07-11-2020, 03:11 AM | #2 | |
Rep 7,431
1) Using ISTA which is free, there are tutorials online on how to use it and Shawnsheridan can help you get you ISTA for free. 2) There is a software free way to do it but I have no idea if it works as I always use ISTA for everything: https://www.bimmer-tech.net/blog/ite...remote-key-fob Note: If you lost your old key or are planning to dispose of it you must use ISTA to erase the old key from the car.
black ming59.50 |
07-12-2020, 10:52 PM | #4 |
Rep 7,431
Bmw's factory diagnostics program for dealership use.
07-13-2020, 06:10 PM | #6 |
Rep 7,431
+1
At this point what I would suggest is that if the bimmertech method does not work to activate your key, I would bring it to the dealer or maybe contact a coder who can do it remotely. I think steve@codemybimmer might be able to help you although I do not know if he can use ISTA remotely.
07-13-2020, 06:38 PM | #7 |
Rep 7,431
I also wanted to ask, where did you get your key fob? Because if you purchased a used key I think you may be out if luck because iirc the key can only be written to one car.
07-13-2020, 10:44 PM | #9 | |
Rep 7,431
But remember the old key is still connected to your car, so if you plan on discarding it without deleting it from the car (which needs esys) you will have to thoroughly destroy the key and all the transponders and chips inside. If not just keep the key in a safe spot.
