09-27-2022, 07:49 AM | #111 |
Rep 345
Front and rears almost maxed out lol still rides good in the canyons. What's the consequences of maxing it out as per recommended ride height? Not good for a long run?
10-04-2022, 08:26 PM | #112 | |
Rep 92
As far as ride height goes, can it go lower than your current settings? I heard the b16 can’t go low. Now I’m not looking for slammed/tuck but just fender to tire fitment. Half a finger gap to no gap type of fitment. I know the mperformance suspension at max rear still has a finger gap which is why I opted away from them |
10-08-2022, 12:39 AM | #113 | ||
Rep 163
2nd pic I raised it about 10mm front and 20mm rear but on 255/40 & 275/40. Rides perfect now.
18 LBB M2
10-29-2022, 05:56 AM | #114 |
Petrol Head
138
Rep 157
Drives: Current: F87 M2C, Jeep Wrangle
I just installed the Litchfield B16 on my M2C, and I absolutely love the setup
I only lowered the car about 1cm all around, installed new set of PS4S, and adjusted the alignment as per Litchfield recommend setup. The car feels much more refined. The suspension now feel premium and sophisticated. I absolutely recommend it for a daily driver. The only set back I had when installing it was the clicking sound the front wheels made when turning at full lock. Litchfield then provided me with insulation tubes for the front springs, and that fixed it permanently. Here are some pics of before and after, the alignment setup and the front springs.
Lagom...
"not too little, not too much" |
10-30-2022, 09:38 PM | #115 |
Rep 858
Drives: F87 M2CS
Is the insulation tubing all that's needed to cure the clicking? My f82 on Bilstein b16d did the same and my current f87cs already came with kw has that also has the clicking but more prominent than compared to the m4.
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
10-30-2022, 11:38 PM | #116 | |
Petrol Head
138
Rep 157
I also applied some white lithium grease all around.
Lagom...
Reddevils7981.00 |
11-10-2022, 04:13 AM | #118 | |
Rep 1,590
Also the vendor where you buy coils from is just as important as the coils itself as I've seen issues with both Bilstein and KW in the warranty department and they often go through vendors. |
11-10-2022, 12:52 PM | #119 | |
3847
Rep 54,376
Drives: F80 M3
KW V3 adds independently adjustable compression damping, but you will likely gain much in damping or quality. However, you will have around $700 more. At that price you are better off with Ohlins R&T. Ohlins is running a rare November sale right now. PM for details. |
M2RAW121.00 |
11-11-2022, 03:59 AM | #120 |
New BMW owner
325
Rep 843
Where's the best place to get the complete kit in the US?
I don't want the car to become lower, well myb just a little if ever. Is that possible?
11-11-2022, 05:10 AM | #121 | |
Petrol Head
138
Rep 157
The best offers I have found on the standard B16 are in the UK (https://www.mlperformance.co.uk/prod...cef7&_ss=r). Shipping cost isn't bad. Here are some pictures of my setup.
Lagom...
11-11-2022, 06:51 PM | #122 |
New BMW owner
325
Rep 843
I can get the set locally for about 2600$ installed. This is probably not one of those things we would install ourselves right? Is there anything else I should be getting on top of the PSS10 “set”?
11-11-2022, 07:40 PM | #123 |
3847
Rep 54,376
Drives: F80 M3
11-15-2022, 09:25 AM | #124 | |
Rep 3,696
The site you referenced (MLP) won't have the regular B16 kit in stock until late Jan, but it's quite a bit cheaper than Litchfield's kit which is in stock. Trying to decide if the extra Litchfield cost is worth it, or should wait til Jan for the cheaper set. Also seems like if Litchfield's specs and pricing is the same for their Bilstein & Nitron kits, I would go Nitron for the added ride height and dampening adjustability. Thoughts? Thanks. |
11-15-2022, 11:00 AM | #125 | ||
Petrol Head
138
Rep 157
Unfortunately I can't help you with that. I went with Chris Harris's recommendation
Lagom...
11-29-2022, 02:33 PM | #126 |
Rep 3,696
Can anyone confirm if the PSS10 B16's work with the F30/OG M2 style Vorshlag camber plates?
Vorshlag tells me the Bilstein's should have an M12-1.5 thread pitch and should work, but just trying to confirm. Thanks. |
12-08-2022, 12:23 AM | #128 |
Rep 75
Depending on how much it's lowered, anywhere from good idea to very important. Modern cars (most, not all play by these rules) change toe at different rates depending on the suspension design, however they generally go the same direction. When it in bump/compression the front axle usually toes out (negative toe) and the rear toes in (positive toe). With how critical the alignment is on a performance car like an M2/3/4 it's important to make sure it's correct, especially after changing ride height.
Another thing to consider that is very, very commonly missed. When you change the ride height by a significant amount it's also very important to re-clock all the rubber torsion/twist bushings. If this is not done, the bushings will wear prematurely and have odd behavior due to stored energy and binding. Last but not least, new springs have tendency to settle/sag anywhere from 10-15mm after they are installed and driven. In fact, Audi specifically says not to align any new vehicles until 1,200 miles at a minimum to ensure the vehicles have settled entirely. Most manufacturer's factory alignment would be out of spec on an alignment rack right off the assembly room floor but would be in-spec after a few hundred miles due to intentional shifts built into the factory alignment. Short story, whether it's lowering springs or adjustable coilovers, build an alignment into the cost of doing it, it'll save you $$$ in the long run and help make the car feel the way it's supposed to. |
12-22-2022, 11:21 PM | #129 | |
New BMW owner
325
Rep 843
12-22-2022, 11:28 PM | #130 |
New BMW owner
325
Rep 843
Finally took the leap and had B16 installed. –12mm on all four. Set at 4F and 2R from the shop. Not sure why but I’ll be trying out diff settings when I get a chance anyways.
Kattanah137.50 |
12-23-2022, 08:55 AM | #131 | |
Rep 3,696
Sounds like all the ride height issues people have been mentioning wasn't a prob? Last edited by ZM2; 12-23-2022 at 09:12 AM.. |
12-23-2022, 11:22 AM | #132 |
New BMW owner
325
Rep 843
I wouldn’t be too quick to say that. My –12 drop is out of range so likely there’s a trade off. Whether it appears or not and when, I can’t say that just bec you’d see many here doing “as low as it’s going to go”, or as close to stocks as possible. I’m sticking my head out without assurance.
For me so far it’s not night and day. I have very limited seat time though and it’s been city driving only so far. Last edited by vrooooom; 12-23-2022 at 11:52 PM.. |
