05-30-2020, 10:23 AM | #2091 |
Rep 39
Decided to tackle a DIY with ambient lighting. A ton of work but the end result was well worth it.
18
flybigjet6745.50 ChrisK4449.00 cptobvious2531.50 Kattanah137.50 Fuji550i389.50 beni51874.50 AZ-Wildcat619.50 ///AVM2528.00 mnbrennan43.00 M2COMP496.50 mzcp2660.00 SilverScotty320.00 Detoxified202.50 AUSf222688.50 m20e30871144.00 LakiTopalovich64.50 Aust350z243.00 DARKMTTR229.00 |
05-30-2020, 04:24 PM | #2092 |
Rep 618
05-30-2020, 06:22 PM | #2093 | |
Rep 11
haha- I also live in SF and I think I saw/heard your M2C rip by me on Portola today? sounds good if that was you.
2020 M2C HS 6MT- Ohlin R&T, AA Midpipe, Apex EC-7 w/ Cup 2's, SS brake lines, Pagid RSL29
SFM2C6MT175.00 |
05-30-2020, 06:28 PM | #2094 | ||
Rep 95
05-30-2020, 07:05 PM | #2095 |
Rep 197
Installed the pedals today. Started to question my sanity trying to drill through the metal brake pedal. Tried to step up the holes which took forever. On the last one I just used the punch mark I made and started with a smaller bit and jumped straight to the 5/32. It cut through the pedal in seconds. Lesson learned. Ignore the dirty floor mat.
Went for a drive and could feel the extra 10hp. |
05-31-2020, 02:36 AM | #2096 |
Rep 1,477
Stretched her legs after the quarantine (top speed governor)
05-31-2020, 06:50 PM | #2099 |
Rep 1,369
That is a must do feature when I finally get my M2C. Do you know if it will reset to half screen CarPlay during an iDrive update or when the dealer does a rest during maintenance?
IG: @rise_n_drive
05-31-2020, 07:52 PM | #2100 |
Rep 618
That I'm not sure, I'll assume so. It took me almost 2 years to do this as I liked the split-screen with Waze and Spotify. But I like the full-screen look of Waze.
06-01-2020, 01:15 AM | #2101 |
Rep 2,104
US Millworks Tow Hook Mount with quick release in custom white.
Poochie9103.00 Artislife903.00 |
06-01-2020, 01:17 AM | #2102 |
Rep 43
06-01-2020, 12:07 PM | #2103 | ||
Rep 39
The kit I used had a single control module that controls 4 LEDs (one for each door and one for each side of the console). I ran power from the 12v adapter in the rear of the center console since I didn't want to splice into any wires. The wires are all hidden under the center console and the main control module is hidden under the cup holder. I then ran power from the center console under the foot wells and through to the doors via the rubber harness hose (this was pretty tough). The project requires a ton of trim removal, but if you're up to it the result is well worth it. I'm happy to provide more info for anyone who would like to know more. |
LakiTopalovich64.50 |
06-01-2020, 04:24 PM | #2104 |
Rep 76
Re-trimmed in alcantara with orange stitching and thinner diameter, feels much better now
4
06-01-2020, 06:19 PM | #2105 |
Rep 839
New goodies came —
06-01-2020, 08:49 PM | #2108 |
Rep 70
I just tested my M2C against the new M340 in the 1/4 mile, the results.... not so good for the m2 check the video.
https://g20.bimmerpost.com/forums/sh....php?t=1726306 |
06-01-2020, 09:22 PM | #2109 | |
Rep 839
Really_fat_ninja404.00 |
06-01-2020, 09:31 PM | #2110 |
Rep 1,083
Installed the door/fender EVA foam seal. The engine/auto downshift sound has soften, the suspension when going over bumps has quiet down, wind noises are down, and even the cars next to you is quieter. It's rather shocking how much noise this pair of foam has taken away.
4
06-02-2020, 02:03 AM | #2111 |
Rep 1,477
06-02-2020, 02:34 AM | #2112 |
Rep 76
Thanks, yeah i wanted to retain the heated steering wheel and have been able to do so. The only restriction was the fact that i wasn't able to install a 12 o'clock marker because the heating panels would have had to be removed.
Poochie9103.00 |
