03-27-2021, 11:37 AM | #221 |
Rep 3,696
Ahh. I’d been seeing that too when starting third gear pulls. Pre-throttle boost had been hitting 23-24psi in several guys’ logs, while he was using throttle closure to keep manifold boost pressure at target.
Seems like this started when he released the 6MT no shift lag update, which keeps boost high in the intake tract for no lag/shift delay. No harm possible to the car, just sounds like he’s just dialing it in a little more so he doesn’t have to lean on throttle closure and boost control as much when pre-throttle spikes up. I’ll be looking forward to V6.0 once you all dial it in! |
03-29-2021, 10:51 AM | #222 |
Rep 3,696
For any stock turbo guys not going for big power, but want to keep fast spool a little bit better top end than stock, check this out: https://x-ph.com/vargas-n55-stage-1-jb-upgrade-kit-new/
Looks like turbo + install could be ~$1500 all-in, which is pretty good! And, I'm sure if you ping Mike at XHP he'd hook you up with more goodies. |
03-29-2021, 11:05 AM | #223 |
Rep 109
Great option and deal. I'll probably go that route, want to wait to see what all the hype is about the pure 800 is when it's available.. then choose
03-29-2021, 12:40 PM | #225 |
Rep 3,696
The xph sale shows $1028 for those options on my side.
And, it’s an easy install, so $1500-$1600 all in gets it on the car if you’re taking it to a shop. Altho, you should do the turbo inlet and DV at the same time, and that’s where pinging Mike directly can get you some deals on the other items. Last edited by ZM2; 03-29-2021 at 12:45 PM.. |
03-29-2021, 02:17 PM | #226 | |
Rep 643
M235i rwd 6mt
03-29-2021, 02:20 PM | #227 | |
Rep 3,696
The price for the Vargas is pretty good, tho. Certainly cheaper than what I paid for my Dinan 3-yrs ago. |
03-29-2021, 06:19 PM | #228 | ||
Rep 362
https://www.bootmod3.net/log?id=6062...90c66e5551a349 https://www.bootmod3.net/log?id=6062...729b0a679d58de |
03-29-2021, 06:53 PM | #230 |
Rep 362
03-29-2021, 07:55 PM | #231 | |
Rep 3,696
There is some timing pull as IATs get >90F, and I think you're just seeing some new tune adjustments that Halim is incorporating as IATs get high. All you can do to combat that is get a larger FMIC or add more ethanol to see if it helps, but I don't think you have to worry about it hurting your car if you're just street driving and doing some pulls here and there. |
JKen_0115176.50 |
03-30-2021, 01:30 AM | #232 | |
Rep 2,577
Be peaceful in mind. Test again in summer.
Lemania 2320
JKen_0115176.50 |
04-02-2021, 02:49 PM | #233 |
Rep 2,526
Now that my Nostrum HPFP is available in the BM3 OTS maps. I'm going to schedule some dyno time to do some pulls with Stage 2+ E30 and see how it looks.
Additionally, I reached out to PTF to check on the status of their latest stuff on the N55 platform (antilag, flex-fuel, multimap, etc). They said its their current project, while they do not have an ETA right now, its being actively worked on. Hoping they get it out soon so I can test that as well |
04-02-2021, 03:03 PM | #234 | |
Rep 3,696
04-02-2021, 04:04 PM | #235 | |
Rep 2,526
Looking like I may be able to get on the dyno next week. |
ZM22813.50 |
04-03-2021, 11:29 AM | #236 |
Rep 109
What did the noise sound like? I'm hearing a noise from that area (only when I accelerate)ever since I installed my dorch stage 1.. kind of metal/chirp whistle and it's driving me nuts..its not the belt and or tensioner either.
04-03-2021, 05:17 PM | #237 | |
Rep 602
04-04-2021, 01:11 PM | #239 |
Rep 3,696
Nice day out, did my first launch control launch with the OTS map.
Let’s just say I shouldn’t have to worry about breaking anything bc it completely shredded my 285 4S’s thru first & second, even with launch control on! Hah! |
04-06-2021, 09:42 AM | #240 |
Rep 415
I’m trying to chase up bm3 support and Dorch about getting the new calibration integrated into the bm3 Dorch settings. Hopefully they pull through and sort it soon.
04-07-2021, 11:20 AM | #242 |
Rep 668
Thanks for all the R & D you guys have done on the N55. I no longer feel the need to change to an M2C.
https://www.bootmod3.net/log?id=606d...90c64f83358aaf https://www.bootmod3.net/log?id=606d...90c64f83358aaf https://www.bootmod3.net/log?id=606d...0b4361e70b7c93 Forgot the logs in case someone would like to comment on them I have send them to PTF also but havent heard back yet. Last edited by koastal; 04-07-2021 at 11:59 PM.. |
ZM22813.50 |
