M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Square Track Set Up 19's?
      01-31-2023, 04:47 PM   #1
kelly_aurora
Is anyone running a square 19 set up for track for M2C? What specs?
Thanks.
      02-05-2023, 05:13 PM   #2
madwheeling
Drives: 2020 BMW M2
Apex 19x9.5 ET28 with 275/30R19 tires, 3.2 front camber. I am thinking of trying a 10.5" with the 275/30 square to get better tire wear. If I keep the 9.5 I will only run a 265 tire in the future.
      02-14-2023, 05:33 PM   #3
Ratkiller
Drives: 2020 BMW M2 Competition
10.5 is a lot of wheel for the front. I'd be interested in know the specs if you can make it fit with out rubbing.
      02-14-2023, 07:16 PM   #4
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
I'm still waiting for someone to try our 19x10 ET40 front and rear. Downside is it takes large front spacers and alignment adjustments to work, but it should be doable. 18x10 ET33 on our flow formed EC-7s is fairly common on the OG m2s, but the spacers needed aren't quite as large.
-Tom
      02-15-2023, 10:59 AM   #5
dead.pixel
Drives: 2021 BMW M2 Competition
-Tom
Would this only be possible on a VS-5RS? It's the only wheel I see on your site with 19x10 ET40. (hoping you will add an EC-7 in that size)
      02-16-2023, 11:56 AM   #6
Expert@ApexWheels
3530
Drives: M3
Correct, for now the 19x10 ET40 would be VS-5RS only. 19x10 ET40 EC-7 is a wheel we've talked about potentially offering in the future so I'll keep your feedback in mind!
-Tom
      02-16-2023, 12:22 PM   #7
madwheeling
Drives: 2020 BMW M2
I am going to try the stock 10" rear on the front before ordering the 10.5" It will not be for a few weeks because the car is still put away for the winter. I think 275's with a 9.5" is causing a lot of my tire wear issues. A 9.5" should be running a 255, even a 265 seems like a bit of a stretch when it comes to a true track tire.
      02-17-2023, 06:28 AM   #8
PackPride85
Plenty of guys run 9.5” without bad wear at the track. Depends a lot on driving style. Camber plates are usually the next step.
