11-24-2020, 11:16 AM | #111 | |
Rep 467
CCB discs last 3 track days you should know !!! 13 k€
///M2 CS MB - M-DCT-2 NH - GLD 763M - Cup2
Bimmed Out1908.50 |
11-24-2020, 11:37 AM | #112 | |
There Is No Substitute
1909
Rep 1,070
///M2CS1151.00 |
11-24-2020, 11:48 AM | #114 |
Rep 275
Come on this is total BS, it's hearsay stories like this that get the misinformation going.
As a track veteran and service professional I can tell you I've never seen this happen. For example I've a friend with a M4 GTS that's 4 years old got over 20 thousand miles and 5 or more track days, his pads are just past 50% worn and his rotors are just fine. Another customer with a 997 GT3, 10 or more track days per year 4 years no issues, I replaced his pads annually at approximately 50% Simple rule, occasionally tracking CCBs is fine. If your a track rat doing 20 plus days a year then steel is the smartest choice unless you've got enough $$$ that you don't mind the expense |
BishUK440.00 MadBimmeRad7121.50 |
11-24-2020, 11:50 AM | #115 |
Rep 467
this is indeed paradoxical and makes these BMW carbon discs a marketing product some in this forum have been fooled by this proving that dealers are very good at selling unnecessary options
Bimmed Out1908.50 |
11-24-2020, 11:53 AM | #116 | |
Rep 467
LukasM2CS73.50 |
11-24-2020, 11:56 AM | #117 |
Rep 405
To my SA's credit, he discussed it with the knowledgeable staff at the dealership and advised me against CCBs. I had told him the car will be year-round use. They advised I would likely be unhappy with cold/wet performance.
Bimmed Out1908.50 |
11-24-2020, 11:59 AM | #118 | ||
Rep 275
I have no potential benefit in any outcome |
11-24-2020, 11:59 AM | #119 |
Rep 467
finally a supposed opinion outside the marketing discourse!
11-24-2020, 12:03 PM | #120 |
Rep 467
I am not a car professional but I do 10 track days a year with a share with all the other participants if carbon discs were the panacea, it would be known
11-24-2020, 12:07 PM | #121 |
Rep 275
My post is in response to the suggestion that 3 mild track days would result in 2 pad replacements and potential rotor damage.
Im not debating about tracking superiority. |
11-24-2020, 12:13 PM | #122 | |
Rep 467
But in mild use what’s the interest of CCB brakes vs Steel brakes ?
11-24-2020, 12:16 PM | #123 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
This has been debated over and over again. Good to see more input but as far as I can tell it comes down to this: 1. Price? 2. Track rat? Better to not select them. Street car? then see question 1. My car will spend most of it's time in the canyons, so I'm excited to have the lightest M2 possible (going with MT also) and no brake dust on the gold wheels.
11-24-2020, 12:24 PM | #124 | |
Rep 467
01-13-2021, 01:25 AM | #126 | |
Rep 1,418
01-13-2021, 01:34 AM | #127 |
Rep 1,348
Swap the pads and disks and you're there. But it's probably cheaper to buy the full retrofit kit: https://www.getbmwparts.com/oem-part...it-34112358378
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
01-13-2021, 01:52 AM | #128 |
Rep 900
Can someone confirm
1. It comes with stainless steel brake line for ceramic brake ? 2. Rotor size is 400mm for ceramic Thanks in advance Last edited by twboy1999; 01-13-2021 at 02:08 AM.. |
01-13-2021, 02:10 AM | #129 | |
Rep 1,078
01-13-2021, 06:11 AM | #130 | |
Rep 4,668
01-13-2021, 08:22 AM | #131 |
Rep 3,335
Notice they don't explain the details on rotational mass in the BMW link. For an engineer, it leaps right out at you when you see all the discussions on line -- a very important variable in rotational mass discussions is the radius of gyration. The radius of gyration is the radius where the rotational mass can be considered located in the basic moment of inertia calculation (i.e. I = m k^2, where m is mass and k is the radius of gyration).
Note that the moment of inertia is a function of the radius of gyration to the 2nd power; hence k has a large effect on rotational inertia as it changes. In the case here a quick estimate of k for the front brake rotor is about 150mm or 5.9". If you wanted to compare mass located at that k versus say the same mass located at roughly the wheel k, it's k1^2/k2^2. If we consider a 19" wheel to have a radius of gyration located at about 8.5", then popping in these approximate numbers yields 0.48; hence the rotor weight is only 48% as important as the wheel weight in this approximate example. Put another way, wheel weight contributes 2.1 times more to rotational inertia than disc weight. This is all back-of-the-envelope quick estimates. However, the effect of radius of gyration is very important in moment of inertia calculations and shouldn't be left out of information any source is providing on "rotating mass" changes. It's somewhat analogous to the way aero drag coefficients are bandied about by car makers, etc. Comparing two different cars, say one with a Cd of 0.30 and the other a Cd of 0.33 is perhaps "interesting" from an aero design perspective, but without the specified frontal area of the two cars, it tells you absolutely nothing about the aerodynamic drag comparison of the two as the car with the lower Cd could actually have a similar or larger aerodynamic drag...you just don't know without specification of the frontal area. Sorry...pet peeves of two commonly misunderstood (marketing exploited too) things in the car world.
Current Stable:
01-13-2021, 08:50 AM | #132 | |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
M2CS,
The second coming of ///M! |
