10-14-2022, 10:34 PM | #155 |
Rep 7,301
Have you done any reading on the Bob Is The Oil Guy (BITOG) forums?
I have never seen a UOA with Amsoil that was better than achieved with M1 0W-40, German Castrol, etc. I just don't see any real evidence their oil is any better than the big players. If you are not under warranty or don't care about LL01 for warranty purposes, then there are still other better choices I think. I'm sure it is fine and works well, but the specs aren't anything special and the marketing feels like a cult sometimes. Not many race teams use their oil either... |
10-14-2022, 11:21 PM | #156 | |
Rep 1,487
AZF has fairly high KV100 for HTHS that it offers (3.76). For example, Pennzoil Platinum Euro 5W40 has KV100 12.8 and HTHS 3.88. Since HTHS is the most important value when it comes to wear, it is telling that Amsoil has to go so thick to get to value that other can easily extract from thinner oil. Don't forget golden rule of lubrication: as thin as possible, as thick as necessary. EFO looks better bcs. KV100 of 13.3 and HTHS of 3.7 is right there with top blenders. But, Noack is 9.9. That is poor result for a blender that claims to be best thing after sliced bread. Interestingly, Noack of AZF is 7.7% which is actually exceptional result, but then KV100 and HTHS values are not as good. Obviously they have issues blending oils on par Mobil1 0W40, Castrol 0W40 or Pennzoil Platinum Euro 5W40 as well as Motul X-Cess 5W40 GEN2. Pour point of both oils indicate less PAO than in Mobil1 0W40 FS. Amsoil is around-50, while M1 0W40 and Castrol 0W40 API SN version are around -60. Lower pour point indicates more PAO, or as some say here "true synthetics." So yeah, this oil from company that claims to be "tru synthetic " blender, has more Group III than others. If being "true synthetic " is paramount, High Performance Lubricants is way to go. |
10-15-2022, 01:47 AM | #157 | |
Rep 1,356
10-15-2022, 02:15 AM | #158 | |
Rep 7,301
Castrol Edge 0W-40 or M1 0W-40 should be pretty good though. It’s not that I doubt Amsoil is good, I just haven’t seen any data to justify the claims and price. If I was going to run a boutique oil I’d look at HPL or Redline before Amsoil. |
F87source7292.50 |
10-15-2022, 02:41 AM | #159 | |
Rep 7,460
chris7197345.50 |
10-15-2022, 02:55 AM | #160 | |
Rep 1,356
chris7197345.50 |
10-15-2022, 03:40 AM | #163 |
Rep 7,460
mobil1 0w40 is a really good oil that is heavy in pao, but I wouldn't use it on a direct injected car because it is really high in SAPS, and that means carbon build up is worsen.
Then again the ams oil was known for being high in SAPS too. I personally would have went with the castrol 0w40 instead (if I didn't get PPE 5w40/shell helix ultra 5w40), because it too is pao heavy and a really solid oil. But SAPs are minimized so it isn't an issue.
10-15-2022, 04:03 AM | #164 |
Rep 929
I go with olive oil unless for track, then I switch to avocado as it's got higher smoke point
chris7197345.50 Fred Conoway365.00 |
10-15-2022, 07:23 AM | #165 | ||
Rep 1,487
However, much better oils out there is street driving is focus regardless of little track time. HPL and Amsoil are both suited better for street use than 300V or Sport. |
chris7197345.50 |
10-15-2022, 07:26 AM | #166 | ||
Rep 1,487
chris7197345.50 |
10-15-2022, 04:06 PM | #167 | |
Rep 7,301
10-15-2022, 04:25 PM | #168 |
Rep 7,460
That's true, but its better to play on the safer side. So N54 which is known to struggle with carbon build up it is better to stay clear. The N55 (depends on if your car makes alot of blow by or not, as it is extremely variable on these engines) then that should influence your choice here, and for the S55 same thing as the n55.
10-15-2022, 04:36 PM | #169 | |
Rep 1,356
10-15-2022, 04:47 PM | #170 |
Rep 7,460
Yes it will, oils with lower NOACKS have lower volatility and thus less chance to end up in the PCV gasses. Oils with lower SAPS have a lower chance of causing build up even if they do end up in the PCV gasses.
10-15-2022, 05:01 PM | #171 | |
Rep 1,356
Diesel engine without egr does not accumulate carbon in the valves no matter what oil you put in it, and no matter the mileage. |
10-15-2022, 05:14 PM | #172 | ||
Rep 7,460
In the case of combating carbon build up, yes oil can indeed help if you chose an oil with a low NOACK and low SAPS it can indeed help combat carbon build up. The same thing with quality gasoline and good additives, cleaner burning fuel means less crap in the PCV vapors to cause build up on the valves.
KevM2724.50 |
10-15-2022, 05:38 PM | #173 | |
Rep 1,356
To combat the problem, you need to take other measures that have nothing to do with the NOACK and the SAPS of the oil, and for that reason diesel engines do not accumulate carbon in the valves regardless of the oil you are going to use. |
10-15-2022, 05:48 PM | #174 | |
Rep 7,460
From the collins dictionary: Combat (https://www.collinsdictionary.com/di...lish/combat:): 3. VERB If people in authority combat something, they try to stop it happening. Congress has criticised new government measures to combat crime. [VERB noun] Synonyms: fight, battle against, oppose, contest - Notice there are no indications here that the problem must be erradicated. Read the sentence that they provide as well. Eliminate (https://www.collinsdictionary.com/di...sh/eliminate): 1. VERB To eliminate something, especially something you do not want or need, means to remove it completely. To attempt and stop [or oppose, battle against, contest, etc] the issue from happening, oil choice and thus NOACK and SAPS rating indeed has an impact on trying to stop this issue of carbon build up from happening. Carbon build up is directly related to the PCV vapors, and that is generated by combustion gasses - which consists of OIL VAPORS (the higher the NOACK the more that will be in this mix, and the more SAPS the more carbon build up becomes an isse) + gasoline vapors. If you can affect one part of that equations then you absolutely can help combat carbon build up. Can you do other things to combat the problem? Sure - oil catch cans help, water injection helps, etc. But saying NOACK ratings and SAPS ratings of oils do not help in this issue demonstrates little understanding of the issue. Now lets clarify some things, NOACK is a smaller contributor vs. SAPS because oil mist is more likely to be coming through the PCV rather than oil vapor due to volatility. However SAPS is still present in either scenario and these cause valve deposits. it's still a factor nonetheless. We are not and were not talking about elimination of the problem, which would be completely venting the pcv vapors atmospheric and blocking off the head ports.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 10-15-2022 at 05:56 PM.. |
10-15-2022, 06:12 PM | #175 | |
Rep 1,356
10-15-2022, 06:16 PM | #176 |
Rep 7,460
lol ok there buddy, seems like you are the only one that "knows" anything - despite being proven wrong for the last 2 pages of this thread.
