01-09-2021, 02:42 PM | #1 |
Rep 2,856
G-Power states they have a OPF-Delete solution...
G-Power has shown on its website a OPF-Delete solution.
I have asked them a lot more information about it, because I am aware how hard it is to make a solution that is 100% failsafe and never throws an error on your display or a limp mode. Let's see what info comes back! I hope it is a solution that will help all those people with locked ECUs and who don't want to tune their M2C or M2 CS. MR |
01-10-2021, 06:36 AM | #6 | |
Rep 9,709
I suspect BMW have mapped a table in the ECU with a standard response value and then added a plus minus tolerance. Some testing is required, but I would guess a mechanical option of relocating the pressure tubes to before the primary cat would probably work. Option 1. By the way, for all options, you only need to do this on one sensor and link the two together. Another option is to connect the secondary (unused) port to a slight vacuum (intake tube or air box) which would return a higher reading once OPF's are deleted. Third option is to elbow the exhaust sensor tubes facing upstream. This will add dynamic pressure. Option 4, fit lower scale sensors from same supplier. For example, change a 1000pa sensor for a 750pa sensor. The 750 will return a higher 0-5v reading for a lower pressure. Provided ambient pressure is around the same value, it should work. Option 5, fit a CAN module that has 0-5v output. This programmed to read load from CAN and output a suitable 0-5v output directly into the sensors. I suspect AK Motion does something similar to this. The leads in the above link. No idea what they do, they just look like leads. Without some electronic module built in I can't see how they would work. |
01-23-2021, 10:04 AM | #8 |
Rep 57
Greetings!
I have contacted LEIB pefromance about their OPF delete solution. https://www.leib-engineering.de/en/l...mpetition-f87n And this is their response: We tested our deleters with stock software and without OPF for more than a year now. We tested on several different BMW cars with different engines and we had no problems with CEL or limb mode. The princip of the deleter is that the pressure sensor can’t show the low pressure any more to prevent the limb mode. |
01-23-2021, 10:31 AM | #9 |
Rep 2,856
Yes today,
"what I can tell you is that the OPF deleter avoid the changed pressure in the exhaust gas system due to the missing OPF. This works and the first OPF failure is solved. Currently we run a long-term study with a own M2, clients and international dealer to check if the ECU will note the second failure after a time that the OPF is defect. With this failure, the M2 S55 will go directly in the hard emergency program. Currently it looks very good but the final evidence is still open." MR Last edited by MR.; 01-23-2021 at 11:26 AM.. |
01-23-2021, 10:34 AM | #10 | |
Rep 2,856
Looks different from what G-Power is offering. MR |
BMW19736.00 |
01-24-2021, 10:18 AM | #11 | |
Rep 57
Yes it is our own development. Every other dealer or tuner in this world is in contact with us to buy our OPF Deleters. The price in our shop is the retail price, but other dealers or tuners may have a higher price. |
02-17-2021, 03:12 AM | #12 |
Rep 1,477
Any updates? Someone is using these OPF deleters?
02-19-2021, 06:24 PM | #13 |
Rep 8
I guys, i'm from Italy and i see now this post.
I want to install aftermarket exhaust for eliminate the opf's filters! Someone has tested one of these products? Thanks |
02-23-2021, 12:15 PM | #15 |
Rep 2,856
Nope nobody has tested any of this. It is an interesting one...
I am done testing things like this on my car for now. My car has no warranty anymore and run a tune. MR |
02-23-2021, 02:36 PM | #16 | |
Rep 658
If the AK-motion unit resolves completely the OPF delete issue and there is zero headache with warranty while visiting BMW dealer as a result, then why bother yourself with this new thing? Or is the AK-motion unit not eliminating the problem of OPF delete? |
02-28-2021, 06:38 AM | #17 | ||
Rep 154
But other than that the AK unit is complicated and time consuming to install, where this unit is easy fast and plug and play. I have the AK unit sitting at home waiting for my mid pipe install, but if this works I'll get it Instead of the AK. |
02-28-2021, 06:41 AM | #18 | |
Rep 658
Which midpipe are you planning to install? And why do you need AK motion unit? Do they sell M2Cs in Israel with OPFs? |
02-28-2021, 09:11 AM | #19 |
Rep 13
LEIB Engineering
I spoke few days ago with Dominik Leib the CEO of LEIB Engineering.
He sounds like a solid person, so I ordered two units (for two cars) of the LEIB OPF DELETER for BMW M2 Competition. This is the link: https://www.leib-engineering.de/en/l...mpetition-f87n I also ordered another interesting devise: LEIB CAN EXHAUST PRO valve flap control for BMW M2 Competition | F87N, it's main functions: EXHAUST VALVE FLAP CONTROL START STOP OFF STAGING DELETER | The error entry that occurs by changing the catalyst(s) will be disabled - no error entry, no check engine light (CEL) And TEMPERATURE GAUGE that allows you to choose between: • Engine oil temperature [1] • Intake temperature [2] • Transmission oil temperature [3] • Cooling water temperature [4] • Exhaust temperature [5] I will post my impression after the installations of the OPF DELETER letting you guys know how it works and ease of installation.. |
LakiTopalovich64.50 |
02-28-2021, 02:45 PM | #20 | |
Rep 658
But why would one buy two items from Leib Engineering for €300 + €500, when AK motion unit costs €409 (with OPF delete cable) and does the same job and on top of that you get a convenient screen which shows different parameters and makes the whole operations more convenient? Leib Engineering: https://www.leib-engineering.de/en/l...mpetition-f87n https://www.leib-engineering.de/leib...tition-f87n-en AK Motion: https://burkhart-engineering.com/en/...l-competition/ https://burkhart-engineering.com/en/...ion-f8x-m3-m4/ |
03-01-2021, 03:53 AM | #21 |
Rep 13
You have a good point but:
I read on sum negative AK feedback regarding OPF cable connectivity issues through installation problems and not having the best customer support. The main thing I am not willing to block my A/C vent. |
03-01-2021, 04:24 AM | #22 | |
Rep 9,709
If all you want is the override features, just Velcro the screen under the passenger footwell panel. You don't have to touch the AKM for it to work. |
