05-15-2021, 09:03 PM | #2575 | |
Rep 500
I sent a support message to BC. Hopefully an update to the app is in the works. |
05-15-2021, 09:14 PM | #2576 |
Remove Before Flight
6822
Rep 1,611
Query:
If the dealer reflashes to reset/eliminate Bimmercoding, will that also reflash the engine DME? i.e. If I have a Carbahn tune installed, but want to update to the latest software, can I do it without nuking the Carbahn tune? I don't think so, but I figured I'd ask. TIA-- R. |
05-16-2021, 07:44 AM | #2577 | |
Rep 4,551
Drives: 2015 328d xDrive
NYC Bimmer259.50 |
05-16-2021, 11:41 AM | #2578 | ||
6822
Rep 1,611
So, if I wanted to keep the DME (CarBahn engine) tune, but update all other software (i.e. wipe out all BimmerCode updates and return all settings to stock) what (specifically) would I tell the dealer to do? Thanks. R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
05-16-2021, 12:17 PM | #2579 | |
Rep 4,551
Side note: if your only goal is to wipe out all of the coding you've done (and the updated software is of no importance to you) that could be easily done in ESYS by you or a coder, and it wouldn't require any istep updating.
NYC Bimmer259.50 |
05-18-2021, 02:29 PM | #2580 | |
Rep 500
"Hi, please use "Check for update" in the settings in the app and perform a data update" The next time I opened Bimmercode, a prompt within the app automatically suggested an "update". All modules are now available and I was able to code as needed. |
AndrewC198910931.00 Rumbloki176.00 |
05-18-2021, 04:03 PM | #2581 | |
Rep 4,551
NYC Bimmer259.50 |
09-29-2021, 08:37 AM | #2582 |
Restless
1335
Rep 1,031
Hi all, quick question...have used Bimmercode for various cars in the past. A couple of weeks ago I used it to do some light coding on my new M2C. I went back in this morning as I wanted to make a couple of tweaks but I was not able to code anything. I got into the app fine, it connected to the car fine, the menus all look the same...but when I go into a specific module, the code button on the top right is greyed out, ie cannot click on it. Tried it for several other modules, same thing. So now I am "stuck". Any ideas? TIA
10-10-2021, 10:55 AM | #2583 | |
Rep 193
I have the identical issue after coding with Bimmercode (not using expert mode either) :-( |
10-10-2021, 10:59 AM | #2584 |
General
10445
Rep 40,789
Drives: 2018 Alpina B6 650ix GC
You need your original factory issued Map FSC Code file. PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-21-2021, 09:18 AM | #2585 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Only ? for those who have coded very recently, were you able to turn off ASD w/ bimmercode?
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
12-21-2021, 01:09 PM | #2586 | |
Rep 8,970
Don't "disable" ASD with Bimmercode option as it can be difficult to restore it without Esys. Simply select a different engine type in ASD options, this will stop ASD from working and you can simply reselect S55 when you want it back on again. |
12-23-2021, 10:37 AM | #2587 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Thanks but I have no plans to restore it.
07-13-2022, 08:37 PM | #2588 |
Rep 60
Hi. I know this is old. But can I use this to reflash a. Issue after a mechanics replaced my E70 X5 air compressor which now triggered a faulty fuel sensor code and the sticking rear windows. Fuel guage now errors to empty with check engine o. For fuel sensor high.
I wanna be able to reset my ECM without having to pay the dealer to reflash my computer. Will bimmercode work? |
07-14-2022, 02:33 AM | #2589 | |
Rep 8,970
Or Esys for module flashing. Or maybe older stuff for E series. |
07-31-2022, 03:48 PM | #2590 | ||
Rep 110
09-13-2022, 08:09 PM | #2591 | |
Rep 7,298
09-14-2022, 06:10 AM | #2592 | |
Rep 8,970
But since about 2016/17 they locked this so if you select any other engine other than the correct one it just blocks ASD, turns it off. So in that respect its better to turn off ASD that way in bimmercode than use the "disable" command which then you can't put it back on again. |
09-14-2022, 05:38 PM | #2593 |
Rep 2
Hi all, I currently have bimmercode and was wondering how I could use bimmercode to code the mirrors to fold in on locking the car with key fob and Comfort access while keeping windows rolled down until held for a couple seconds. Currently, Bimmercode has let me set up the car so that both windows and mirrors fold in simultaneously and I pretty annoying when I want to leave the windows cracked in hot weather.
09-15-2022, 12:35 AM | #2594 |
Rep 8,970
Mine does that standard?
Shorter press for mirrors. Longer press for windows up. But when Windows are rising they stop when your let go of fob button anyway so you can leave them cracked that way. |
11-20-2022, 04:24 PM | #2595 |
Rep 552
I used to have a Vgate that worked well, until the support was discontinued and I finally made the transition to UniCarScan 2100. It arrived last week, but I can't seem to get my phones to connect to it. It will pair, but it will not connect. Comes up with being able to enter the "1234" to pair, but just can't connect. I'm using a OnePlus 7, and a Samsung S22. Anyone have any ideas?
Also, having the M2C, do I still select M2 for coding? I was confused for a bit seeing as it has the S55 engine, I thought i might need to select M4/M3. |
02-08-2023, 01:52 PM | #2596 |
~Spyder
638
Rep 870
Drives: '19 M2C Hockenheim 6sp
Gang - silly question here, so I’m not sure if this a German/English translation thing…but I am trying to double validate that ASD is off. IMO, wording could be improved for clarity.
The attached screenshot of BimmerCode…does that mean ASD is off? I read the statement as ‘ASD Deactivation’…a binary yes or a no ( is ASD active or not). Also, BimmerCode does not allow me to change the setting…and I apparently I don’t have a backup to revert back to. I have both BimmerLink and BimmerCode; in BLink, the ASD setting is OFF. Do they affect each other?
Skål från Sverige...via Texas y-all
