12-09-2022, 02:52 AM | #1 |
Rep 488
M2C MT - Post shift lag
Hi,
Due to M2 OG unfortunately being stolen, I am now considering getting an M2C. Please can people with the M2C manual (MT) car let me know their experience with the post gearshift lag? I have seen in this thread that a few people were reporting this issue in amongst a discussion about turbo lag:https://f87.bimmerpost.com/forums/sh....php?t=1812407 ( MrOhnoez, SilverScotty , CSBM5 , Burnside81 I see that you all mention it, but thought it worth starting a new thread focused on this particular issue) With the OG/N55 M2, the DME enforced post-shift lag was very frustrating, but fortunately, after loads of investigation by board members and evidencing, BM3 came to the rescue with a tune to dial it out for that engine. Please can you let me know: 1) Is the post shift lag only noticeable in 1-2 shifts, or is it felt in all gears? 2) Roughly how long does the lag last before power comes back online? 3) Can you share a log that shows gearshifts? 4) Does anyone know if a tuner has fixed this for S55 engines? Thanks loads! |
12-09-2022, 11:19 AM | #3 |
Rep 7,336
FWIW I am not sure if I notice this on the S55 or not. Sometimes I think I do but it's hard to tell. Is there an easy way to produce it?
12-09-2022, 12:55 PM | #4 |
Rep 1,392
12-09-2022, 01:29 PM | #5 |
Rep 7,336
12-09-2022, 03:18 PM | #6 |
Rep 3,361
It's torque management on a 1-2 upshift that I mentioned. Turn off DSC and quick-shift a 1-2 upshift at 7k in 1st (i.e. like you'd do at the strip)....max acceleration in 1st to 7k rpms, then lightening quick "throttle lift, slam clutch, snatch 1-2 upshift, clutch out, throttle pinned down". You'll feel a bog a split second since torque is managed. If not, it would of course blow away the tires like a car with this power output easily would (i.e. my E39 M5 would lay down 20 feet of 2nd gear rubber in similar upshift, and my E90 M3 will bark the tires loudly while also laying down rubber in 2nd). Normally one would have to carefully manage the throttle and clutch engagement rate going into 2nd gear on a car with this torque output and DSC off. As programmed, you can just go for it and not have to worry about it getting away from you in most cases.
It's not turbo lag...it's purposely programmed torque management, and it exists on the F8x M3/M4 6MT also. That said, it apparently doesn't really affect maximum acceleration since C&D was able to get the 6MT M2C faster than the DCT version by 0.1 seconds. The 6MT is better able to be launched, hooked up hard, than the DCT as they said (at least by a competent driver with lots of launching experience...).
Current Stable:
12-09-2022, 04:00 PM | #7 | |
Rep 7,336
12-09-2022, 04:39 PM | #8 |
Rep 1,392
12-09-2022, 10:12 PM | #9 |
your average JAMF
3185
Rep 4,110
12-09-2022, 11:08 PM | #10 | |
Rep 7,336
It's not magic like people say. It just does what it says, and that is slightly delay clutch engagement. Where it is noticeable is mostly modulating the clutch on takeoff from a stop, on a hill, or in reverse. The only other time I noticed it was the situation I mentioned, where with the CDV removed you get a more aggressive clutch dump on a shift. I'm confident if you drove two back-to-back you would notice it, especially in car with as much clutch feedback as that one. Where I disagree with the crowd is where they claim it fixes all kinds of ills like the 1->2 shift. It did nothing for me there, I only appreciated it in traffic or launching the car. I'm on the fence about doing the CDV on the M2C because I don't feel the delay as much as I did on the Z4M. I'd do it back and forth to test if it were still a separate little part and not part of the slave cylinder. It wasn't life changing but I preferred the car without it 100%. Last edited by chris719; 12-09-2022 at 11:16 PM.. |
widetyres280.00 |
12-10-2022, 09:14 AM | #11 |
Rep 1,818
As far as the CDV in M2C, it made the clutch pedal a little softer to press. I do like the more direct clutch engagement, but I don't think it did much else overall. I wouldn't go back, however.
12-10-2022, 03:50 PM | #12 | |
Rep 488
12-10-2022, 03:54 PM | #13 | |
Rep 488
Removal of the CDV apparent makes fast getaways from a standstill easier. |
chris7197378.50 |
12-10-2022, 03:57 PM | #14 | |
Rep 488
Agree, on F87 platform it seems less of a necessity to remove it, although it would be nice to try. |
chris7197378.50 |
12-10-2022, 05:13 PM | #15 | |
Rep 241
12-11-2022, 03:33 PM | #16 |
Rep 7,336
I drove hard yesterday and noticed this "torque management" on 2nd to 3rd also. I did not have DSC off, however, but no light flashed. I'm not sure if we are talking about the same thing though exactly.
12-12-2022, 01:01 PM | #17 |
Rep 221
21 6MT BSM M Drivers, no lag. No issues, very very happy.
BMWCCA M Chapter & NJ chapter
'21 BMW M2C BSM 6MT MDrivers Pkg |
12-12-2022, 01:27 PM | #18 |
Rep 7,336
Did you swap the slave cylinder with the E90 part or remove the restriction in the original? I wonder if the softer pedal is just due to the E90 slave?
